Midi Event and Message DataBase
How can i make a Midi Database?
How can i make a Midi Event Database? How can i Make a Midi Messages DataBase? Is Midi Sequencing Midi events? midi messesage, I just want the Note on and off message what are they called? |
Midi Real time editing how
How do i Edit midi messages,control messages, program messages, system messages, tempo messages, midi channels in real time? trying to edit them in real time Would i need about 20 midi filters on different Midi Channels? Where can i buy some SMF hard drives with midi inputs ports going to a hard drive with a Cd rom? Recording SMF midi messages,control messages, program messages, system messages, tempo messages, midi channels in real time files in real time on different hard drives with a midi input ports i need where can i buy them? |
a midi message cannot be "edited" in real time. You must accept the fact that you're just not fast enough HAL ...
" Miwk Kowz " Kጝ: securelock Last edited by Toki987; 08-22-2005 at 00:20.. |
a midi message cannot be "edited" in real time. why not?
Walters
What's a SMF Hard Drive? What does it have to do with M1D1? Can you do M1D1 in 0,1,0,1? Do you use Automation to do M1D1? I think I'm getting the hang of this... ![]()
http://www.myspace.com/tazonmyspace
http://www.myspace.com/divercity07 http://www.myspace.com/bigwillz24 Help! I've been censored and I can't get up! ![]() |
when the midi message is sent from the controller, you cannot stop the data, edit it and let it go along its way to the synth in real time.You have to generate new data and send it. The data is simple digital information, kinda like switches that are in a positive or a negative state, there is no in between. It all happens near the speed of light.
This may help you. http://www.midi.org/
" Miwk Kowz " Kጝ: securelock Last edited by Toki987; 08-22-2005 at 01:54.. |
What about using like 10 midi filters set to different parameters,channels?
to filter out the messages in real time? |
Hmmm...
I'm still wondering why you're wanting to do this?
MIDI is a protocol that sends digital information in a string to your MIDI gear... Are you trying to filter out something that's not working in your system? The only real way to "edit" MIDI informaiton in "real time" would be to send something like a patch change manually from a keyboard into your system while it's in record mode - Or as I "THINK" you said - place a filter to filter our certain MIDI information as it is played back... But it would still have to go into your sequencer somehow... |
Dude don't try and answer walters questions with a real answer he isn't looking for one. Look at his prevoius post. Then look at those three red chicklets hes got. He didn't get them for nothing.
Dang...
You're right man...
I'm just a sucker I guess... Thanks for the heads up... |
Hear you are Walters read this reply and get back to someone else
RealTime Category Messages Each RealTime Category message (ie, Status of 0xF8 to 0xFF) consists of only 1 byte, the Status. These messages are primarily concerned with timing/syncing functions which means that they must be sent and received at specific times without any delays. Because of this, MIDI allows a RealTime message to be sent at any time, even interspersed within some other MIDI message. For example, a RealTime message could be sent inbetween the two data bytes of a Note On message. A device should always be prepared to handle such a situation; processing the 1 byte RealTime message, and then subsequently resume processing the previously interrupted message as if the RealTime message had never occurred. For more information about RealTime, read the sections Running Status, Ignoring MIDI Messages, and Syncing Sequence Playback. Running Status The MIDI spec allows for a MIDI message to be sent without its Status byte (ie, just its data bytes are sent) as long as the previous, transmitted message had the same Status. This is referred to as running status. Running status is simply a clever scheme to maximize the efficiency of MIDI transmission (by removing extraneous Status bytes). The basic philosophy of running status is that a device must always remember the last Status byte that it received (except for RealTime), and if it doesn't receive a Status byte when expected (on subsequent messages), it should assume that it's dealing with a running status situation. A device that generates MIDI messages should always remember the last Status byte that it sent (except for RealTime), and if it needs to send another message with the same Status, the Status byte may be omitted. Let's take an example of a device creating a stream of MIDI messages. Assume that the device needs to send 3 Note On messages (for middle C, E above middle C, and G above middle C) on channel 0. Here are the 3 MIDI messages to which I'm referring. 