Go Back   Home Recording > Equipment Forums > Microphones
Reply    Audiofanzine Microphone Microphone News Microphone Medias Microphone Tests Microphone Articles Microphone User Reviews Microphone Classifieds Ads
Old 09-27-2005
Relakst Relakst is offline
Newbie
Relakst is on a distinguished road
Dropped CAD E300 2
I just received a "slightly used" CAD and, alas, it had to have been dropped. The basket is bent, there is a tiny dent where the basket hit the mic case, and the capsule is leaning slightly to the side of the dent. Granted, the capsule is rubber mounted and probably could be straightened.
I haven't had a chance to try it yet. What sort of damage could have occured? Could it have messed up the capsule's ability to perform normally?
Worried
Old 09-27-2005
MadAudio's Avatar
MadAudio MadAudio is offline
Damned if I do
MadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond repute
I'd be worried, too. That doesn't sound good. Do you think it was dropped in shipment or sent that way? Did the seller say it was working? If it was me, I'd be nervous to test it, fearing I'd cause more damage.
Newest endeavor: Playing drums in a live band version of 7 Door Sedan's music.
"Do yourself a favour just shut up, read up then put up." --muttley600
Old 09-27-2005
Newbie
Supposed to have been "mint". How could trying it out cause more damage?
Old 09-27-2005
MadAudio's Avatar
Damned if I do
Well since condensor mics use phantom power, there's a slight possibility of frying the capsule if there's a short somewhere. BTW, I have the original version of the E300, and that one uses phantom in conjunction with an internal battery. Is the E300/2 the same? I haven't actually seen one.
Old 09-27-2005
Newbie
Yes, it is the same setup. So I will make sure it has some charge before I try it out. You can see it at http://www.cadmics.com/e300_2.htm. I'll use my AT4050 to compare.
Old 09-27-2005
MadAudio's Avatar
Damned if I do
Wow, that's a lot more compact than mine! Good luck!
Old 09-27-2005
Newbie
Weighs a ton, though. Gonna haff ta use the boat anchor on the other end of the boom... which is prolly why it was dropped in the first place... DAMN!
Old 09-27-2005
PhilGood's Avatar
PhilGood PhilGood is offline
Juice Box Hero
PhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond repute
I think the only damage that could happen would be if the shock of the drop caused the diaphragm to stretch or come loose. Then it would just sound like pooh! The capsules usually are charged to about 60-70 volts in a tube mic, depending on how its biased. On 48v phantom, its probably there or lower so the voltage really couldn't hurt it. All the solid state components really can't be damaged by shock so the only real damage would be mechanical.
Does the capsule move when you turn the mic?
“Build a man a fire and he'll be warm for a day. Set him on fire and he'll be warm for the rest of his life."
Old 09-27-2005
Newbie
No, it doesn't move. I was able to make it straight very easily with my fingers. I guess it was made to move a bit to take some shock.
Old 09-27-2005
PhilGood's Avatar
Juice Box Hero
I think its probably safe to try it.
Old 09-28-2005
versimilitude's Avatar
versimilitude versimilitude is offline
Newbie
versimilitude is infamous around these parts
*cough* *crap* *cough *cough*
another "quality" post you're nearly up to 3,500 now
  #12
Old 09-28-2005
MadAudio's Avatar
Damned if I do
Wouldn't it be better to correct me than belittle me? Please tell me why I'm wrong - I'm always learning.
  #13
Old 09-28-2005
timboZ's Avatar
timboZ timboZ is offline
Band-Aid®
timboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond repute
Post #1 from versimilitude...
And I give you and A+ and a gold star for effort
15 posts out of 42 and you only replied to yourself 7 times you're definitely cominginfirst
Post #2 from versimilitude...
Post #3 from versimilitude...
I am an A-hole. I know nothing.
Christian and Ted are my lovers.
V-tude all of your quality posts have helped me out.
Go away A-hole.
WARNING:
THIS POST DOESN'T CONTAIN ANYTHING HELPFUL
http://www.myspace.com/veritasrs
__________________________________________________________________________________________________
  #14
Old 09-28-2005
PhilGood's Avatar
Juice Box Hero
What the....???
Well, fuckadoodledo!! Who are you??
Mad, pay him no mind! I think you gave good advice! Always err on the side of caution.
  #15
Old 09-28-2005
tourettes5139's Avatar
tourettes5139 tourettes5139 is offline
ugh..........
tourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond repute
Thumbs down
Come on!!! Thats just ridiculous.
Ironic how he's the one that the aforementioned cockfag was being rude to, and he's still being nicer than most of us. Props!!
Check out my band!!
www.myspace.com/darkvelvetlaughter
GFCG Membership No:000 019
  #16
Old 09-28-2005
Newbie
Um, ya... well, anyways...END RESULT: A dropped CAD E300^2 sounds.... UNBELIEVABLE!!!! WOW! JUST......... WOW!!!*
*(don't try this at home, see dealer for details, not for the faint of heart, not necessarily as shown, not a CAD dealer, not a CAD dropper, not an argument starter, etc.)
  #17
Old 09-28-2005
MadAudio's Avatar
Damned if I do
If it's anything like the original, you will LOVE that mic for a long time. I just started using mine in conjunction with a cardioid to do mid-side micing.
ENJOY!
  #18
Old 09-28-2005
Newbie
Thanks... I couldn't be happier with the sound... as with the 4050, no need for EQ (the equipment, not the magazine*). I'd call it a more colored sound than the 4050. Or maybe the 4050 just doesn't "hear" as well. Anyways, my acoustic guitar just shimmers! And this thing is supposed to accel on vocals. I can't wait to try THAT.
I'm guessing not many people have this mic. I've seen very little on the net about it. The little I did see was very positive so that's why I bought it. Oh, and it was a quarter of the price of new in Canada! That helped.
*not an EQ editor, not a roadie
My CAD EQUITEK E-200 experience. smellyfuzz Microphones 9 01-11-2009 18:20
pair of 666s and a cad m179 eeldip Free Ads for Music / Recording Equipment 2 06-07-2004 17:07
cad e200 & e300 dragnalus Microphones 8 04-28-2002 11:40
CAD ZM-1G or CAD SM1 cjmusicman Microphones 3 12-31-2001 03:59
