Old 08-20-2005
alexq alexq is offline
Newbie
alexq is on a distinguished road
Tascam 388 motor troubles?
Hi -- this group looks like the right place to post this.
I have a Tascam 388, which I used a lot a few years ago but since then has been sitting not doing much (I occasionally used it as a mixer but not as a tape device).
I recently dug out my old tapes to remaster them, and I loaded up the 388 as best as I remembered (and confirmed according to the manual), but when I push play/rewind/anything, the motors don't do anything, and the light above the button I pushed is simply solid...
I seem to remember this happening before but I can't remember if it really did, and what to do about it - or do you think the capstan motor is in trouble? When I wind the tape, or even lift those things up that you wind it through, I don't hear a motor starting up....
Thanks for any help!!
-Alex
Old 08-21-2005
The Ghost of FM's Avatar
The Ghost of FM The Ghost of FM is offline
French Mofo
The Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond repute
You might want to firstly check the motor fuses by removing the top panel above the vu meters to see if any are blown.
Cheers!
Old 08-21-2005
Herm's Avatar
Herm Herm is offline
1K Silver Member
Herm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond repute
Tascam had some problems with belts that would get sticky like glue and attach them selves to the capstan pulley and the motor shaft.
They will lock up the whole thing and can burn your motor up.
Check and see if you can turn the capstan stub with you finger and see if it turns if not then your belt is messed up. But I would still pull the bottom off of the machine and check the belt that way also.
And like Jeff said check the fuse. If the fuse is blown take the bottom off and check the belt before you just change the fuse and turn it back on.
Old 08-21-2005
Newbie
Whoops- well, I didn't get a chance to do what you suggested first before I changed the fuse - but here's what I did:
I checked the fuse - indeed, the fuse was blown. In fact, I think two were. I replaced them, and now it rewinds and fast forwards - and if I listen closely, I can hear the motor start up when I load the tape.
However, when I press play, everything clicks into place, but nothing moves.
When I try and manually spin the capstan, it does move - but it's got a heavy motion to it - hard to start up, rolls for a while.
I suppose this all points to the belt?
Thanks again!
Old 08-21-2005
jpmorris's Avatar
jpmorris jpmorris is offline
Tape Wolf
jpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond repute
I don't know these machines, but assuming they're like the TSR, Model 32 and Fostex A8, the capstan is actually a large, heavy flywheel. It is driven by a small motor next to it using a belt that generally goes around the rim of the flywheel.
I'd check the belt to make sure it hasn't snapped or come off or something, and if possible, try to start the machine with the front cover off and the belt removed so you can establish whether the capstan drive motor is turning or not. I don't know how easy that would be on a 388 given that it has a lid and all.
Old 08-21-2005
Herm's Avatar
1K Silver Member
Its a peice of cake to check and change the belt on a 388. The worst part is taking all of the screws out of the bottom.
Old 08-21-2005
Newbie
Yes! It is the belt! It's, as they say, as loose as a goose...
I'm guessing a hardware store might be the place to get a new one? Or does someone have another suggestion?
Thanks for the help!
Old 08-22-2005
Beck's Avatar
Beck Beck is offline
Analog Partisan Ranger
Beck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond repute
Tascam Part# 5800698201 (capstan drivebelt)
Tascam Parts
parts@tascam.com
(323) 727-4840
-Tim
«:: «::B::» «::E::» «::C::» «::K::» ::»
"Where in the hell are the red M&M's?"
~My Lil' Sister, 1976
Old 10-01-2005
Newbie
hi all - i'm back (and hoping this thread is still getting read)
the replacement belt seems to work alright.. but there's still something fishy going on...
when i press play, everything is wobbly - the speed is not constant, it's variable and slower than it should be. the two things on either side that move up and down and spin with the tape bounce up and down a lot...
i _think_ it's a tension problem... in fact, if i manually spin the right reel myself to pick up the slack, everything plays fine....
it doesn't quite make sense to me though - any suggestions?
Old 10-01-2005
A Reel Person's Avatar
A Reel Person A Reel Person is offline
It's Too Funky in Here!!!
A Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond repute
Arrow ...
Make sure the tape you're using is brand new and free of sticky shed. Any uneven drag on the tape path might cause this. Also clean the heads and tape guides very well, until they're spotless.
The worst case of this issue might be related to unstable servos, due possibly to maladjustment of the servo section, or worse yet, a reel motor drive transistor that's gone flakey (oscillating) & may be on the verge of failing.
You have to verify the tape and clean the tape heads/path before suspecting any other internal malfunction.
Beatles and other Classic Rock covers!! Yeah, Yeah, Yeah!!!
637 songs by 191 bands.
Old 10-01-2005
Newbie
OK, i tried that.. but i think i've figured out the issue...
but i may not have - that's where you guys come in..
the capstan seems to be three pieces. the big one that's attached with the drive belt to the motor, a long metal stick that's what comes in contact with the tape itself, and a washer thing in on that (rubber one side, metal on the other? or it could be black plastic).
the long metal stick is NOT tight in the big circle piece.. in fact, it's very loose. and once you hit PLAY, the big piece keeps spinning, but the long metal stick is completely still.
there seem to be two black circles on the big circle piece that MIGHT have something to do with tightening around the metal stick, but i'm not sure..
suggestions .... .. please?
My new TASCAM 388 + LOTS of pictures!! cjacek Analog Only 86 08-19-2008 13:12
Tascam 388 manual as .pdf burok TASCAM User Forum 21 09-16-2006 14:00
Link a Tascam 424 and 388 carquinez Recording Techniques 10 06-16-2005 12:37
Tascam 388 and Not enough tracks SwanSong Analog Only 8 12-29-2004 01:13
Tascam 388 vs. Tascam MSR-16 themaddog Analog Only 5 10-18-2004 14:05
