Old 10-03-2005
jalbert jalbert is offline
Senior Member
jalbert has a reputation beyond reputejalbert has a reputation beyond reputejalbert has a reputation beyond reputejalbert has a reputation beyond reputejalbert has a reputation beyond reputejalbert has a reputation beyond reputejalbert has a reputation beyond reputejalbert has a reputation beyond reputejalbert has a reputation beyond reputejalbert has a reputation beyond reputejalbert has a reputation beyond repute
Using An Amp As A Mixer
I have a Marshall AS100D amp that has four channels. I want to run a few microphones into the amp and then use the DI outputs on the back to run a line into one channel of a digital recorder(possibly the Tascam DP-01FXCD). When I've tried to record the signal coming from the DI outputs with a tape recorder it always sounds horribly distorted no matter what I do. Will I have the same problem when I run it into the digital recorder? Why won't it work with a tape recorder? I'm also planning on using a line from DI outputs to connect my amp to a small PA. Will I have a problem with that too? Any help woud be great. Thanks.
Pay no attention to that little red square.
Old 10-03-2005
thediscoking's Avatar
thediscoking thediscoking is offline
Junior Member
thediscoking is a jewel in the roughthediscoking is a jewel in the roughthediscoking is a jewel in the rough
Come on, man. Save the earth and buy a mixer.
Old 10-04-2005
ssscientist's Avatar
ssscientist ssscientist is offline
Info you can use...
ssscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond repute
I second thediscoking's suggestion. This is $100 and will be $100 well spent.
Old 10-04-2005
olfunk olfunk is offline
Dedicated Member
olfunk has a reputation beyond reputeolfunk has a reputation beyond reputeolfunk has a reputation beyond reputeolfunk has a reputation beyond reputeolfunk has a reputation beyond reputeolfunk has a reputation beyond reputeolfunk has a reputation beyond reputeolfunk has a reputation beyond reputeolfunk has a reputation beyond reputeolfunk has a reputation beyond reputeolfunk has a reputation beyond repute
i use the 50watt version of that amp as a mixer dude to record with. your version is even more capable so if you don't wanna get a mixer like me, then you may as well use it.
"And you can function as someone besides who you are." John Frusciante
http://imagegen.last.fm/red/oartists/olfunk.gif
Old 10-04-2005
Senior Member
Thanks for actually answering my question. Do you use the DI outputs when you're recording with the amp? Do you run a line right from the DI's into a mic input on a recorder? Have you tried hooking your amp up to a PA using the DI's? Thanks.
Old 10-04-2005
irishfolker's Avatar
irishfolker irishfolker is offline
Structural Member
irishfolker has a reputation beyond reputeirishfolker has a reputation beyond reputeirishfolker has a reputation beyond reputeirishfolker has a reputation beyond reputeirishfolker has a reputation beyond reputeirishfolker has a reputation beyond reputeirishfolker has a reputation beyond reputeirishfolker has a reputation beyond reputeirishfolker has a reputation beyond reputeirishfolker has a reputation beyond reputeirishfolker has a reputation beyond repute
You might try running into the line in instead of mic inputs on your recorder. That might eliminate the overdriving.
Can I Run Mixer out to guitar amp? bwyatt1009 Newbies 2 03-05-2005 18:11
stereo mic with mini plug to pre amp or mixer? johneeeveee Microphones 3 12-20-2003 06:49
Mixer, power amp and more... ebeam Free Ads for Music / Recording Equipment 3 05-19-2003 11:20
help using the mixer together with the amp washburn10 Recording Techniques 0 02-09-2002 13:13
help mixer + amp washburn10 Digital Recording & Computers 0 02-09-2002 13:11
