Go Back   Home Recording > User Forums by Brand > TASCAM User Forum
Reply    Audiofanzine Tascam Tascam News Tascam Medias Tascam Tests Tascam Articles Tascam User Reviews Tascam Classifieds Ads
Old 08-25-2005
studiodrum studiodrum is offline
Dedicated Member
studiodrum is on a distinguished road
using Click Track with a 424 MkII
Hey gents!
Is there a way of hooking-up a Dr. Rhythm machine (using it as a click track) to the 424 mkII, while recording on all (4) Channels. . . ? I don't need the click to be recorded, . . .just heard through the headphone during recording as a tempo reference. . . any suggestions?
Old 08-25-2005
Blue Bear Sound's Avatar
Blue Bear Sound Blue Bear Sound is offline
Don't feed the bear......
Blue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond repute
Run the outputs of the durm machine to one of the extra input channels - monitor that channel while recording on the others.....
Old 08-25-2005
andyhix's Avatar
andyhix andyhix is offline
www.miterecords.com
andyhix has a reputation beyond reputeandyhix has a reputation beyond reputeandyhix has a reputation beyond reputeandyhix has a reputation beyond reputeandyhix has a reputation beyond reputeandyhix has a reputation beyond reputeandyhix has a reputation beyond reputeandyhix has a reputation beyond reputeandyhix has a reputation beyond reputeandyhix has a reputation beyond reputeandyhix has a reputation beyond repute
you would have to record the rhythm/click on a track, in order to get it to sync up consistantly with other instruments once you start recording them. you could do as bear suggests, but that would only work for the first track(s) you record. To add on afterwards, the click would be gone. That might work fine if you're first instrument to tape is something that the rest can key off of, like a rhythm guitar or another percussion part.
Personally, what I do, is record the click. Record 3 more tracks of keeper stuff, then record over the click with the 4th instrument. By the time you get there, you likely won't need the click anymore unless you are doing something really out there.
Old 08-31-2005
Dedicated Member
Thanks for the input guys!
Yeah, Ultimately, recording the click to its own track is the way to go~ This way you have a firm beat when recording your other tracks. . .and theirs definitely no guess work, or interpretation of the rhythm. . .
But, with only 4 tracks to work with, . . . I think what we plan to do is record the bass and drums using the click as a monitor-- This way we will have a solid rhythm track to build on, . . .
Also, what input on the 424 mkII would work best to monitor the click-track, . .and what switches should be engaged on the 424 to make this work . . .?
Thanks again for the input guys!
Old 09-02-2005
Dedicated Member
So, what would be the best inputs to use on the 424 mkII to plug the 'click machine in. . .?
Old 09-02-2005
andyhix's Avatar
www.miterecords.com
just depends what type of cable your click machine uses - assuming it has RCA outs, I would just plug it into the sub input. you could just use one of the jacks, even, since you don't need stereo for your click. Then arm (either direct or buss L/R) whatever track you want to record it on. I think that's all it takes. Just mess around with it, and you'll figure it out in no time.
adding a DBX compressor to 424 mkII. . ?? studiodrum TASCAM User Forum 6 11-20-2004 19:45
connecting click to Tascam 424 studiodrum TASCAM User Forum 1 10-24-2004 12:21
424 mkII help tree TASCAM User Forum 1 05-11-2004 22:19
Click Track problems argh!! badgerer Newbies 52 05-05-2003 10:35
click track bleeding ssseals Recording Techniques 7 03-27-2002 01:36
