Go Back   Home Recording > Equipment Forums > MIDI Mania
Reply    Audiofanzine Electronic-instrument Electronic-instrument News Electronic-instrument Medias Electronic-instrument Tests Electronic-instrument Articles Electronic-instrument User Reviews Electronic-instrument Classifieds Ads
Old 09-20-2005
peteuk90 peteuk90 is offline
Newbie
peteuk90 is on a distinguished road
No Sound?
Hi there, sorry if I appear thick.. just learning about MIDI!! I have a delta 1010LT sound card which is great. Just starting recording bass,guitar etc. The drummer has got an electronic drum kit which we were advised to record in midi then convert each track etc. When I plug the midi cables in and audio I hear it and it is creating notes on the screen to say it is recording a pad (snare) I have set the driver to delta card but no play back at all. It's all there except sound.
I run it on MAGIX Deluxe 2005 software.
Helpppp!!
Pete
Old 09-20-2005
mikemorgan's Avatar
mikemorgan mikemorgan is offline
panned out
mikemorgan has a reputation beyond reputemikemorgan has a reputation beyond reputemikemorgan has a reputation beyond reputemikemorgan has a reputation beyond reputemikemorgan has a reputation beyond reputemikemorgan has a reputation beyond reputemikemorgan has a reputation beyond reputemikemorgan has a reputation beyond reputemikemorgan has a reputation beyond reputemikemorgan has a reputation beyond reputemikemorgan has a reputation beyond repute
In order to get sound fromn a midi track, you have to assign that track to control a synth-module(your drum brain), or a softsynth(software midi moduLE). the midi track tells the module to play, then you monitor the sound from the module. There a lot to this, but you should do some searching on the difference between midi and audio. sorry, wish I had some links.
actually if you run a midi out from your computer to the electronic drum midi in, you should hear sound from the outputs od the drum module.
Old 09-20-2005
ssscientist's Avatar
ssscientist ssscientist is offline
Info you can use...
ssscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond repute
Here are links to two good articles on midi basics - part one and part two.
Selecting the right midi note number - as well as the right midi channel - is all there is to getting a drum sound from a module. Just adjust either the transmitter (the drummer's electronic kit) or the receiver (the drum module) until you've got the right sounds coming from the right drum.
BOSS DR-550 questions Pinky Drums and Percussion 29 08-11-2009 22:36
Mixing secrets by sonusman s_o_n_u_s_m_a_n Mixing / Mastering 261 05-14-2009 19:26
Mixing, mastering, and getting "that" sound... Mercuri Mixing / Mastering 39 01-10-2008 08:01
I think little amps sound like crap....or I am open to suggestions. mixmkr Guitars and Basses 29 05-03-2005 19:04
SMOOTH, HOMOGENOUS, EXCITING mixes... Is it possible??? Mercuri Recording Techniques 69 12-07-2002 20:05
