MD421-II/e609S mic comparison... chuggin with a Cobra Amp
Here is a MD421-II and e609S mic comparison...
MD421-II / e609S Comparison Setup: Cobra Amp - Crunch Channel Cobra Cab - Greenbacks Mic: MD421-II (Top Right Speaker) and e609S (Top Left Speaker) The guitar was double tracked with each mic to a seperate track... so that's four tracks. Two Md421-II and two e609S You'll hear the short riff twice in this MP3... 1st riff alternates between the MD421-II and e609S, back and forth. When a particular mic is heard, it's only that mic in both the Left and Right sides and alternates so the differences are apparent: Time \ Left \ Right 00: MD421 MD421 09: e609S e609S 17: MD421 MD421 21: e609S e609S 25: MD421 MD421 33: e609S e609S 42: MD421 MD421 2nd riff is the MD421 on the Left and the e609S on the Right but not hard panned Time \ Left \ Right 00:00 MD421 e609S I use this micing setup often for heavy guitars. It gives a lot of flexibility during mixing... |
I like the 609 better, but both are pretty good actually
Nice tone ![]() |
It apears that the e609s is a bit brighter than the 421.......which is good to know....
I wonder how much of a difference there is when using the e609 (Black / originals) ??? Hmm.... Thanks for the great comparrison!! I wish someone would do that with the SM57/e609 since this topic comes up quite a bit. ![]() Rick |
when the take is panned left, but not hard panned, the e609S is actually on the Right side to a lesser degree and... when the take is panned right, but not hard panned, the MD421 is actually on the Left side to a lesser degree and... This flexibility is nice... panning can be used like an EQ to some degree. |
I like the 609S better, which I would have bought anyway b/c the MD421 is too expensive for a mic for me at the moment...
thanks for taking the time tho, looking forward to a E609S vs SM57 from you... Stan.
The Home Recording Vocalists Forum |
i had considered a 609 and 57 A/B, but after virtually no response I had decided against it... when I get time I'll do one |
#12
Personally, I dig the 421 versions better - they sound a lot fuller on the low end, and the 609 sounds a little tinny to me. I actually just bought my first 421 a few days ago, but so far I've only used it to record my floor tom. I suppose I made a good choice, seeing as how the 421 responds well to low frequencies.
![]() As for SM57, I haven't had a lot of luck using them on guitars. It could have been my placement or the amp I was using, but when I did an A/B with a 57 and this crappy $20 Nady vocal mic I had lying around, the Nady seemed to sound a lot fuller. The 57 was just too thin for me...different strokes for different folks, I suppose ![]() -Agra |
#13
i did a recording a while back where i used an md421 and an e609 on a guitar track, and there wasn't nearly the difference that you have. i wonder why. probably just placement, i guess.
This place is garbage. |
#14
I like the first 10 seconds with the MD421.
#15
Hi...by itself,the MD421 was the clear winner to my ears/through my monitors in both clips...more body-fuller sound...even after throwing your clip into Samplitude and running a HP and LP filter on it.The combo of the two mics didn't sound bad though...just not as good IMO.
#16
I agree with everyone that liked the MD-421 better, not much to add on my part you all covered it well. Now what I want to hear is some sm-57/m201/md421 snare clips!
#17
I usually end up rolling off the low-end some for the 421 when in a full mix thanks for the comments... |
#18
#19
I have heard some killer clips from others here using a 57, but I can't seem to capture that with mine. |
#20
Sonixx, are you using any compression on that clip? I'm using my e609s in my signal path and am getting nothing near the frequency response that you are getting.
I know I need to upgrade my gear, but to not get anything near what you are and it is driving me bonkers. Here's my chain: EMG Pickup -> PSA-1 -> Crate ss combo (clean) -> e609s -> UB802 -> Soundblaster MP3+ USB Can the crappy pieces in my signal chain really make things sound crappy?
SoundClick...geezer stuff [Acoustic Rock] MySpace...enter at your own risk. [Metal Oriented] |
#21
Are you saying that the sound coming out of the Crate is what you would consider good??..............Just checking.
![]() Sometimes you gotta stick your head down where the mic is going to be to get a better idea of the sound that the mic actually sees.........uh...hears. ![]() Rick |
#22
I don't know...I'm only using the Crate thru the clean channel while using the PSA-1 as my pre-amp. Do you think the Crate is actually hosing my frequencies? Possibly the speakers? I wish that I could play for someone live...I honestly don't know if the sound is actually any good. Unfortunately, it's all relative to my own experiences.
#23
No compression but Vintage Warmer at a very very low setting, mainly for the low end... No EQ... I did roll off above 7500Hz. Often I do run the Vintage Warmer at a much more extreme setting though. I seldom EQ post tracking other than Hi Pass at 60Hz, Low Pass at 7500Hz and maybe a Hi-Shelving at 10K +2db Here's my signal chain: EMG81 -> Cobra Head Crunch Chnl -> Hot Plate @-8db -> Cobra Cab Greenbacks -> SM57/e609S -> Mackie 1604vlz -> RME ADI-8 -> Samplitude The Channel and Master Vols were at 3:00 The mics were aimed just ever so slightly off-center When I track, I monitor with a pair of AKG 171 phones and set the amp with the phones on. I have no clue as to what the amp sounds like in the room... and don't care. Also, 9 out of 10 times I point the mic directly at the dust cover. I'd like to understand what you consider crappy... can you post something? -keith- Last edited by Sonixx; 08-26-2005 at 06:31.. |
#24
Sonixx,
Here are 2 short clips: This one is raw: http://home.comcast.net/~katauskas/NoMore_raw.mp3 This one has EQ and a multi-band compression on the guitars to bring out some mids. There is also some compression on the mix. http://home.comcast.net/~katauskas/NoMore_mixed.mp3 I really appreciate you taking the time to listen. Its just really missing something...? Dave
#25
Dave,
I just listened and my first impression is that it sounds like mainly preamp gain... I run my amps almost full bore because I prefer the tone of pushing the power section... can be much thicker. I'm not familiar with your chain and amp. How loud do you record? What tone are you going for? -keith- Last edited by Sonixx; 08-26-2005 at 06:58.. |
| Experiment in Guitar and Bass Amp DI and Mic | Sonic Misfit | Guitars and Basses | 0 | 03-17-2004 14:46 |
| Korg mic pres vs separate mic pre amp | Randjons | Microphones | 5 | 07-15-2003 21:27 |
| What is a mic pre amp and Top Condenser mic choice under $300 | Monkubus325 | Microphones | 39 | 07-02-2003 16:04 |
| NT1 Rode ? | Ears | Microphones | 24 | 06-27-2000 09:16 |
