Go Back   Home Recording > Equipment Forums > MIDI Mania
Reply    Audiofanzine Electronic-instrument Electronic-instrument News Electronic-instrument Medias Electronic-instrument Tests Electronic-instrument Articles Electronic-instrument User Reviews Electronic-instrument Classifieds Ads
Old 08-23-2005
pinkie's Avatar
pinkie pinkie is offline
Newbie
pinkie is on a distinguished road
M-Audio Enigma Software Troubles
with some encouragement i've decided to begin my own thread!
uh. anyhow. i'm using enigma with my recently purchased trigger finger. so, i open enigma up, piddle around with edits and whatnot, and send the data back to my trigger finger. this worked fine with notes, i customly assigned each pad a different note, and that went fine. however, whenever i assign knobs and sliders in enigma, they don't seem to get sent to the trigger finger.
if anyone could just lay down a simple step by step procedure or something, i think i'm just doing one simple thing wrong. or if anyone has any insight at all, anything will help.
thanks.
Old 08-24-2005
ssscientist's Avatar
ssscientist ssscientist is offline
Info you can use...
ssscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond repute
If you can set the notes but not the control sliders, you probably have some type of midi filtering set on the Trigger Finger itself that's not allowing the controllers to be set by external means. See if you can find that page inside the Trigger Finger.
Also, it may be a midi channel problem. Make sure the software and the unit are on the same channel.
Congratulations on starting your own thread!
Old 08-24-2005
pinkie's Avatar
Newbie
i'm assuming they're on the same channel as i can transfer certain data.
here's where i really become confused. i toyed around with it some today. i was able to set two knobs but no others. i set those two nobs to control GM Volume and GM pan, both of which are pretty mundane. i'm not sure how it worked because then i tried to add more and nothing would send. i'm just very confused.
Old 08-26-2005
-=¤willhaven¤=- -=¤willhaven¤=- is offline
Dedicated Member
-=¤willhaven¤=- will become famous soon enough
Be careful with inputting the settings. It never wants to keep the settings if you double click, enter a number, then click off. I think you have to physically click [Enter] to make a setting stick.
I ran through some buttons quicky and was pissed when it didn't work. I looked at the settings on that pad again and saw that they were all at the default value. Bah.
HOME-RECORDING Software dayslikefriday Newbies 14 06-11-2005 06:14
help with audio and computer software muzteach Recording Techniques 11 09-14-2003 10:24
Volume question. badgas Recording Techniques 27 04-08-2002 07:09
looking for audio editing software that will do these things yfedee Newbies 2 03-15-2002 13:47
Dithering darnold Mixing / Mastering 27 12-13-2001 21:29
