Old 09-01-2005
srsmoak srsmoak is offline
Newbie
srsmoak is on a distinguished road
Angry Tape Squeak
I'm integrating analogue into my digital recording platform and have recently acquired a Fostex A8 w. VU meter. It's been thoroughly tested and the ins and outs work. Machine seems in good shape.
Problem is that I'm having "tape" squeak. (I'm guessing it's tape.) I recorded some drum tracks a few days ago with minimal problems (most were vol and input related which I can fix on my end). Now, however, I'm trying to lay down an acoustic (on a different tape) and the tape has begun to squeak. I changed out the tape with the old one and even it squeaked. What's going on? Why would my Fostex begin squeaking? Is it the tape? Or do I need lubricant for the heads. Machine has been demaged and heads recently cleaned if this should be a factor.
chip
Old 09-01-2005
tubesrawsom's Avatar
tubesrawsom tubesrawsom is offline
BE HAPPY!
tubesrawsom will become famous soon enough
make sure your not looping any signals
Iron What?
Old 09-01-2005
MadAudio's Avatar
MadAudio MadAudio is offline
Damned if I do
MadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond repute
You meant the tape itself is making a physical squeak, correct?
What brand of tape & how old is it? Might be sticky-shed syndrome.
FYI, you do not lube heads.
Newest endeavor: Playing drums in a live band version of 7 Door Sedan's music.
"Do yourself a favour just shut up, read up then put up." --muttley600
Old 09-02-2005
Newbie
Yes, tape is squeaking. I removed tape from reels and pressed trigger so that it would run w/out tape and no squeaking. Then I put tape back on and after about 30 secs. of record it starts to squeaking.
Tape is AMPEX 456 I acquired from previous owner. It was unopened and still in shrink wrap. I now have some Quantegy 456 so perhaps (thinking it could be "old" tape) I'll try that today.
thanks.
Old 09-02-2005
MadAudio's Avatar
Damned if I do
Yeah, it's possible that it's bad tape.
Old 09-12-2005
Cave Dweller Cave Dweller is offline
Dedicated Member
Cave Dweller will become famous soon enough
perhaps the pinch roller is squeaking.
Old 09-18-2005
Beck's Avatar
Beck Beck is offline
Analog Partisan Ranger
Beck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond repute
Make sure to clean the tape path with q-tips and 90+% alcohol before you use the new tape. And I mean a really thorough cleaning with lots of cleaning sticks and alcohol.
If the old tape had sticky-shed it will leave residue behind that will continue to give you problems. Ampex 456 made before 1994 will usually be in a sticky state even if it was sealed.
-Tim
«:: «::B::» «::E::» «::C::» «::K::» ::»
"Where in the hell are the red M&M's?"
~My Lil' Sister, 1976
Old 09-18-2005
goldtopchas's Avatar
goldtopchas goldtopchas is offline
Dedicated Member
goldtopchas has a reputation beyond reputegoldtopchas has a reputation beyond reputegoldtopchas has a reputation beyond reputegoldtopchas has a reputation beyond reputegoldtopchas has a reputation beyond reputegoldtopchas has a reputation beyond reputegoldtopchas has a reputation beyond reputegoldtopchas has a reputation beyond reputegoldtopchas has a reputation beyond reputegoldtopchas has a reputation beyond reputegoldtopchas has a reputation beyond repute
Maybe an issue with the tape rubbing against a warped reel??
"Is this thing on"??????
456 or GP-9? For 1/4" 1/2track mixdown / mastering? Dr ZEE Analog Only 27 06-14-2005 06:28
Swirly sound on old tapes Ptron Mixing / Mastering 6 12-04-2004 12:36
Get rid of tape hiss? mjr Recording Techniques 16 09-26-2002 23:37
Urgent Advice With Analog Tape Copying Needed! janek Analog Only 5 02-26-2002 15:55
Need info on best way to hook up Patchbay Infinitrax The Rack 2 03-09-2001 02:42
