Go Back   Home Recording > Equipment Forums > Drums and Percussion
Reply    Audiofanzine Drum Drum News Drum Medias Drum Tests Drum Articles Drum User Reviews Drum Classifieds Ads
Old 08-19-2005
RyanHubris RyanHubris is offline
Junior Member
RyanHubris is on a distinguished road
Kick drum help
I'm having a lot of trouble getting a really solid kick drum sound. I'm using a AKG D122 going into mixer into delta 1010 into sonar. I think my main problem is placement, because the kick sounds great to my ear. I took off the far head and removed the pillow I had inside and got little improvement, but I can still tell something is missing.
Any suggestions? Any placement tips or anything I'm missing would be greatly appreciated. Thanks!
Old 08-20-2005
Halion's Avatar
Halion Halion is offline
1K Silver Member
Halion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond repute
How are you placing it then
Old 08-20-2005
loki loki is offline
Newbie
loki is on a distinguished road
from what i understand, it's best to use a resonant head with an off-center hole and stick the 112 inside a few inches. keeping the muffling inside the drum would be a good idea too because you'll hear a lot of sustained bass frequences without it and the 112 will really highlight them.
Old 08-20-2005
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
A lot of this depends on your idea of a solid kick sound, the kick drum and the type of heads and tuning.
We need to know what you are going for, (style of music might help) what you have tried, and why that wasn't doing it for you.
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
Old 08-20-2005
Junior Member
The style is basic rock and roll (think that Led Zepplin sound!). Nothing death metal or hardcore or anything. No double kickers. The bass drum is a Ludwig Accent with an Aquarian Super Kicker II head.
Old 08-20-2005
Farview's Avatar
If you are literally talking Zepplin, what is missing is most likely the room mic. That was a big part of that sound.
Jay Walsh
Old 08-20-2005
Tim Brown's Avatar
Tim Brown Tim Brown is offline
Why 2K?
Tim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond repute
If that's the case - try this, put the resonant head back on -WITHOUT any muffling inside it. Tune the resonant head up tight say... at least 2 "tight" turns of the tension rods to begin, and lay a blanket in front of the kick LIGHTLY touching the head. Slowly bring the tension of the batter head(the side you play on) up, and take "test" recordings at each tuning.
Bonham used no muffling inside the drum, and the drum was tuned fairly tight - especially the resonant head... then mic the drum from about 12" or so in front of the drum, and aimed about "beater" height.
Tim
Old 08-20-2005
dr.colossus's Avatar
dr.colossus dr.colossus is offline
Force of Nature
dr.colossus is a jewel in the roughdr.colossus is a jewel in the roughdr.colossus is a jewel in the rough
I always thought "bonham" tuning was tight batter head and loose reso. I agree in terms of muffling, for this sound I wouldn't use any at all, but start with a bit to tame some of those resonant feqs.
Personally, I find bass drum one of the hardest things to mix. Quite often I find if i get the b-drum sounding nice in mix, when I solo it its nothing like anything I'd every expect to be happy with.
Its also a good idea to d/l some of those bonham out-takes that were floating around the bb and use them as reference when mixing your drums.
Old 08-20-2005
Tim Brown's Avatar
Why 2K?
No, he tuned all of his resonant heads really high - almost "snare drum" high. Jeff Ocheltree, Bonham's drum tech, has an audio file online where he describes how Bonahm tuned the drums.
http://www.drummerworld.com/Videos/johnbonhamtech.html
Below the video is an audio file of Ocheltree talking about What Bonzo used and how he tuned.
This is from his DVD on Drum Teching called "Trust Your Ears".
Tim
Old 08-20-2005
Junior Member
Thanks a bunch everyone for the replies and tips.
"Personally, I find bass drum one of the hardest things to mix. Quite often I find if i get the b-drum sounding nice in mix, when I solo it its nothing like anything I'd every expect to be happy with."
This perfectly describes how I feel. Hopefully if I keep messing around I can get it to sound better in the mix.
Old 08-20-2005
jmorris's Avatar
jmorris jmorris is offline
livebandrecordings.com
jmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond repute
My 2 cents:
I have the beater head loose. I most cases use an older AKG D20 just inside the 5" hole about 1 "at 3 o'clock pointed aty the beater. The front head I have also loose. Blanket inside against the beater head,not touching the res. head at all . I have found that I can get more or less resonance by adjusting the tension of res. head. I however do not like this setup with my D112. For the D 112, I use same setup EXCEPT...I put the mic in about 6 " from beater, off axes a bit and EQ to taiste. I bost about 3800hz and cut 300hz. It is what works for my set.
  #12
Old 08-21-2005
Bdrum's Avatar
Bdrum Bdrum is offline
Dedicated Member
Bdrum is a glorious beacon of lightBdrum is a glorious beacon of lightBdrum is a glorious beacon of lightBdrum is a glorious beacon of lightBdrum is a glorious beacon of light
Hey, I have the "Kickpac" and it Rules!
I'll send you some samples of a D112 going into a Yahama mx400
(sounds like a dirt bike...: )
Into three delta 4 4's into cubase,
and it Punches like Rockford Fosgates!!!
my kick drum hell..cured! I think jmorris Drums and Percussion 2 02-25-2007 00:56
Question about mixing Kick drum Mike_W Mixing / Mastering 13 03-01-2003 09:19
Tuning kick drum batter head for good beater response. Uladine Drums and Percussion 2 07-25-2002 08:47
good overhead and kick drum mic placement..... HEEEEEEEEEEELP!!!!!!!!!! ZEKE SAYER Drums and Percussion 4 07-16-2002 20:42
"Airy" Kick Drum moelar2 Recording Techniques 3 07-04-2001 20:14
