levels and mixing
Lately i have tryin to work on my mixer, where i just seem to have trouble on adjusting levels.like drums and bass guitar.I'm not real sure to bring drums up enough to clear everythign else, but then sometime si think the drums are so loud i cant hear anythign else, another problem i have is mixing bass.Its either too high or non existant, i just cant seem to get it to flow just right.I havent even started eq'in yet im at a loss with that, i wouldnt even know where to start even after reading hours of online of articles.I'm also still expermenting with compression, how much or when to do it. any tips or suggestions for me to get myself on track with this? thanks
Gear: soundcraft Mixer m-audio audiophile 24/96 schecter guitars line6 spider amps various soft synths The one plugin that I cant live without:bbe sonic maximizer |
Are you trying to record "live"; i.e. recording everything at one in the same take and and mixing it all on the fly to a stereo recording? If so, are there legitimate logistical reasons for you to do that like time constraints or lack of input channels to your PC (how many simultaneous channels in do you have?) If you're mixing to a stereo recording live because you have to, then a little more inforamtion abut how many instruments and voclas you're recording and how, and what style of music it may be, would be very helpful to avoid general comments like "strap your compressor across the drums at 3:1 medium", which may or may not be the actual best solution for you. If, OTOH, you're talking about mixing multiple tracks in CEP, that's a different animal altogether with a different set of details. So could you explain a little further? G. |
One trick I use to get levels to match is to turn down the monitors to a very soft level, whisper soft. What happens is that when you listen this soft is that any tracks that are too soft in relation to the others will simply disappear. So if your drums are too loud, when you turn down the volume you won't be able to hear any other tracks.
What you do is *at the soft volume* adjust the levels so that you can hear every part in the mix. Then turn the volume back up to normal levels and you should be fairly close to the right relative volumes between the tracks. |
G. |
listening to the radio fairly quite, an alarm clock radio... listening to the "oldie hits" station... noticed how the vocals were up front every word understandable, guitar main riffs came and went usually when there's no vocals going on.... bass was there, but minimal drum ex: snare only heard... but on songs that had more drums the bass was pushed back...disappeared as Sonic said. while the vocals & guitar and/or piano rffs remain same, with guitar or piano licks coming in and out and not stomping on the vocals. it was like a whisper level, on a crap 2" or 1" radio/alarm clock speaker. dolecek1... i'm doin the same Mixing 101 man...its fried at times...each sounds ok, then little by little the mud creeps in or "masking"...very interesting like any art i guess..crazy. i'm going to do the whisper thing...sounds logical and easy. ![]()
if it's not happening in the room, it ain't gonna happen on tape.-HG |
There are several different procedures that various people have for mixing, e.g. building bass up, starting with vocals, putting all faders at 0dB and going from there. In the end you really just need lots of practice to hear what you need to hear. I still suck, but I can usually get a mix to the point where all the instruments can be heard and nothing is too offensive. I'm a lifelong musician (and avid forum reader) with performing, not recording engineering, experience in professional studios and it still took a ton of work to get to this point as a recording engineer. Regarding the alarm clock, is it mono? All kinds of strange things can happen in mono, but obviously the instruments directly in the center will be featured. |
| stupid mixing question - levels | Roger Mac | Mixing / Mastering | 6 | 10-20-2004 11:05 |
| Mixing levels | jazzyblues | Cakewalk / Sonar Forum | 27 | 05-10-2004 09:06 |
| Mixing Levels question | fluxburn | Mixing / Mastering | 3 | 06-19-2003 19:53 |
| Recording and mixing levels | phosphor | Cakewalk / Sonar Forum | 7 | 03-03-2002 01:03 |
| levels when mixing. absolute relative | WEBCYAN | Mixing / Mastering | 2 | 02-11-2002 15:50 |
