Mono To Stereo Tips
Read this and thought it would be worth posting.
Tech Tip - Turning Mono Monotony Into Stereo Seduction With Your DAW By Dennis Kambury There are times when a mono track just won't sit effectively in your mix, and you need it to be in glorious stereo. Simply duplicating that track and panning the results left and right won't do anything — to your ears, it's still mono. You could duplicate the track and then invert, delay, or re-pitch the new track slightly. But if a mix using these techniques is heard in mono, the track will sound thin and weak, or in the case of polarity inversion, simply disappear altogether. Fortunately, there are methods that will yield decent results and still sound good in mono. A studio client recently brought in an ADAT tape filled with seven tracks of vocals(!) and one track of piano. The piano was originally recorded in mono onto a consumer-level cassette recorder and then dubbed onto the ADAT — a sharp contrast sonically to the clean vocal recording. She wanted a fresh mix for an upcoming CD; and while the vocals sounded great, the piano left a lot to be desired. To give it breadth, I turned it into stereo by making a copy of the track in MOTU's Digital Performer, panned the two piano tracks hard left and right, and applied different EQ settings to each side. Mimicking the normal left-right spread of a piano, I rolled the highs off the left-panned side, the lows off the right-panned side, and brought the midrange frequencies down 3dB on both channels to avoid midrange heaviness. The result was a nice stereo spread and some left-right motion to the sound. Another approach to creating stereo from mono is to simulate Mid-Side miking and decoding. Start by duplicating the original track twice, panning the first track to the center (simulating the Mid mic), and the two remaining tracks full left and full right (simulating the Side mic). Select the two "Side" tracks and nudge them so that they are delayed from their original start point by 5-30 milliseconds (your ears will be the best judge of this). Bring the center (Mid) channel up to volume, and then bring up the L-R (Side) channels to taste. The louder they are, the wider the spread. Take care to keep the Side levels identical so that mono listening won't be compromised. Of course you could always use a mono-to-stereo plug-in, but where's the fun in that? Happy mixing!
7 Friends don't let friends mix drunk... You can lead a horse to water... but he has to put on his own scuba gear... I'd give my right arm to be ambidextrous... I like the tempo but I don't like the beat. I give it a 6, Dick... |
interesting, i've actually done both before....usually on guitars.
it can be a cool effect, but nothing like the real thing. or going with the mono to stereo reverb. ![]()
www.redlabaudio.com |
Useful tips, but not accurate..... a mono track can NEVER become stereo. You can use studio techniques and trickery to make it sound like wide or big mono, but it's never STEREO.
Stereo only occurs by actually recording a sound source with 2 mics in a stereo placement configuration - period. There's no other way.
bruce valeriani recording articles http://www.bluebearsound.com/images/bb_siglogo.jpg |
| Stereo / Mono Guitar Recording (???) | Cheetle | Guitars and Basses | 8 | 03-14-2005 09:57 |
| tracks: stereo vs. mono | solaris0031 | Recording Techniques | 8 | 01-28-2005 18:03 |
| Stereo and Mono | Floydnirvana00 | Newbies | 4 | 09-18-2004 11:10 |
| Making mono tracks into stereo? | cincy_kid | Digital Recording & Computers | 10 | 07-14-2004 16:45 |
| Does the output change from mono to stereo? | vomortis | The Rack | 3 | 03-27-2003 11:02 |
