Go Back   Home Recording > Equipment Forums > MIDI Mania
Reply    Audiofanzine Electronic-instrument Electronic-instrument News Electronic-instrument Medias Electronic-instrument Tests Electronic-instrument Articles Electronic-instrument User Reviews Electronic-instrument Classifieds Ads
Old 10-03-2005
spindrummer82 spindrummer82 is offline
Newbie
spindrummer82 has a brilliant futurespindrummer82 has a brilliant futurespindrummer82 has a brilliant futurespindrummer82 has a brilliant futurespindrummer82 has a brilliant futurespindrummer82 has a brilliant futurespindrummer82 has a brilliant futurespindrummer82 has a brilliant futurespindrummer82 has a brilliant futurespindrummer82 has a brilliant futurespindrummer82 has a brilliant future
E-drums and Reason 3.0
I have Reason 3.0 and a home built e-drum kit. I got an Alesis D-4 which is pretty limited in the sound department. I got some good sounds using Redrum and some effects on patched in and I made some drum tracks just by clicking notes into the midi sequencing part.
I want to record into the Redrum midi sequencer with my e-drums. I have an M-Audio Midisport 1x1 and need to know how to set it up so the channels line up right (kick drum from drum brain to the kick drum track of Redrum).
Or would it be easier to record the midi into Samplitude (which I know how to do) and copy it from there into Redrum?
All ideas are welcome.
Old 10-06-2005
ssscientist's Avatar
ssscientist ssscientist is offline
Info you can use...
ssscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond repute
If you were forward thinking enough to make your home-built E Drum kit so that the midi note numbers that it sends out can be changed, change them to match the Redrum, put the appropriate track in record and you should be all set.
If not, you'll need a midi utility program like MidiOx that can remap incoming midi notes. Assuming that you will need to press MidiOx into service, set it to recieve the notes the drum pads send, then set it to output straight into Reason -- not ReWired or anything --with the appropriate notes remapped.
As far as Samplitude goes, any program that can generate a SMF (standard midi file) is compatable with Reason, but it would probably be more immediate and satisfying to control the Redrum in real time from your own kit.
Reason and electronic drums and midi Vullkunnraven MIDI Mania 3 04-15-2005 13:36
reason 3.0 or Sonar 4 Modern_Talking Newbies 1 12-25-2004 03:01
Reason 2.5 and Sonar 2 for drums... MadStrum! Drums and Percussion 1 09-19-2003 10:40
Sonar using Reason drums djc Cakewalk / Sonar Forum 3 07-26-2002 13:38
