Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 08-17-2005
tommy mas tommy mas is offline
Junior Member
tommy mas has a spectacular aura abouttommy mas has a spectacular aura about
Mixing at High or Low volumes???
do you all think that it is better to switch between mixing at very high volumes, and lower volumes, or do you think mixing one way or the other is better ?
i have heard some places that mixing low is good, and if your mix sounds good low, then it will sound good loud also. but then at the same time you also want your mix to sound good when bumped really loud, so im just curious what you all think...
Old 08-17-2005
darnold's Avatar
darnold darnold is offline
1K Silver Member
darnold will become famous soon enough
I prefer to mix loud. I just dont feel you hear everything when you get it loud. I find that when you get it right loud its good soft too if not a little bassier.
The problem with mixing loud is it wears your ears out. So if your not going to have alot of breaks then mix quiet and then check loud for fine tuning.
Danny
Old 08-17-2005
giraffe's Avatar
giraffe giraffe is offline
i love negative rep
giraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond repute
i think the current wisdom is mix mid, while remembering to check both whisper and blast levels.
audio?
seriously, give me negative rep.
Old 08-17-2005
Junior Member
aight
thanks a lot
Old 08-17-2005
apl's Avatar
apl apl is offline
Stand Up Comity
apl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond repute
I think there's some kind of standard used in mixing for movies, around 85dBA average. This is probably a good level where your ear isn't putting on too much of its own compensation.
The fabulous Naiant Mics, perfect for acoustic instruments!
If you don't have DavidK's CD, you are a loser.
My tunes. Thanks!
NB
DA BEARS!
Old 08-17-2005
Junior Member
isnt the highest the human ear can hear is 120 db? so would mixing at 85 db be extrmely loud and harmful for your hears?
Old 08-17-2005
Junior Member
*ears
i need a slice of pizza
Old 08-17-2005
apl's Avatar
apl apl is offline
Stand Up Comity
http://www.soundinstitute.com/article_detail.cfm/95
My tunes. Thanks!
NB
DA BEARS!
Old 08-17-2005
AlexW AlexW is offline
Force of Nature
AlexW is a splendid one to beholdAlexW is a splendid one to beholdAlexW is a splendid one to beholdAlexW is a splendid one to beholdAlexW is a splendid one to beholdAlexW is a splendid one to beholdAlexW is a splendid one to behold
85 dB isn't all that loud sounding to me actually. You can get a cheapo sound level meter at Radio Shack to check with. What I've heard/read is that at 85 dB or so most frequencies sound pretty accurate (flat) to the human ear.
Old 08-17-2005
MadAudio's Avatar
MadAudio MadAudio is offline
Damned if I do
MadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond repute
I also tend to mix at around 85dB, but I will check the mix at lower levels. Having more than one set of speakers/monitors is also handy. While I do my main mixing through my Wharfedales, I also check the mix through my NS-10s and my Rat Shack Minimus 7s.
Newest endeavor: Playing drums in a live band version of 7 Door Sedan's music.
"Do yourself a favour just shut up, read up then put up." --muttley600
Old 08-17-2005
FALKEN's Avatar
FALKEN FALKEN is online now
FALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond repute
I find that it is easier to set levels at a low volume, especially vocals and bass, but as I try to make out the small details, the fader moves up until my girlfriend comes in and says i'm blowing her hearing out across the house....can't seem to control that thing. (the fader).
  #12
Old 08-17-2005
Gorty Gorty is offline
Gorty has a reputation beyond reputeGorty has a reputation beyond reputeGorty has a reputation beyond reputeGorty has a reputation beyond reputeGorty has a reputation beyond reputeGorty has a reputation beyond reputeGorty has a reputation beyond reputeGorty has a reputation beyond reputeGorty has a reputation beyond reputeGorty has a reputation beyond reputeGorty has a reputation beyond repute
I'm not sure of the level in dB's that I will mix at but generally I will mix at a level that will give me a couple of hours or so of mixing without fatigue setting in (especially mixing guitars that I like to have cutting through the mix somewhat).
In the end I have always been led to believe that checking your mixes at varying levels is a good practice to adopt.
However I love it loud!!!!!
  #13
Old 08-17-2005
Protoolfool Protoolfool is offline
Newbie
Protoolfool is on a distinguished road
Tis The Floyd /Munchin(munchkin??!!) theory that estimates aprrox. 80 db is the most accurate audio level for frequencies to show their true colors.
