BUSS recording with VF160
can someone explain easily how to buss one source to a different track? (ex input 2 to input 11?)
is it possible to record multiple sources to one track? (ex inputs 1 and 2 to track 12?) thank you for the help. Last edited by getupkid0717; 08-17-2005 at 23:13.. |
Say, for instance, you have a mixer or a Porta-format clone, and the principals are the same.
Your Inputs, [1-4] or [1-8] are routed through an "Assign" or "Group-Assign" section, which would typically be "L/R" or "1-2-3-4", depending on if you're on a simple Porta- or a larger one, or mixer. In general, "L/R" applies to Track 1: Left, Track 2: Right, Track 3: Left, Track 4: Right", as well as being "Group 1:L", "Group 2:R", "Group 3:L", "Group 4:R". Each "Track" or "Group"-assign has a button or switch, and then you'd rotate the PAN knob to differentiate your inputs between L & R. Sorry if this explanantion is not the clearest synopsis. For your Input 1, you may start by assigning it to Track or Group 1 & 2. Then, if you rotate Pan to the Left, Input 1 assigns exclusively to Track/Group 1, and rotate Pan to the Right, it assigns to Track/Group 2. Set PAN in the center, and you have equal amounts of signal routing to R/L, 1 & 2, equally. Tracks or Groups 3 & 4 basically parallel the signal path on 1 & 2, with 3:L and 4:R. Any input may be assigned to any output, (group) buss or track, through use of a combination of the Assign (group/track) switches (or buttons) and PAN. Hope that's clear enough to get you started on the right track. I could only be more specific about the button names if I knew exactly which mixer you're talking about, but the principals are the same for every multi-buss mixer, and Porta-'s alike.
a.k.a. Davemania! Beatles and other Classic Rock covers!! Yeah, Yeah, Yeah!!! 637 songs by 191 bands.
| PC recording, not for the fence-sitters | Diragor | Digital Recording & Computers | 11 | 02-28-2006 17:26 |
| Tascam M-35 Help please | Blackdog.sn | TASCAM User Forum | 23 | 08-04-2005 01:26 |
| audio recording - start and end points | Peter Dunn | Recording Techniques | 8 | 09-14-2004 13:19 |
| Delta 44 vs. Windows Recording Mixer. God help me. | Shepherd | Digital Recording & Computers | 2 | 06-09-2003 07:39 |
| A setup for mostly live recording... | Godsguitarist | Digital Recording & Computers | 8 | 05-09-2002 23:22 |
