Cardioid Capsule Repair?
I recently purchased a matched pair of Elation KM201 microphones with omni and cardioid capsules. The omni pair seems to be working fine, but one of the two cardioid caplsues doesn't sound right. These are suppose to be a matched pair, and the difference is quite dramatic between the two. It sounds as though the capsulse is blown cause there is no low end, and the top end sounds sizzly, but not in a good way.
Does anyone know where a replacement might be had, or if there is some way or repairing the damage capsule. Is there someone who specializes in repairing microphone capsules? I assume someone here must've had a similar experience at one point. Thanks Jay |
Here's a short MP3 of the 2 capsules. The first is the damaged capsule.
http://www.robotkillcity.com/KM201.mp3 Jay |
Hmmm
Can you get pictures of them?
I don't recommend taking apart anything you: 1) Have to force apart/open 2) Don't know how to put together again
http://www.animationmagazine.net/ima...n_show_150.gif |
Alright, heres some photos, though I'm not sure how these help exaclty.
I have tried swapping the bodies and capsules with each other already. It is indeed the one particular capsule. That is the one pictured below. The second photo is of the capsule with the windscreen removed. The third of course is the body. ![]() |
Is elation still in business?
Our new Myspace page The Churn - giving world music the beating it deserves Mustafa Shag |
Capsules
There are a few reasons that capsules die:
1) Diaphragm loses tension and/or conductive coating. I hear this is common with Chinese capsules. Try Peluso Labs for a re-skin. 2) Obstructions between the diaphragm and backplate. Capacitor mics can and will collect dust/junk inside of them. 3) Bad contacts between capsule and mic body. Check those out too. I'd compare the two capsules since it seems you can get them apart. Use a magnifying glass. I make sure to never mix up the parts between the two, even if they are a matched pair. Check the capacitance - This can be done on many multimeters. Someone nearby has one if you don't. If they are indeed a matched pair, the capacitance shouldn't be off toooo far. One lead goes on the housing, the other on the prong sticking out of the bottom.
| All the World's Tube Microphones PART TWO | Bambi Busboom | Microphones | 5 | 09-06-2006 13:16 |
| All the World's Tube Microphones PART ONE | Bambi Busboom | Microphones | 2 | 08-15-2004 04:02 |
| Whats Everyone Got For Mics ? | Henri Devill | Microphones | 101 | 04-20-2003 09:25 |
| Oktava MC012 cardioid capsule dead | crgman | Microphones | 1 | 02-10-2002 19:54 |
| Rode NT-1 or Marshall v67? | Nutdotnet | Microphones | 20 | 03-22-2001 15:06 |
