Old 10-10-2005
oneup009 oneup009 is offline
Newbie
oneup009 is a glorious beacon of lightoneup009 is a glorious beacon of lightoneup009 is a glorious beacon of lightoneup009 is a glorious beacon of lightoneup009 is a glorious beacon of light
new set-up
thinking of buying some new equipment... what do you think of this set up? (primarily for recording acoustic guitar and vocals)
mxl 990/991 > art tube V3 preamp > fostex mr8 > computer line in > cool edit pro 2.0
thanks
Old 10-10-2005
reshp1's Avatar
reshp1 reshp1 is offline
1K Silver Member
reshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond repute
I would do something like this instead.
MXL990/991>firepod>computer running cheap DAW program.
If your final product comes out of your computer, why record it through a crappy preamp, into a mediocre standalone recorder, then pipe it all in via the line in of your shitty consumer soundcard? Simplify it down to mic>all in one preamp/ADconvertor/interface>computer, you should get a lot cleaner recordings that way. BTW, I just threw the firepod out there as an example, there are plenty of other good options.
I wish my lawn was Emo so it'd cut itself.
Old 10-10-2005
Newbie
forgot to mention, im on a pretty tight budget, around 300. the mr8 would be bought used from a friend for about 100, plus the preamp/mics - should be around 300. im also considering spending a bit more and going for the mr-8 HD and running that into cool edit
Old 10-10-2005
reshp1's Avatar
1K Silver Member
Okay, well if you are getting all the stuff used cheap, then I see your reasoning. Just realize that the weak link is still the line in on your computer sound card, it's just not designed for critical audio work. How many channels are you planning on recording at a time? There's pretty good interfaces that can be had for $300-400, preamps included depending on how many channels you need. Here's a few options.
http://www.musiciansfriend.com/srs7/...se_pid/701385/
http://www.musiciansfriend.com/srs7/...se_pid/709201/
http://www.musiciansfriend.com/srs7/...se_pid/242511/
Old 10-11-2005
Adam P Adam P is offline
stuck in the money pit
Adam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond repute
All of reshp1's suggestions are good ones. He's also correct in saying that the weakest link is still your compuer's soundcard.
For a little less money, you could get theM-Audio 1010LT. It has 2 mic preamps, though I don't know what quality, but I'd suspect that they're not any worse than the ART unit. The only drawback is that it doesn't have any monitoring capabilities the way those other units do. You can save up for a mixer for monitoring though, and it will also give you more preamps to record multiple sources at once.
Old 10-11-2005
Robert D Robert D is offline
Close to the Edge
Robert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond repute
Think of it this way - whether you run an old P-III or a Cray super computer, the sound of your recorder (the computer) is the sound of your soundcard, or audio interface. If your interface sucks, everything sucks. I know it's hard to spend limited funds on this, but it's really the foundation of building your DAW recording setup.
-RD
Old 10-11-2005
Tonedrone Tonedrone is offline
Newbie
Tonedrone is on a distinguished road
I think you can buy Tascams 424mk3(yes a four track) for about $300. The pres on those guys are'nt half bad
Old 10-11-2005
Close to the Edge
Dead end. Get a proper interface and the skys the limit.
Old 10-11-2005
arnorhs's Avatar
arnorhs arnorhs is offline
Newbie
arnorhs is on a distinguished road
Spend everything on a microphone and a computer interface. M-Audio 2 channel USB interface with Mic inputs (and 48V phantom power) should do the trick very nicely and a Behringer B1 Mic should do the trick very nicely (I have one - I can promise it's very good).
With that setup you'd be on budget and also very well prepared.
Old 10-11-2005
Newbie
thanks for all the suggestions everyone...
i'm intrigued by the usb preamp/higher-end mic idea... would something like this be compatible with cool edit pro for direct recording?
http://www.musiciansfriend.com/srs7/...se_pid/701368/
Old 10-12-2005
I could be wrong, but I don't think the M-Audio units work with Cool Edit. Don't quote me on that though. I think that Cool Edit uses WDM drivers, and the MobilePre is compatible with ASIO and MME.
The Tascam US-122 (link) should though, for $50 more.
Both units come with their own software for recording though. The M-Audio with Ableton, I believe, and the Tascam with a version of Cubase.
J-station guitar tones for bass? badassmak Guitars and Basses 11 11-11-2005 10:16
Tascam M-35 Help please Blackdog.sn TASCAM User Forum 23 08-04-2005 01:26
New set woes tilinmyowngrave Drums and Percussion 7 06-17-2005 17:15
Studio Drum Set Michael Jones Drums and Percussion 4 09-11-2002 14:42
knowledge share on my vocoding emerald tablet Recording Techniques 10 08-16-2002 12:40
