Midi Tracks not Synced
I assume that this has been addressed before but I can't find the answer. I am running Cubase Sx with a Roland XP-30. I am sending midi from Cubase into my Roland hoping to get multiple tracks to play simutaneously. They sound almost synced at first but then after about 3 seconds one track is fast then the other. Is there a way to fix this?
My computer is only 750 Mhz but still... midi info is not a lot of binary data.. in fact, I think that it is on the order of or less amount of data that is sent across a 55.6 kB/s modem so why is it out of sync? By the way, I only have two tracks. PS - I have an M-audio Delta 44. Any advice would be appreciated. Peter. |
Sounds like you should post this in the Cubase forum.As you stated MIDI takes hardly any resources.
Are you using the XP-30 for MIDI input? Not being familiar with Cubase,do you see the midi notes on screen and in sync? Also what type of interface are you using for MIDI? |
Sorry if this is in the wrong forum. To answer your question...
The Roland is set-up to receive midi notes from cubase. The midi interface is the roland edirol um-1. The midi notes are indeed on the screen and I placed them there manually. Not sure why the two channels are not being transmitted simultaneously but if I don't figure it out, I will have to scrap the whole thing which would be unfortunate because I am quite proud of track 1. Thanks, Peter. |
If I'm not mistaken there is no sequencer in an XP30.
I use Sonar and it's as simple as play it and replay it.Not being faniliar with Cubases MIDI implementation that's why I suggested using the Cubase forum. |
The XP30 does not have sequencing
In theory all the Cubase is doing is triggering MIDI notes - accordingly, any time sync problems must be in Cubase (I don't think the Delta or the processing abilities of the computer have anythin to do with this). I suspect that when the individual performances were recorded into Cubase there is some problem with the clock setting. I agree the answer may be in the Cubase forum (or calling Cubase tech support). |
Torment, Violent Aggression, Systematic State of Oppression. The Heretics, All Swing From The trees, Cast To Hell, With Their Disease. DARKENED |
I'm not to keen about recording the audio until your finished with your project,it defeats the purpose of having MIDI in the first place. |
| FL Studio as a MIDI sequencer? | HairWuzEre | Keyboards and Sound Modules | 1 | 10-21-2004 12:37 |
| Quick Question | sarkastic714 | MIDI Mania | 1 | 09-21-2004 06:21 |
| Need serious midi help whats the best way to do this? | puppethead | MIDI Mania | 3 | 10-09-2003 15:59 |
| Need serious midi help whats the best way to do this? | puppethead | MIDI Mania | 0 | 10-08-2003 22:00 |
| Midi drum stuff for the hard of thinking: | Alan McGuinness | Cakewalk / Sonar Forum | 3 | 12-12-2002 12:03 |