0x90 0x3C 0x7F 0x90 0x40 0x7F 0x90 0x43 0x7F Notice that the Status bytes of all 3 messages are the same (ie, Note On, Channel 0). Therefore the device could implement running status for the latter 2 messages, sending the following bytes: 0x90 0x3C 0x7F 0x40 0x7F 0x43 0x7F This allows the device to save time since there are 2 less bytes to transmit. Indeed, if the message that the device sent before these 3 also happened to be a Note On message on channel 0, then the device could have omitted the first message's Status too. Now let's take the perspective of a device receiving this above stream. It receives the first message's Status (ie, 0x90) and thinks "Here's a Note On Status on channel 0. I'll remember this Status byte. I know that there are 2 more data bytes in a Note On message. I'll expect those next". And, it receives those 2 data bytes. Then, it receives the data byte of the second message (ie, 0x40). Here's when the device thinks "I didn't expect another data byte. I expected the Status byte of some message. This must be a running status message. The last Status byte that I received was 0x90, so I'll assume that this is the same Status. Therefore, this 0x40 is the first data byte of another Note On message on channel 0". Remember that a Note On message with a velocity of 0 is really considered to be a Note Off. With this in mind, you could send a whole stream of note messages (ie, turning notes on and off) without needing a Status byte for all but the first message. All of the messages will be Note On status, but the messages that really turn notes off will have 0 velocity. For example, here's how to play and release middle C utilizing running status: 0x90 0x3C 0x7F 0x3C 0x00 <-- This is really a Note Off because of 0 velocity RealTime Category messages (ie, Status of 0xF8 to 0xFF) do not effect running status in any way. Because a RealTime message consists of only 1 byte, and it may be received at any time, including interspersed with another message, it should be handled transparently. For example, if a 0xF8 byte was received inbetween any 2 bytes of the above examples, the 0xF8 should be processed immediately, and then the device should resume processing the example streams exactly as it would have otherwise. Because RealTime messages only consist of a Status, running status obviously can't be implemented on RealTime messages. System Common Category messages (ie, Status of 0xF0 to 0xF7) cancel any running status. In other words, the message after a System Common message must begin with a Status byte. System Common messages themselves can't be implemented with running status. For example, if a Song Select message was sent immediately after another Song Select, the second message would still need a Status byte. Running status is only implemented for Voice Category messages (ie, Status is 0x80 to 0xEF). A recommended approach for a receiving device is to maintain its "running status buffer" as so: Buffer is cleared (ie, set to 0) at power up. Buffer stores the status when a Voice Category Status (ie, 0x80 to 0xEF) is received. Buffer is cleared when a System Common Category Status (ie, 0xF0 to 0xF7) is received. Nothing is done to the buffer when a RealTime Category message is received. Any data bytes are ignored when the buffer is 0. Syncing Sequence Playback A sequencer is a software program or hardware unit that "plays" a musical performance complete with appropriate rhythmic and melodic inflections (ie, plays musical notes in the context of a musical beat). Often, it's necessary to synchronize a sequencer to some other device that is controlling a timed playback, such as a drum box playing its internal rhythm patterns, so that both play at the same instant and the same tempo. Several MIDI messages are used to cue devices to start playback at a certain point in the sequence, make sure that the devices start simultaneously, and then keep the devices in sync until they are simultaneously stopped. One device, the master, sends these messages to the other device, the slave.The slave references its playback to these messages. The message that controls the playback rate (ie, ultimately tempo) is MIDI Clock. This is sent by the master at a rate dependent upon the master's tempo. Specifically, the master sends 24 MIDI Clocks, spaced at equal intervals, during every quarter note interval.(12 MIDI Clocks are in an eighth note, 6 MIDI Clocks in a 16th, etc). Therefore, when a slave device counts down the receipt of 24 MIDI Clock messages, it knows that one quarter note has passed. When the slave counts off another 24 MIDI Clock messages, it knows that another quarter note has passed. For example, if a master is set at a tempo of 120 BPM (ie, there are 120 quarter notes in every minute), the master sends a MIDI clock every 20833 microseconds. (ie, There are 1,000,000 microseconds in a second. Therefore, there are 60,000,000 microseconds in a minute. At a tempo of 120 BPM, there are 120 quarter notes per minute. There are 24 MIDI clocks in each quarter note. Therefore, there should be 24 * 120 MIDI Clocks per minute. So, each MIDI Clock is sent at a rate of 60,000,000/(24 * 120) microseconds). The master needs to be able to start the slave precisely when the master starts. The master does this by sending a MIDI Start message. The MIDI Start message alerts the slave that, upon receipt of the very next MIDI Clock message, the slave should start the playback of its sequence. In other words, the MIDI Start puts the slave in "play mode", and the receipt of that first MIDI Clock marks the initial downbeat of the song (ie, MIDI Beat 0). What this means is that (typically) the master sends out that MIDI Clock "downbeat" immediately after the MIDI Start. (In practice, most masters allow a 1 millisecond interval inbetween the MIDI Start and subsequent MIDI Clock messages in order to give the slave an opportunity to prepare itself for playback). In essense, a MIDI Start is just a warning to let the slave know that the next MIDI Clock represents the downbeat, and playback is to start then. Of course, the slave then begins counting off subsequent MIDI Clock messages, with every 6th being a passing 16th note, every 12th being a passing eighth note, and every 24th being a passing quarter note. A master stops the slave simultaneously by sending a MIDI Stop message. The master may then continue to send MIDI Clocks at the