34B Capstan Motor Lube and Cold Solder Joints
Greetings everyone!
This afternoon, my 34B's capstan motor began making a squeaking sound. I was about to oil it, but seeing that a certain type of oil from Tascam is mentioned in the manual, but not seeing any other info. about the oil, I'm taking a guess and thinking that this is light machine oil, like one would use for other motors, etc. Is this correct? Now to find where to put the oil... no mention of that appears obvious in the owner's/service manual. Needless to say, I'm not using it until I stop the squeak, lest the squeak turn into a bigger problem. ... and after the fun of some recent problems with more cold solder joints making themselves apparent, I don't feel like any more problems with this deck for a while. Are cold solder joints on the motherboard fairly routine for these machines? A while back, I did some disassembly, removed the motherboard, resoldered some cold solder joints (intermittent... what fun!), then to be on the safe side, also resolded some other joints that appeared questionable. Some that I missed became intermittent and had to be resoldered this weekend. Of course, this deck was way out of alignment when I bought it... it was like someone gave a monkey some screwdrivers and sat the monkey in front of the tape deck with the trim-pots and head stack exposed! All channels, both sync and repro heads! ...and the back of the motherboard was coated with some dark substance and what looked like cat hair... who knows what horrors this machine's been subjected to in the past. Lots of clean-up time, a new capstan belt and roller, etc. were needed, but it seems to be a rather nice deck. Just beware of e-bay ads stating that something is in great working condition! Oh yeah... one more thing, when removing or replacing the front panel, be very careful with the vacuum fluoescent display... I broke the tip off of mine, letting air into it, turning the display white, and had to order a new tape counter display from Tascam... not cheap! |
this was the 34B from hell?
a.k.a. Davemania! Beatles and other Classic Rock covers!! Yeah, Yeah, Yeah!!! 637 songs by 191 bands.
Sewing machine oil or 3-in-one oil is just right. A great place to get a motor oiling syringe is from theteacman on eBay.
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=5800987345 He'll send you a nice syringe and instructions for only $5.95. A nice fellow and very helpful. -Tim ![]()
«:: «::B::» «::E::» «::C::» «::K::» ::» "Where in the hell are the red M&M's?" ~My Lil' Sister, 1976 |
34B and possibly bent reel motor shaft
reassembling and repairing a 34B though... still more to learn... like calibrating for wow and flutter. Is a special wow & flutter test tape truly needed? Now, for more fun with this great find from e-bay... Tonight I set out to find out why the reels don't wind evenly and why the left reel wobbles somewhat. Swapping reel tables shows that they're not the problem. If I hold a piece of paper against the bare shaft while it spins, near the top of the shaft, a slight tapping sound of the shaft against the paper can be heard. I'm thinking that this may possibly be a bent shaft... something I don't like the thought of. Perhaps I can fit some sort of shim between the flange and the reel table to correct this. If Tascam wanted $50 for that little counter display, and over $20 for a pinch roller, I hate to think what a motor costs. A machine shop probably won't be any less expensive. ![]() There don't seem to be any adjustments for this; the flange wobbles slightly on the shaft when the set screws are loosened, but no adjusting that seems to make any difference. I'll try repositioning it a few more times, since there's one flat area on the shaft... just maybe that will work. Has anyone else here run into a problem like this? Suggestions? (besides stick it back on e-bay) |
something called "turbine oil" in the hardware store... it was the only light machine oil they had, everything else had various additives that I didn't want. The capstan motor and the capstan assembly above the flywheel are now quiet. That syringe may be quite useful, since, even though I was careful not to use much oil, I still used a little too much on some of the rollers since a little oil splattered on a blank tape, not a good thing to happen. |
| Does anyone know how to solder cables? | Sagar | Studio Building & Display | 53 | 11-16-2007 22:28 |
| Soldering Cables | scottn5388 | Other Equipment and Reviews | 21 | 03-26-2003 11:26 |
