Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 10-09-2005
11miles 11miles is offline
Senior Member
11miles will become famous soon enough
Eq-ing voice
Hey,
I've been seaching the forum, for soeme good tips on how to eq voice, so it really gets out of the speakers!
THe low cut, the presence boost, high shelf?
With man voices, i tend to cut it around 80Hz. I cut this band around 450-500, with really great results. THen boost the mid range at around 3-4k. Both for 3-4dB, or whatever is necessary. And then i boost the high's with the hgh shelf at around 8-9k
Similar to women but the bands are a bit higher. Low cut at 110?
Anyway, i've been wondering what is your aproach?
How do you do it?
How does the eq-ing change when you have the singer really close (proximity effect)
Me, failing English? That's Unpossible...
Old 10-09-2005
Dogman's Avatar
Dogman Dogman is online now
Campeón de la Internet
Dogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond repute
Originally Posted by 11miles
Hey,
How do you do it?
I have found, with my own voice anyway, that if I'm close to the mic, I might need to take down the low end a bit more than when I am farther from teh mic. It all depends on the song for me, as some tunes need the boomy lower end, and some don't. I usually don't take any highs out, but might if some how they don't fit. This probably has to do with my 1/4 octave range though...
If I want a somewhat lo-fi type sound, then I cut highs, and lows a bit, more of the lows. But, it's all gonna be different with each voice, and probably with each song.
Ed
I won the internets......
Old 10-09-2005
Senior Member
yes i know, that it depends from the voice!
But in general, some good ways too try the voice to come out of the speakers?
Mine are as described...
I do all the ''finding out'' with sweeping!
I find it the easiest way, to boost up everything and try to set Q jsut right!
Not to BELL-y and not to NOTCH-y
I have had some good reults!
And i like to take the ''garbage out'' in the 200Hz region! Some voices are very muffled there! I liek to take them out aswell!
SO in general it's a lot more cutting than boosting!
THe proximity is where things get a bit more complicated if you ask me!
You want to do it bassy- Otherwise you would not go for the ''get your mouth as close to the mike as possible'' method!
Usually you wont voice to be up close, and with bassy feeling you are not in the right direction! I still have nto found a great way to deal with it in the mix!
And do you compress right away? Much?
Old 10-09-2005
Dogman's Avatar
I actually compress just a little at tracking, but mainly because I can't sing, and am loud most of the time. Keeps my vocal a little more even. I think with a good performance, you won't need to do this, but I never have a good performance...
Old 10-10-2005
scarboro78's Avatar
scarboro78 scarboro78 is offline
NYC HIP-HOP AMBASSADOR
scarboro78 has a reputation beyond reputescarboro78 has a reputation beyond reputescarboro78 has a reputation beyond reputescarboro78 has a reputation beyond reputescarboro78 has a reputation beyond reputescarboro78 has a reputation beyond reputescarboro78 has a reputation beyond reputescarboro78 has a reputation beyond reputescarboro78 has a reputation beyond reputescarboro78 has a reputation beyond reputescarboro78 has a reputation beyond repute
Why would you cut more low end of a woman's voice?? Unless she sounds like Barry White.. (which would be scary)
My Current Chain:
AKG 414-B/XL II or BLUE Dragonfly > Avalon 737 > Apogee Trak2 > Aardvark LX6 > Cubase SX 2.0> Mackie Big Knob > Event TR8's & Event Tria's & MoreMe Headphones
Old 10-10-2005
scrubs's Avatar
scrubs scrubs is offline
Not of sound mind
scrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond repute
Hopefully, if I did my job right when tracking, I don't need any EQ adjustments other than, perhaps, a low cut at around 80-100Hz. Work on microphone placement, preamp gain staging, and possibly slight compression when tracking to make the vocal "stick out."
"That was so terrible, I think you gave me cancer!"
My tunage
Recording Solo Acoustic & Voice mcolling Recording Techniques 5 05-09-2005 16:51
Voice Master Pro versus Ultravoice Digital luigi Mixing / Mastering 2 07-04-2003 20:40
Calm Relaxed Voice or Strained Edgier Voice? Robertt8 MP3 Mixing Clinic 16 06-20-2003 07:39
mic for my midrange voice shortyprs Microphones 21 05-11-2003 22:19
