Chicken or the egg?
When I'm recording my drum machine, should my signal go to the EQ -then- the compressor, or should it go to the compressor first and then the EQ?
Thanks, y'all
"You're only given a little spark of madness. You mustn't lose it!"...Robin Williams |
you can do either or. it'll work either way.
but, my philosophy is to correct before you enhance. For example, I like to use the compressor first because I like to correct excessive dynamics on the track. Then I'll use EQ to tweak the sound how I want it. If there is some weird sound, however, like a ringing noise...or low rumble, I'll EQ to correct it before I compress it, then EQ again to shape the sound. You also have to ask yourself either: Do I want to boost part of the frequency spectrum after I've just smashed it down with the compressor?.....or Do I want to smash down the frequencies I just boosted with EQ? It all depends on what you're going for.
www.redlabaudio.com |
EQ-> Compress: will exagerate the EQ. For example, if you boost 2k then compress everything, the 2k will tend to trigger the compressor more. EVERYTHING will then be turned down - making the 2k bump more noticeable. If you primarily cut with the EQ this is much less an issue. Rule of thumb is corrective EQ before compression. Why have that boomy sound you don't want anyway triggering the compressor?
Compress->EQ: This allows the EQ to be a bit more predictable- I prefer this when I have serious sculpting to do with the EQ. So use shaping EQ after compression. Or do whatever sounds best. With compression and EQ you *really* have to use your ears. Take care, Chris |
the way i go is....
corrective eq before comp (so the comp is not reacting to freq's that don't exist any more) sound altering eq after comp. (so if i'm, say, boosting the hi's the compressor isn't reacting mostly to the boost) |
Thank you,
thank you, thank you... I've been needing some help clearing that up. I've been playing live for years, but really want to record more at home with my free time. Thanks, jimbo (the "q" is silent)
| Chicken or the Egg? | the edzell | Songwriting, Singing & Vocals | 8 | 05-31-2004 12:03 |
| The Chicken or the Egg. | muzeman | The Rack | 2 | 04-24-2003 18:19 |
