Go Back   Home Recording > Equipment Forums > Microphones
Reply    Audiofanzine Microphone Microphone News Microphone Medias Microphone Tests Microphone Articles Microphone User Reviews Microphone Classifieds Ads
Old 09-27-2005
Luc the Tinkerer Luc the Tinkerer is offline
Newbie
Luc the Tinkerer is on a distinguished road
Question The General opinion on the Apex460 tube condenser mic?
I just bought one yesterday (belayed birthday present! ) as it's the only large diaphragm mic I can afford for vocals. I've read all of the reviews and decided regardless to upgrade the stock vacuum tube - The Tube Shop recommended the Ei 12AX7 as a definite improvement over the stock tube, in fact I ordered a pair: one for the mic and the other for my ART Tube mic preamp.
Since I'm not an experienced engineer I could be running in circles trying to nail that elusive "clear, clean, open sounding vocal" sound, so all input is appreciated ...
My digital audio interface is a E-MU 0404, I own various Behringer gear (Eurorack 6 channel mixer, Composer Pro Compressor and Digital Virtualizer) a ART ube mic preamp and a pair of Apex mics: the 435 and 460, and a pair of AKG headphones.
At this stage the vocals sound boomy and seem to lack clarity & top end on both mics, thus the tube upgrades (though I must admit the 460 is more sensitive and responsive than the 435).
I tried bypassing the compressor, preamping with the mixer, then bypassing the mixer and recording straight to the soundcard from the ART preamp ... I can spruce up the vocal sound a bit with the Patchmix effects, but the end result still lack that polished, well produced sound.
Knock on wood the tube upgrade leads me onee step closer to 'sonic Nirvana'
Old 09-27-2005
scrubs's Avatar
scrubs scrubs is offline
Not of sound mind
scrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond repute
http://homerecording.com/bbs/showthr...light=Apex+460
If you're not able to get a "clean, clear, open" sound out of this mic (which is pretty bright), you may need to look into a preamp upgrade.
"That was so terrible, I think you gave me cancer!"
My tunage
Old 09-27-2005
teainthesahara's Avatar
teainthesahara teainthesahara is offline
Dedicated Member
teainthesahara has a reputation beyond reputeteainthesahara has a reputation beyond reputeteainthesahara has a reputation beyond reputeteainthesahara has a reputation beyond reputeteainthesahara has a reputation beyond reputeteainthesahara has a reputation beyond reputeteainthesahara has a reputation beyond reputeteainthesahara has a reputation beyond reputeteainthesahara has a reputation beyond reputeteainthesahara has a reputation beyond reputeteainthesahara has a reputation beyond repute
I think i would look at your mic technique first, as well as what your doing at mixdown time. That ART preamp, while not the greatest, should not make the sound boomy, nor take away top end.
Old 09-27-2005
PhilGood's Avatar
PhilGood PhilGood is offline
Juice Box Hero
PhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond repute
You can get a good sound out of this mic on most things. It has a slightly scooped sound, which can be improved to a degree with a tube swap. I know you ordered a pair of 12AX7's, but really you would be better off with a 12AY7 (6072A) or even a 12AT7. The reason being that the 12AX7 has an amplification factor of 100 vs the 12AY7 having a factor of 44. The sound between the two isn't really that different, but the lower amplification factor prevents the tube from saturating the transformer with loud or fast transient signals.
The other problem with this mic is that they use both halves if the twin triode tube. The first half is the main amp stage and the second is used as a cathode follower to lower the impedance output of the tube. This means they can use a cheaper transformer, which can also degrade the sound quality.
One other thing I've discovered is that the 3 layer grill seems to impede the midrange and probably causes a time-smear of the high end. I improved mine by removing the inner 2 layers of screen. This can be difficult and should only be attempted if you know what you're doing. Otherwise, leave it alone.
The biggest flaw of this mic is the capsule. It could be better, like a Peluso 34mm or even a 797 dual diaphragm.
Like I said, it'll do well on a lot of things, but with a few improvements it could really rival a high-end mic.
“Build a man a fire and he'll be warm for a day. Set him on fire and he'll be warm for the rest of his life."
Old 09-27-2005
Newbie
I chose the Ei 12AX7 tubes at the recommendation of the tech at The Tube Store.com.
The main purpose of that mic is to record vocals (namely my own voice) can it do well for that purpose?
I've read somewhere that swapping the op-amps in the Tube MP will do more for the overall sound than swapping the tube, but at this stage I am considering parting with the Tube MP (and perhaps even the Apex 435 - I DI all instruments, the voice is the only thing I need a mic for) for an improved mic preamp.
I once owned this dual channel solid state Mic preamp that was hailed by most as the best thing since sliced bread (I forget the name) , some of them from this very message board, however it was so static-ey it ended up in a trade for another piece of gear or other ...
For my purchase of the Apex you pretty much have gathered my budget is limited, so I can't afford the high-end gear ...
Old 09-27-2005
PhilGood's Avatar
Juice Box Hero
Well, the guy doesn't know much about mics.
Depends on what the vocals are like and if they will work with the mic. Its very personal.
There are some mods to toob pres that work OK. I did one for a Bellari 105 that turned out great!! I haven't heard the finished mod for the Tube MP, but since its a starved plate design the op amp change will be the biggest improvement, especially if they are burr browns.
Old 09-28-2005
The Garage The Garage is offline
Senior Member
The Garage is on a distinguished roadThe Garage is on a distinguished roadThe Garage is on a distinguished roadThe Garage is on a distinguished roadThe Garage is on a distinguished roadThe Garage is on a distinguished roadThe Garage is on a distinguished roadThe Garage is on a distinguished roadThe Garage is on a distinguished road
i would hold on to the apex 435. i've found it pretty useful on a number of INSTRUMENTS (not vocals). you may want to record acoustically and not d.i. at some point and this mic will come in handy.
All the World's Tube Microphones PART TWO Bambi Busboom Microphones 5 09-06-2006 13:16
FS: Rode NT1000, MXL 960 Tube Mic and more!... kidvybes Free Ads for Music / Recording Equipment 7 07-10-2005 08:05
6072a vs 12ax7 in tube mic Bob's Mods Microphones 5 04-06-2005 07:39
Tube in Mic or Preamp? MercyfullMusic Microphones 2 11-08-2001 19:26
A first look at the new Studio projects T3 Tube mic Dot Microphones 40 07-08-2001 08:41
