Go Back   Home Recording > Equipment Forums > MIDI Mania
Reply    Audiofanzine Electronic-instrument Electronic-instrument News Electronic-instrument Medias Electronic-instrument Tests Electronic-instrument Articles Electronic-instrument User Reviews Electronic-instrument Classifieds Ads
Old 09-20-2005
kevr82 kevr82 is offline
Newbie
kevr82 is on a distinguished road
General MIDI
I have recently acquired a new synth which features "General MIDI". Could some explain to me the difference between this and normal MIDI? Thanks.
Old 09-20-2005
Toki987's Avatar
Toki987 Toki987 is offline
Rock Steady
Toki987 has a reputation beyond reputeToki987 has a reputation beyond reputeToki987 has a reputation beyond reputeToki987 has a reputation beyond reputeToki987 has a reputation beyond reputeToki987 has a reputation beyond reputeToki987 has a reputation beyond reputeToki987 has a reputation beyond reputeToki987 has a reputation beyond reputeToki987 has a reputation beyond reputeToki987 has a reputation beyond repute
there is no normal midi. There was standard midi, then general midi.
Here`s link that might help you out.
http://www.midi.org/about-midi/abtmidi.shtml#protocol
" Miwk Kowz "
Kጝ: securelock
Old 09-20-2005
AlChuck's Avatar
AlChuck AlChuck is offline
Been Here, Posted That
AlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond repute
MIDI defines the protocol for messages between synths and other devices that want to "speak" to them. That is, the kinds of messages, their format, etc. One of these is the program change message, which is supposed to tell the MIDI device to change to a different patch. But it does not specify which patch numbers correspond to which particular sounds. So, Musical Instrument Manufacturer A was free to have a piano sound summoned by Patch#1 while Musical Instrument Manufacturer B could choose Patch #75 to be a piano.
After a short while, people who had made sequences based on using Synth A discovered that if they wanted their sequence to be played with similar instruments using Synth B, they would have to reassign the patches. Kind of a pain in the neck, and also somewhat confusing for newbies to understand and deal with.
From this was born an extension to the MIDI spec called General MIDI. The main thing it added was a standard set of instruments and corresponding patch numbers. So if Musical Instrument Manufacturers A and B supported GM, then both would have the acoustic piano patch mapped to Patch #1. Sequences could then be much more readily shared between people with differing synths.
Old 09-20-2005
Riverdog's Avatar
Riverdog Riverdog is offline
Registered User
Riverdog has a reputation beyond reputeRiverdog has a reputation beyond reputeRiverdog has a reputation beyond reputeRiverdog has a reputation beyond reputeRiverdog has a reputation beyond reputeRiverdog has a reputation beyond reputeRiverdog has a reputation beyond reputeRiverdog has a reputation beyond reputeRiverdog has a reputation beyond reputeRiverdog has a reputation beyond reputeRiverdog has a reputation beyond repute
Ps
AlChuck is exactly right...
However, remember that the Piano patch on Synth A and Piano Patch on Synth B may sound a little different... But it's a piano... Going from a Kurzweil K2600 to a "Casio CZ 10 dollar Sam's Club Special" will sound different...
Just an FYI
How do I hook everything together? mikara Newbies 20 09-02-2005 05:27
Midi track with Sonar & Audigy’s Interface?? carlosfl Cakewalk / Sonar Forum 6 06-25-2005 11:16
Quick Question sarkastic714 MIDI Mania 1 09-21-2004 06:21
Best Sample CD for EXS24 with General Midi Drums? GeorgeG3 Digital Recording & Computers 7 05-15-2002 11:04
Converting MIDI to WAV AndrewSales Cakewalk / Sonar Forum 38 08-21-2001 22:31
