Old 10-07-2005
UKPete UKPete is offline
Newbie
UKPete is on a distinguished road
Recording bass
Was wondering the best way to record bass onto my computer software. I have a delta 1010lt sound card, Trace Elliott amp. I can D.I from the amp also output it direct into my soundcard. i also have a pre amp.. the trouble is, it spounds a bit dull, does it help if I get new strings on?
Or maybe record the amp with a microphone?
Old 10-07-2005
scrubs's Avatar
scrubs scrubs is offline
Not of sound mind
scrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond repute
There is no one "best way" to record bass. There is only the best way for a particular song and setup, depending on what you want to achieve. Try out the different options and find out what sounds good to you. I usually go DI, but sometimes blend a miked amp with the DI signal. The DI provides the low end fullness, while the cab provides the high end definition, imo.
"That was so terrible, I think you gave me cancer!"
My tunage
Old 10-07-2005
Atterion Atterion is offline
The Dark Knight
Atterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond repute
I'd run the DI out of the Trace Elliot to the Delta and use the Mic and Pre on the cab. Not sure of your speaker size, but I prefer to mic a 10" speaker rather then a 15" or 18". The 10" will give you better definition (And I've found that unless you get just the right combination of components in the signal chain, a 15" or 18' woofer will generally sound "Flappy"). New strings are a big plus, especially where you claim your sound is dull.
Torment, Violent Aggression,
Systematic State of Oppression.
The Heretics, All Swing From The trees,
Cast To Hell, With Their Disease. DARKENED
Old 10-07-2005
tourettes5139's Avatar
tourettes5139 tourettes5139 is offline
ugh..........
tourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond repute
I second the suggestion of new strings. That will make a huge difference. I know it did in my recordings.
Check out my band!!
www.myspace.com/darkvelvetlaughter
GFCG Membership No:000 019
Old 10-07-2005
peteuk90 peteuk90 is offline
Newbie
peteuk90 is on a distinguished road
Cheers guys, will try the combinations, and I totally agree about the strings! It's either £25 or boiling them.. hee hee
Old 10-08-2005
CarcPazu CarcPazu is offline
Senior Member
CarcPazu has a reputation beyond reputeCarcPazu has a reputation beyond reputeCarcPazu has a reputation beyond reputeCarcPazu has a reputation beyond reputeCarcPazu has a reputation beyond reputeCarcPazu has a reputation beyond reputeCarcPazu has a reputation beyond reputeCarcPazu has a reputation beyond reputeCarcPazu has a reputation beyond reputeCarcPazu has a reputation beyond reputeCarcPazu has a reputation beyond repute
Boiling them? Is this working? I mean can you actually get old strings better doing this?
CarcPazu
Old 10-09-2005
Blade_Jones Blade_Jones is offline
Newbie
Blade_Jones has a little shameless behaviour in the past
Try running thru a high end channel strip like a $2,800 Focusrite ISA 430 MKII and you'll hear a sweet, smooth EQ and a limiter that kicks butt. It also helps to record bass parts in sections. On my bass the A and G strings are not as loud as the E string. So you go back and actually DOUBLE some of the quiet notes. So basically a combination of high end gear and recording technique might help you a lot.
Old 10-09-2005
The Dark Knight
Yeah it helps. It basically cleans out all the dead skin and grime that builds up in the string windings (Which is one of the biggest culprits of giving you a dull tone). It doesn't return your string to quite brand new sounding, but brings it back to life for sure. More like the sound you get after you had played your strings for a couple of weeks. I actually prefer that sound over the brand new sound of strings (which always seem just a bit too bright), but I'm far too lazy to actually boil mine.
Old 10-10-2005
Monkey Allen's Avatar
Monkey Allen Monkey Allen is offline
creeping moses
Monkey Allen has a reputation beyond reputeMonkey Allen has a reputation beyond reputeMonkey Allen has a reputation beyond reputeMonkey Allen has a reputation beyond reputeMonkey Allen has a reputation beyond reputeMonkey Allen has a reputation beyond reputeMonkey Allen has a reputation beyond reputeMonkey Allen has a reputation beyond reputeMonkey Allen has a reputation beyond reputeMonkey Allen has a reputation beyond reputeMonkey Allen has a reputation beyond repute
I mic up the amp with a condenser mic, goes pretty well
Old 10-10-2005
AGCurry AGCurry is offline
Force of Nature
AGCurry has a reputation beyond reputeAGCurry has a reputation beyond reputeAGCurry has a reputation beyond reputeAGCurry has a reputation beyond reputeAGCurry has a reputation beyond reputeAGCurry has a reputation beyond reputeAGCurry has a reputation beyond reputeAGCurry has a reputation beyond reputeAGCurry has a reputation beyond reputeAGCurry has a reputation beyond reputeAGCurry has a reputation beyond repute
Are you serious?
Old 10-10-2005
The Dark Knight
Originally Posted by AGCurry
Are you serious?
Sounds like he's serious. And sounds like he needs to readjust his pick-ups too. I've never had that problem.
  #12
Old 10-10-2005
giraffe's Avatar
giraffe giraffe is offline
i love negative rep
giraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond repute
been here, done this, it works.
audio?
seriously, give me negative rep.
  #13
Old 10-10-2005
Senior Member
And what about baking them with HP sauce in microwave?
CarcPazu
  #14
Old 10-11-2005
giraffe's Avatar
i love negative rep
actually, i've also thrown them in the freezer overnite, it works, but not as good as boiling them.
audio?
  #15
Old 10-11-2005
snow lizard's Avatar
snow lizard snow lizard is offline
Dedicated Slacker
snow lizard has a reputation beyond reputesnow lizard has a reputation beyond reputesnow lizard has a reputation beyond reputesnow lizard has a reputation beyond reputesnow lizard has a reputation beyond reputesnow lizard has a reputation beyond reputesnow lizard has a reputation beyond reputesnow lizard has a reputation beyond reputesnow lizard has a reputation beyond reputesnow lizard has a reputation beyond reputesnow lizard has a reputation beyond repute
A conventional oven would be better, but I've never been partial to HP sauce.
Habanero oil and lemon juice... that's different. It's a matter of taste, I guess.
(and just boiling them in plain water will temporarily bring back some life to the tone.)
sl
Which bass for recording that modern deep tone all rockers use today? (Nickelback...) StarSyn Guitars and Basses 12 09-30-2005 09:05
Anyone have advice on recording jazz fusion bass? ProgMetalShred Recording Techniques 11 09-07-2004 00:28
Anyone have advice on recording jazz fusion bass? ProgMetalShred Guitars and Basses 1 09-04-2004 21:01
aardvark direct pro user.... Advice on recording DI Bass needed Rassoodocks Recording Techniques 13 06-24-2003 07:09
Help choosing a bass for recording mcmd Guitars and Basses 9 08-13-2001 14:07
