guitar wiring issue - plz help
i recently finished wiring my explorer type guitar, with les paul style wiring.. and it works great - *except* for the fact that there seems to be some bleedthrough between the two pickups.. ie, in neck position i still hear some bridge and vice versa... the only way to silence it completely is to turn both volumes down...
I have gotten to a point that i think it is a ground problem, but i was wondering if anyone knew where this might be coming from, ie is it too many grounds or not enough? as far as i can tell everything is hooked up properly..? could it be the pickups piercing the shield of my switch runs? are there gremlins in there? any help is appreciated before i tear it apart and completely redo it oh yeah i also have a multimeter handy if anyone can suggest measuring points to pinpoint the problem. thanks Last edited by seismetr0n; 09-23-2005 at 08:31.. |
The fabulous Naiant Mics, perfect for acoustic instruments!
If you don't have DavidK's CD, you are a loser. My tunes. Thanks! ![]() NB DA BEARS! |
if im switched to the bridge pup and i turn the vol all the way down i still hear some sound (weak but there), until i turn the neck pup all the way down, then its quiet. and vice versa for the other pup..
thanks |
EDIT: You got your reply in while I was still typing the above. Can you try what I just mentioned and see what happens? |
nope that doesnt happen... that would be if i wired it like a strat, i have it wired (mostly) properly (pup goes to middle of pot, switch comes out bottom, other end grounded with cap on it from tone pot) ..
its wired like this http://www.stewmac.com/freeinfo/I-0133.html (except switch and pup and shitched on the pot) like i said its probably a ground prob somewhere sile2001, you might want to switch yours if you want independant volume control for each pup (blend em in the middle ) thanks |
thanks everyone for trying to help... i switched it so it was wired exactly like the diagram (how yours is wired silo).. and now there is no problem, except i cant blend the pups in the neck+bridge position... oh well .. too bad... maybe it was never meant to be
silo you should stick with how yours is wired and disregard me.. ![]() stew-mac swore it was a ground problem.... i think maybe it always bleeds through and they just dont put it through gain like i do ![]() anyway thanks |
| Plz help me out here, need guitar techies! | BillyTheKid | Other Equipment and Reviews | 1 | 03-24-2005 15:54 |
| Gibson guitars: why the high cost? | amt7565 | Guitars and Basses | 83 | 05-20-2004 18:23 |
| Clipping, voice and guitar | vagabond | Recording Techniques | 8 | 08-30-2002 23:52 |
| !NEED HELP! guitar wiring not working | schnoops | Guitars and Basses | 1 | 07-11-2002 11:29 |
| Guitar wiring | Cooperman | Guitars and Basses | 3 | 11-14-2000 19:55 |
