Old 10-02-2005
TunaTheFish's Avatar
TunaTheFish TunaTheFish is offline
Junior Member
TunaTheFish is on a distinguished road
delay when recording please help
basically when we try and record there is always a delay. This happens on both keyboard and guitar after playing it takes some time before cubase picks the signal up and records it, it is not much, maybe a few milliseconds but it sounds out of sync when you play it back after recording on top of something. What can we do to solve this problem. The souncard we have atm is crap, could this be the cause of the problem. Is this a common problem or is it normally related to hardware? Thanks
Old 10-02-2005
Ronan's Avatar
Ronan Ronan is offline
Force of Nature
Ronan has a reputation beyond reputeRonan has a reputation beyond reputeRonan has a reputation beyond reputeRonan has a reputation beyond reputeRonan has a reputation beyond reputeRonan has a reputation beyond reputeRonan has a reputation beyond reputeRonan has a reputation beyond reputeRonan has a reputation beyond reputeRonan has a reputation beyond reputeRonan has a reputation beyond repute
This is most likely digital latency when using a host based system. Its the amount of time your computer takes to process the sound while you are playing and spit it back out your speakers.
Ronan Chris Murphy
Ronan's Recording Show My "TV Show" about recording.
Home Recording Bootcamp teaching other guys how to get in trouble
Old 10-02-2005
treymonfauntre's Avatar
treymonfauntre treymonfauntre is offline
Magic Bag Of Sounds
treymonfauntre has a reputation beyond reputetreymonfauntre has a reputation beyond reputetreymonfauntre has a reputation beyond reputetreymonfauntre has a reputation beyond reputetreymonfauntre has a reputation beyond reputetreymonfauntre has a reputation beyond reputetreymonfauntre has a reputation beyond reputetreymonfauntre has a reputation beyond reputetreymonfauntre has a reputation beyond reputetreymonfauntre has a reputation beyond reputetreymonfauntre has a reputation beyond repute
soundcard latency. unfortunately its normal for cheaper soundcards.
http://www.floridadiy.com
Old 10-03-2005
Junior Member
Ok thanks, so the problem should be solved when i put my better sound card in (as soon as i re order a driver CD off the website)
Or is there wa way of downloading the drivers??????
The sound card i have is an Sound blaster audigy platinum eX
Thanks.
Old 10-03-2005
crankz1's Avatar
crankz1 crankz1 is offline
crankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond repute
If you really want to use a Soundblaster card .... You may wish to try the kX drivers.
Better yet, you might want to think about a better soundcard. An Audiophile 24/96 would be much better than your Audigy. If you stick with the Soundblaster, you should keep your sample rate at 48kHz until you master for CD.
~It all works out in the end~
Old 10-03-2005
Ronan's Avatar
Force of Nature
Its not really a matter of cheap versus not so cheap sound cards, it has to do with the sound card using the host computer for processing the audio, unlike something like a Pro Tools TDM system wich does its own processing. TDM systems have latency but its small enough that you would not notice it.
There are some new interfaces that have monitoring schemes that let you work around this problem.
Ronan Chris Murphy
a delay in recording??? HELP jayphon Cool Edit Pro / Adobe Audition Forum 3 08-17-2004 15:18
NY Times article on home recording and soundproofing AlChuck Studio Building & Display 18 04-06-2004 16:46
NEWBIES - FINAL ARTICLE - VOCAL, ORCHESTRAL AND CHOIR recording tips. manning1 Newbies 0 01-07-2004 13:54
recording guitar with delay for example jimi Recording Techniques 7 01-20-2003 11:11
Delay in recording thecrispy1 Cubase User Forum 8 10-30-2001 02:26
