Please recommend an A/D converter.
I've been looking for a decent preamp to be used between my Roland VS-1680 and a pair of AKG C3000B's. First I started to look at those low cost toob pres from Art, Presonus etc. but after reading through this and other forums, I thought maybe it's not the right way to go.
However, when I read through the VS-planet (Roland user forum) I read several recommendations that with VS-1680 you should have a preamp with digital out, to be able to completely bypass the on-board pres AND converters (which are only 20 bit and not high quality). Many users there recommend the Art DPS II. Well, if I have understood right the DPS II is not great as a preamp, though the A/D converters are very usable. Now I'm also thinking about the possibility to buy a separate converter and a better pre, like DMP3 or RNP. So, could you recommend me a good but not too expensive A/D converter. In fact the price should be considerably less than the price of DPS II, because otherwise I don't see any reason not to by the DPS, just for the converters (because you can bypass its preamp and use it only as a converter). Thanks in advance! (If someone is interested to listen how my music sounds recorded using only Roland's own pres, please visit http://www.mikseri.net/artists/juhasavisalo.34865.php ) |
It's hard to believe people are suggesting the ART DPS2 to improve conversion. I would guess, based solely on price and reputation, that those AD converters would be pretty similar to the stock converters on your Roland recorder. My sense is that to achieve any real or even perceived improvements, you would have to find a much better device at a somewhat higher cost. Many folks around here suggest the Kurzweil Rumor ($499) for it's converters. If you have more to spend, there is also the Lucid 9624 which is about $850. |
There are no cheap stand-alone A-Ds. For $300, you can have two very nice mic pres plus two line level ins and satisfactory A/D with the Presonus Firepod. The RME ADI-8 is as good as you'll ever need, but it ain't cheap.
The fabulous Naiant Mics, perfect for acoustic instruments!
If you don't have DavidK's CD, you are a loser. My tunes. Thanks! ![]() NB DA BEARS! |
Thanks for your comments. Now that I've looked more the prices of stand-alone converters, I very well understand that something like DPS II can't possibly have any quality converters for that price. Although, it's a bit surpricing to read reviews in SOS and EMusician which give quite good marks for this preamp in general and also it's converters:
http://www.soundonsound.com/sos/Oct0...les/artdps.htm http://emusician.com/signalprocessor...dps/index.html For someone like me, with no own knowledge base in these things, it's quite difficult to make decisions when all kind of information and opinions come in from many directions... One more silly question: how much do you think the quality of conversion affects the sound quality, compared to the effect of a good preamp? So, with my Roland 1680 and limited budget, should I spend my money to a decent converter (maybe RME ADI-2?) + an OK pre (like DMP3) or just buy a better pre (RNP, Grace...) and use the analog ins? |
You have to take magazine reviews with a grain of salt, how many times have you ever read a really bad review? You have to kinda read between the lines and see what actual users think.
I wish my lawn was Emo so it'd cut itself. |
I was always under the impression that converters made the SMALLEST change to the sound. However, Dot (Dan at www.soundpure.com) said my converters (MOTU 828mkII) were holding me back from realizing the improvements from better mics and pres. So, I bought a used apogee ad16/da16 - it made a HUGE difference. Way more than any other single piece of gear. Converters really do make a difference! ![]()
They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety. -B.F. |
I wouldn't sweat the difference between preamps and converters. Just assume both are important and plan to eventually get the best you can afford in both categories. The same can be said for mics. |
the art unit has a DIO converter in it. it has been known by the audiophile types to kick some butt just do a internet search. for the price you cant go wrong. you will get a good converter much better than the roland and a mic pre that will keep you busy with all its different settings for a while till you feel the need to upgrade.
Hehe... this is just what I ment in my earlier post when I talked about the many kinds of opinions and reviews
. Yes, a quick search shows that many people indeed seem to like the DIO. Dwillis, the Roland unit has both optical and coaxial SPDIF in/out. And the manual describes how to change the "reference clock" from internal to external, so I guess everything should be fine for using an external converter that has SPDIF out. |
Ive been doing this for about 4 years now and started out buying cheap gear. Now that Ive grown in understanding and bought 4 of everything trying to get a good sound Ive learn one important thing.
If your not spending at least 1000.00 for a pre or converter you're just wasting your money for something that is not much if an improvement and you'll soon be replacing. Save your money by buy some professional equipment.
The most popular HR member - just do a search
#12
#13
I guess I should have said as you get close $1000.00 you start noticing a major imporvement as a general rule.
#14
the 1680 roland is only 20 bit so going to 24 bits with the art DIO as well as a better converter WILL BE NIGHT AND DAY i have used my brothers a couple years back so i know. do a search for THE BORDER CABLE COMPANY if you have any doubts to its quality. im thinking its better than the flying cow.
#15
there is always the possibility that you may hear no difference at all given the perceptiveness of your ears or the quality of your monitoring setup. |
#16
In His Name Big Kenny |
#17
http://emusician.com/mag/emusic_dbx/index.html http://emusician.com/signalprocessor...l_2/index.html |
#18
ahem, if you are plugging this into your roland machine and its only 20 bit, whos to say it won't just ignore the extra 4 bits from a 24bit converter?
http://www.floridadiy.com |
#19
#20
| Recording setup, A/D converter + soundcard or both-in-one ? | Soulgolem | Digital Recording & Computers | 0 | 08-13-2005 11:48 |
| Sonic Solutions A/D converter | Chip Hitchens | The Rack | 6 | 03-25-2004 14:47 |
| Good A/D converter (for cheap, OF COURSE)? | ScienceOne | The Rack | 14 | 01-31-2004 22:19 |
| FS: Mindprint DI Port 2-channel Class A mic pre and A/D converter | chessrock | Free Ads for Music / Recording Equipment | 9 | 05-18-2003 19:16 |
| What is the 24bit a/d converter ? eom | mosthigh | Other Equipment and Reviews | 3 | 11-06-2000 11:21 |