  #14
Old 08-17-2005
GOODLAND's Avatar
GOODLAND GOODLAND is offline
Force of Nature
GOODLAND has a reputation beyond reputeGOODLAND has a reputation beyond reputeGOODLAND has a reputation beyond reputeGOODLAND has a reputation beyond reputeGOODLAND has a reputation beyond reputeGOODLAND has a reputation beyond reputeGOODLAND has a reputation beyond reputeGOODLAND has a reputation beyond reputeGOODLAND has a reputation beyond reputeGOODLAND has a reputation beyond reputeGOODLAND has a reputation beyond repute
I keep it somewhat quiet but boost it up in the end to make sure.
  #15
Old 08-18-2005
Track Rat's Avatar
Total Gear Slut
I have a Rat Shack SPL meter that I use to set the mix level to 80 to 85 dB.
Mike
  #16
Old 08-18-2005
SonicAlbert's Avatar
SonicAlbert SonicAlbert is offline
Super-Sonic "Herb" Albert
SonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond repute
Mixing at mid levels doesn't do too much wear and tear on the ears, and is good for long sessions. Checking soft is essential, as is checking at blast levels for short periods. I also find using a big and a little pair of monitors very helpful, and checking in mono is amazingly useful as well.
  #17
Old 08-18-2005
prestomation prestomation is offline
Dedicated Member
prestomation has a reputation beyond reputeprestomation has a reputation beyond reputeprestomation has a reputation beyond reputeprestomation has a reputation beyond reputeprestomation has a reputation beyond reputeprestomation has a reputation beyond reputeprestomation has a reputation beyond reputeprestomation has a reputation beyond reputeprestomation has a reputation beyond reputeprestomation has a reputation beyond reputeprestomation has a reputation beyond repute
I probably monitor louder then the averege AE, but not ear blasting. Everyonce and i while i'll turn it up quite a bit and sit back and close my eyes. And then sometimes I'll do the same thing, but turn it way down. It helps me get my mind off the last thing i was mixing, and onto something else i need to spend hours tweaking.
  #18
Old 08-18-2005
SouthSIDE Glen's Avatar
SouthSIDE Glen SouthSIDE Glen is offline
independentrecording.net
SouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond repute
While I like your name better, it's actually called the "Fletcher-Munson" curve, and yeah the textbooks state the somewhere in the 80-85dBSPL range is supposed to be ideal. I find that I can't keep it at those levels for super long, though, at least not in near fields. It gets loud and fatiguing to keep it up there constantly. Keep it varied, like other posts have said, and bring it up to the higher levels for testing/checking purposes.
G.
Glen J. Stephan,
SouthSIDE Multimedia Productions
RECORDING RESOURCES AND INFO SITE:
  #19
Old 08-18-2005
MadAudio's Avatar
Damned if I do
THIS IS A VERY GOOD POINT!
OK, I'm done shouting now.
  #20
Old 08-22-2005
solomon solomon is offline
Newbie
solomon is on a distinguished road
Sir
well it is not so bad when you keep it mid, but boost in the end to check your levels .
  #21
Old 08-22-2005
Simman's Avatar
Simman Simman is online now
Force of Nature
Simman has a reputation beyond reputeSimman has a reputation beyond reputeSimman has a reputation beyond reputeSimman has a reputation beyond reputeSimman has a reputation beyond reputeSimman has a reputation beyond reputeSimman has a reputation beyond reputeSimman has a reputation beyond reputeSimman has a reputation beyond reputeSimman has a reputation beyond reputeSimman has a reputation beyond repute
I mix at varing degrees of volume but mostly end up at mid volume ~80 - 85 DB. I do crank it up and listen to the mix from outside of the control room (obviously I leave the door open ) just to get a different perspective on the mix as well.
Balanced, unbalanced, high impedance, low??? tucker97325 Studio Building & Display 3 05-21-2005 10:03
Help! High E string keeps ringing canada-paul Guitars and Basses 7 05-01-2002 08:01
High and Low mic...possible phase problem- please explain? bloozguy Drums and Percussion 5 02-22-2002 11:05
Let's talk about normalization. Eurythmic Digital Recording & Computers 18 04-07-2000 14:50
Mixing down to High end cassettes. Painkiller Newbies 3 11-17-1999 11:50
