which mic to use on bass amp?
pick one to use on a bass amp...
studio projects b1, oktava mk012, shure sm57 or sm58 |
57 + DI is always a class act
reamp bass through a guitar amp with a 58
I'd be tempted to reach for the B1, 57, Oktava, and 58, in that order, but I've never used the B1. Personally, if I'm miking up a bass amp, I'm putting my ATM25 or my Beyer TGX-50 on it, or maybe even the Oktava 219.
the B1 and the 57 should be fine...
I've had satisfactory results using an SM58 on a Peavey TKO bass amp, and running the track through Antares Mic Simulator. I'd make the SM58 model the LD kick mic from Shure (forgot the model name, Beta 52 if I'm not mistaken). I'd mix this with the DI signal for extra clarity.
Also, if you have Amplitube, check out its bass amp presets. I've gotten good results running a DI bass track into one of those, and a Sonitus compressor (which comes with Sonar) thrown in to even out the bad playing. |
Give that little Oktava a try. I quite frequently use AKG 451's or 414's on bass cabs. Personally, I like the tightness of the small diaphragm condensor the best. However, a 57 or 58 will generally do just fine. ANy of those mics will do as a matter of fact. The real trick is how you place it, and what you do with the signal after it hits the mic
Be sure to check your phase, especially with bass guitar. |
thanks fellas
most of you guys were wrong... the oktava mk012 out performed every other mic... and generally has since I got myself a matched pair...
Whatever works for you, mate. Good to hear that you've found your sound.
thanks. yeah as it turns out... the oktava captures the source of the sound better... with an sm57 or 58, did you find you guys had to EQ it quite a bit to sit well in the mix?
#12
#13
DI stand for "direct injection"...its a way of recording instruments that's an alternative to putting a microphone in front of an amp.
#14
#15
that's one of the reasons that the 57/58 is "the industry standard" that many believe it to be--especially among live sound engineers. it's not b/c it sounds good straight out of the box.....it's b/c it takes eq VERY well. in almost every instance that i've used a 545/57/58, i've had to eq it in some way to get it to sit right. in fact, that's generally the only reason i'll even hang one of those mics anymore--is to have a track that i can radically eq and know it'll "take it" well. cheers, wade |
| Which mic for a bass amp????? | Franky 2000 | Microphones | 15 | 02-19-2005 15:01 |
| Synth bass to bass amp...help! | copperandstars | Guitars and Basses | 6 | 10-25-2003 14:55 |
| What bass and bass amp should I buy? | Mongoo | Guitars and Basses | 10 | 02-21-2003 21:49 |
| NT1 Rode ? | Ears | Microphones | 24 | 06-27-2000 09:16 |
