Old 09-02-2005
SKYflyer SKYflyer is offline
Senior Member
SKYflyer has a reputation beyond reputeSKYflyer has a reputation beyond reputeSKYflyer has a reputation beyond reputeSKYflyer has a reputation beyond reputeSKYflyer has a reputation beyond reputeSKYflyer has a reputation beyond reputeSKYflyer has a reputation beyond reputeSKYflyer has a reputation beyond reputeSKYflyer has a reputation beyond reputeSKYflyer has a reputation beyond reputeSKYflyer has a reputation beyond repute
Keyboard into MR8: Line level input not working properly
http://homerecording.com/bbs/showthread.php?t=168432
Appreciate it if the users of this forum would take a look at this topic i made previously in the digital recording forum.
I didnt seem to be getting many responses from there, so i thought i would post it here also.
Thanks.
Old 09-03-2005
Rokket's Avatar
Rokket Rokket is offline
Sgt Floyd Pepper
Rokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond repute
Try turning the volume of your keyboard up, or running it through a pre amp. I know the keyboard is line level, but the amps in the keyboard might not be that great. Turn the volume of the keyboard up till it clips then back it off. You should get a good signal that way.
The hardest part of being a bartender is figuring out who is drunk, and who is just plain stupid.
Old 09-03-2005
Senior Member
Thanks for the response, rokket. I already had the keyboard turned up to maximum volume.
So you think the problem is just that the preamp in the keyboard is bad and creates a weak line level signal? I thought all line level signals were equal, and that there werent degrees of strength so to speak within them (becides like 4 db and -10 db). Am i wrong?
Old 09-03-2005
Ed Dixon Ed Dixon is offline
1K Silver Member
Ed Dixon has a reputation beyond reputeEd Dixon has a reputation beyond reputeEd Dixon has a reputation beyond reputeEd Dixon has a reputation beyond reputeEd Dixon has a reputation beyond reputeEd Dixon has a reputation beyond reputeEd Dixon has a reputation beyond reputeEd Dixon has a reputation beyond reputeEd Dixon has a reputation beyond reputeEd Dixon has a reputation beyond reputeEd Dixon has a reputation beyond repute
Some keyboards are fairly hot and others weaker. In either case you should be able to input to the MR8 without problem. Just use the trim knob until the signal is at the right level.
I have an assortment of line level gear, and each is a little different. I just adjust until it levels correctly. At that point one really does not care where the trim is set. You just want the correct signal.
Ed
Old 09-04-2005
crgl crgl is offline
Junior Member
crgl has a brilliant futurecrgl has a brilliant futurecrgl has a brilliant futurecrgl has a brilliant futurecrgl has a brilliant futurecrgl has a brilliant futurecrgl has a brilliant futurecrgl has a brilliant futurecrgl has a brilliant futurecrgl has a brilliant futurecrgl has a brilliant future
SkyFlyer:
The same thing happens to me.
I record my Alesis QS direct and always have to bring the trim up to the middle ( aprox ). It also depends on the voice you are using.
Some people here will say that you should better use a good mixer to preamplify the signal from the keyboard because the preamplifier in the Fostex MR8 is not good, but even in this case you will have to use the trim to boost it a little more before clipping.
You should always record the keyboard at max volume because, apart from getting the signal as hot as possible, it is where the keyboard signal will have the maximum signal to noise ratio.
Mic Input Vs Line In on Computers lurgan liar Newbies 19 04-27-2005 21:44
Hi-Z Input vs. Line Input SoonerFan Newbies 0 04-19-2005 11:18
cabling - compatibility issues - khz - bits - signal chain analysis ending with MR8 diogo Fostex Forum 7 03-16-2005 16:25
Mic/Line/Inst - a primer for newbies homerecor Newbies 0 03-02-2004 19:16
global disable with line input xander1369 Cubase User Forum 0 03-12-2000 16:28
