Go Back   Home Recording > Equipment Forums > Guitars and Basses
Reply    Audiofanzine Guitar Guitar News Guitar Medias Guitar Tests Guitar Articles Guitar User Reviews Guitar Classifieds Ads
Old 09-24-2005
werewolf831 werewolf831 is offline
Senior Member
werewolf831 is infamous around these partswerewolf831 is infamous around these partswerewolf831 is infamous around these partswerewolf831 is infamous around these partswerewolf831 is infamous around these parts
SVT3 Pro gain setting question
In the settings section of the owners manual for the SVT3 pro, they have the tube gain and master volume turned all the way up, and then they use the gain knob to adjust the volume. Why wouldn't the manual suggest using the master volume to set the desired overall volume instead? Just always wondered about that. I'd post a pic but but the ampeg site won't load up for me tonight. Any insight to this would be helpful.
Cheers
werewolf
Old 09-24-2005
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
That will give you the cleanest sound. If you turn the master down and the gain up, you will get more distortion. SVT's are supposed to distort a bit, you will have to play with it to find your sound.
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
Old 09-25-2005
BroadRun BroadRun is offline
Newbie
BroadRun is on a distinguished road
I've owned one since 99, don't have the manual anymore. There is a peak/mute led next to the gain knob, play hard and turn gain until the peak stops lighting, or occasionally lights. The tube gain knob is useless, leave it turned all the way up, it's an Ampeg, the whole point is to get a tube sound.
The notion of turning the master wide open and use the gain for primary control sounds crazy.
Old 09-25-2005
Bassman Brad's Avatar
Bassman Brad Bassman Brad is offline
Dedicated Member
Bassman Brad is a glorious beacon of lightBassman Brad is a glorious beacon of lightBassman Brad is a glorious beacon of lightBassman Brad is a glorious beacon of lightBassman Brad is a glorious beacon of light
At one time, I would have agreed with this statement. Except that, recently, I have found myself using my own primary bass amp (a Mesa Boogie) in exactly this manner -- master set on full blast, and controlling the volume with the gain knob. I've found that this works extremely well. When I'm playing quieter sets, such as our acoustic gigs, then I have a very clean sound. When we crank it up and go to the electric gigs, then I have more distortion. And both sound appropriate for the types of material that we're doing in each setting.
Ultimately, though, it depends upon what kind of sound you're going for. If you want a cleaner sound, then the master volume should be higher than the gain knob. If you want more distortion, then it should be the other way around.
Brad
______________________________________________
“If music be the food of love, play on;”
William Shakespeare - from The Twelfth Night
Old 09-26-2005
Senior Member
Great replies everyone. Thanks for the help!
Pro Tools Question jonhall5446 Mixing / Mastering 9 08-23-2004 14:58
Pro CD Burners - Stupid *More Gain* Question mark4man The Rack 12 07-13-2004 19:06
Preamp Gain question - related to the VTB-1 and DMP3 kirkhere The Rack 8 02-23-2004 22:52
Question for gain structure / preamp experts like Blue Bear and others… Armistice The Rack 5 01-14-2004 14:33
buffer size setting for aardvark direct pro q10 bradthefattest Digital Recording & Computers 0 08-01-2003 17:25
