Old 10-08-2000
MrLip MrLip is offline
Force of Nature
MrLip has a reputation beyond reputeMrLip has a reputation beyond reputeMrLip has a reputation beyond reputeMrLip has a reputation beyond reputeMrLip has a reputation beyond reputeMrLip has a reputation beyond reputeMrLip has a reputation beyond reputeMrLip has a reputation beyond reputeMrLip has a reputation beyond reputeMrLip has a reputation beyond reputeMrLip has a reputation beyond repute
Has anyone had problems with this combination?
I can't get Logic to see my PC AV driver. I've downloaded all latest drivers from sblive.com. Next to PC AV driver it just says "no driver". Next to this there is a 'control panel' button but when I click it nothing happens.
It seems that it doesn't see any compatible drivers. I had no problems with logic 4.2
Anyone had this problem or know how to fix it?
Old 10-09-2000
John Sayers's Avatar
John Sayers John Sayers is offline
Solar Power!!
John Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond repute
Got the same problem Mr Lip - I'll await someones reply also
Old 10-11-2000
Guest
Posts: n/a
I would go back to 4.2 and stay there for a while, I had nothing but trouble with 4.5. There are many issues that Logic needs to work out before I will upgrade again. Right now 4.2 works wonderful, so I can't justify the change. When I did it the first time it was just to try out ASIO but soon found out that ASIO is a CPU hog and crashes WAY to much. Anyway if you don't already know about this great message board here is the addy. http://www.ozemail.com.au/~oscwilde/
Its an awsome Logic board and through the faq you should find the answer to your question.
Its bedtime goodluck,
Shakes,
Have you hugged your JoeMeek today?
