polysterine capacitors
Does anyone know if Radioshack capacitors are considered polysterine capacitors ? Someone here on the forum modded his microphone with polysterine capacitors and I wonder where I could get them . Thanks,
No, Radio Shack are all Ceramic, Tantalium and Mylars. Mylar would be acceptable, but they aren't readily available in 1000pF, which I'm assuming is what you're looking for.
Try getting them from: www.mouser.com www.digikey.com
“Build a man a fire and he'll be warm for a day. Set him on fire and he'll be warm for the rest of his life." |
Here is one example: http://www.radioshack.com/product.as...5Fid=272-1069# Polystyrene caps are a bit harder to find. You'll probably have to mail-order them. |
Yeah, its the coupling capacitor between the capsule and the head amp. Ceramics and tants sound terrible there. The poystyrene have almost the same linearity as a paper in oil cap. That helps remove some of the sizzle.
I think that's what he's after. I could be wrong.
I got mine from Mouser Here is the part number. http://www.mouser.com/index.cfm?hand..._pcodeid=02310
I wish my lawn was Emo so it'd cut itself. |
Do you mean Polypropylene capacitors?
Not for the coupling capacitor at the leads of the head amp, although you could probably use a polypropolene and it would sound good. Ploystyrene are much better. ANYTHING is better than ceramic or tantalium. They suffer from bad hysteresis. That contributes to the shrill high end in budget mics.
I actually did audition polystyrene, polypropylene, and Mylar caps in a homemade mic once, and the polystyrenes were significanty cleaner sounding than the others. These were the generic Mouser style polystyrenes, not the $$$ brand-name audiophile ones, which sometimes don't sound that hot.
BTW the ceramic cap in the MXL 991 does not look like the common ceramic disk. Is this maybe the newer COG/NPO ceramic type which I believe is multi-layer and has a much more linear frequency response and stability? Anyone care to comment on this?
The Only Time Success Comes Before Work Is In the Dictionary |
| LesPaul volume/tone capacitors - what does Hammer use? | Outlaws | Guitars and Basses | 0 | 03-01-2005 12:56 |
| Is Using condensers and Capacitors safe? | dvs recordings | Microphones | 2 | 02-08-2002 18:52 |
| Capacitors: Use electro's or tants ? | MottledGreen | The Rack | 4 | 10-24-2000 17:14 |