rate of its tempo, but the slave should ignore these, and not advance its "song position". Of course, the slave may use these continuing MIDI Clocks to ascertain what the master's tempo is at all times. Sometimes, a musician will want to start the playback point somewhere other than at the beginning of a song (ie, he may be recording an overdub in a certain part of the song). The master needs to tell the slave what beat to cue playback to. The master does this by sending a Song Position Pointer message. The 2 data bytes in a Song Position Pointer are a 14-bit value that determines the MIDI Beat upon which to start playback. Sequences are always assumed to start on a MIDI Beat of 0 (ie, the downbeat). Each MIDI Beat spans 6 MIDI Clocks. In other words, each MIDI Beat is a 16th note (since there are 24 MIDI Clocks in a quarter note, therefore 4 MIDI Beats also fit in a quarter). So, a master can sync playback to a resolution of any particular 16th note. For example, if a Song Position value of 8 is received, then a slave should cue playback to the third quarter note of the song. (8 MIDI beats * 6 MIDI clocks per MIDI beat = 48 MIDI Clocks. Since there are 24 MIDI Clocks in a quarter note, the first quarter occurs on a time of 0 MIDI Clocks, the second quarter note occurs upon the 24th MIDI Clock, and the third quarter note occurs on the 48th MIDI Clock). A Song Position Pointer message should not be sent while the devices are in play. This message should only be sent while devices are stopped. Otherwise, a slave might take too long to cue its new start point and miss a MIDI Clock that it should be processing. A MIDI Start always begins playback at MIDI Beat 0 (ie, the very beginning of the song). So, when a slave receives a MIDI Start, it automatically resets its "Song Position" to 0. If the master needs to start playback at some other point (as set by a Song Position Pointer message), then a MIDI Continue message is sent instead of MIDI Start. Like a MIDI Start, the MIDI Continue is immediately followed by a MIDI Clock "downbeat" in order to start playback then. The only difference with MIDI Continue is that this downbeat won't necessarily be the very start of the song. The downbeat will be at whichever point the playback was set via a Song Position Pointer message or at the point when a MIDI Stop message was sent (whichever message last occurred). What this implies is that a slave must always remember its "current song position" in terms of MIDI Beats. The slave should keep track of the nearest previous MIDI beat at which it stopped playback (ie, its stopped "Song Position"), in the anticipation that a MIDI Continue might be received next. Some playback devices have the capability of containing several sequences. These are usually numbered from 0 to however many sequences there are. If 2 such devices are synced, a musician typically may set up the sequences on each to match the other. For example, if the master is a sequencer with a reggae bass line for sequence 0, then a slaved drum box might have a reggae drum beat for sequence 0. The musician can then select the same sequence number on both devices simultaneously by having the master send a Song Select message whenever the musician selects that sequence on the master. When a slave receives a Song Select message, it should cue the new song at MIDI Beat 0 (ie, reset its "song position" to 0). The master should also assume that the newly selected song will start from beat 0. Of course, the master could send a subsequent Song Position Pointer message (after the Song Select) to cue the slave to a different MIDI Beat. If a slave receives MIDI Start or MIDI Continue messages while it's in play, it should ignore those messages. Likewise, if it receives MIDI Stop messages while stopped, it ignores those. Ignoring MIDI Messages A device should be able to "ignore" all MIDI messages that it doesn't use, including currently undefined MIDI messages (ie Status is 0xF4, 0xF5, 0xF9, or 0xFD). In other words, a device is expected to be able to deal with all MIDI messages that it could possibly be sent, even if it simply ignores those messages that aren't applicable to the device's functions. If a MIDI message is not a RealTime Category message, then the way to ignore the message is to throw away its Status and all data bytes (ie, bit #7 clear) up to the next received, non-RealTime Status byte. If a RealTime Category message is received interspersed with this message's data bytes (remember that all RealTime Category messages consist of only 1 byte, the Status), then the device will have to process that 1 Status byte, and then return to the process of skipping the initial message. Of course, if the next received, non-RealTime Status byte is for another message that the device doesn't use, then the "skip procedure" is repeated. If the MIDI message is a RealTime Category message, then the way to ignore the message is to simply ignore that one Status byte. All RealTime messages have only 1 byte, the Status. Even the two undefined RealTime Category Status bytes of 0xF9 and 0xFD should be skipped in this manner. Remember that RealTime Category messages do not cancel running status and also could be sent interspersed with some other message, so any data bytes after a RealTime Category message must belong to some other message. ![]() |
| Is Event out of business? | jamie_drum | Other Equipment and Reviews | 8 | 05-20-2005 13:15 |
| Sawplus | John Sayers | Digital Recording & Computers | 9 | 07-20-2000 19:59 |
| Tannoy vs. Event (battle of the century) | HAWLK | Mixing / Mastering | 23 | 12-05-1999 15:08 |
