Old 08-16-2005
Jakob_v Jakob_v is offline
Newbie
Jakob_v is an unknown quantity at this point
The 3-to-1 rule - misunderstood?
Hello, I've been reading and learning quite a lot about phasing problems lately. I've been wondering why people write so different things about the 3-to-1 rule..
I've heard two explanations of it:
1) The distance between the mics should be three times the distance from the mics to their sound sources. This means Mic 1 will have X distance to source A, and 3X distance to source B, while Mic 2 will have X distance to source B, and 3X distance to source A. I have heard this from a few people.
2) The distance between Mic 2 and the sound source should be 3 times the distance between Mic 1 and the sound source. I've heard this from a lot of people.
I can totally understand number 1, since the mics will recieve most of the sound from the closest sound source, because volume raises exponentially when you get closer to the source. Phase cancelling will then be minimal.
I can't understand number 2, because Mic 2 would need a lot of preamp gain to have the same signal as mic 1, and phasing problems will occur. I've tried to mic my amp with 2 mics on a different distance, no way the phasing issues dies away when I use the 3-to-1 rule. Of course, with the same amount of gain on both mics, Mic 2 won't be heard at all....
Any explanations? Other theories? Facts?
Old 08-16-2005
Newbie
Originally Posted by SouthSIDE Glen
The answer is "C.) None of the above."
The standard 3:1 rule reads that the mics should be a minimum of three times the distance from each other as they are from their common source. In other words, if mic A is 1 foot from the sound source and mic B is also 1 foot from the sound source, the two mics should be placed at least 3 feet from each other in a wide spread.
This applies to non-coincident and non-near-coincident setups only. In other words this obviously does not apply to an X/Y pair, OTRF pair, etc. in which by definition the mics are very close to or on top of each other.
G.
I can't really see how it's possible to place two mics who each are 1 foot from the source, 3 feet away from each other? Or are you talking about 2 sound sources?
Could you explain a bit more about non-coincident and non-near coincident micing?
Edit: Drugs?
Old 08-16-2005
SouthSIDE Glen's Avatar
SouthSIDE Glen SouthSIDE Glen is offline
independentrecording.net
SouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond repute
1) is the answer. It also applies to two non-coincident mics recording the same sound source.
G.
Glen J. Stephan,
SouthSIDE Multimedia Productions
RECORDING RESOURCES AND INFO SITE:
Old 08-16-2005
Edit: Drugs?
Yeah, drugs. First of all, you read and quoted my reply before I deleted it because I explained it badly or wrongly. "Drugs" was my lame explanation for deleting it. Sorry
I'll explain better in the next post.
G.
Glen J. Stephan,
Old 08-16-2005
An example of what I was talking about would be stereo overhead mics over a drum set. By the 3:1 rule, the overheads should be a minimum of three times the distance from each other as they are from the top of the drum kit.
"Coinicdent" mics are two mics that are setup to record in stereo where the mics are pointed angled away from each other with their pickups either right on top of each other (what's called in the States "X/Y miking".) There are other variations on such miking techniques, a Google search on coincident microphones should give you plenty of detail.
But to get back to 3:1, the idea is that the mics should be farther away from each other than they are the source, regardless of whether its one source or more.
G.
Glen J. Stephan,
Old 08-16-2005
Newbie
Okay, thankyou
Old 08-16-2005
snow lizard's Avatar
snow lizard snow lizard is offline
Dedicated Slacker
snow lizard has a reputation beyond reputesnow lizard has a reputation beyond reputesnow lizard has a reputation beyond reputesnow lizard has a reputation beyond reputesnow lizard has a reputation beyond reputesnow lizard has a reputation beyond reputesnow lizard has a reputation beyond reputesnow lizard has a reputation beyond reputesnow lizard has a reputation beyond reputesnow lizard has a reputation beyond reputesnow lizard has a reputation beyond repute
A/B micing.
Using only one microphone.
Not necessarily. Number 2 isn't really an example of A/B stereo micing, but what might help in this case is the time delay that it takes for a sound source to travel the extra distance to the farther microphone.
It's common for people to use 2 or more mics to capture a guitar amp, but usually not for a stereo image. An exception might be if you were recording a stereo amp like a Jazz Chorus and you wanted to capture the stereo image of the amp - A/B micing could be used. Consider a non-stereo amp for this:
Take a mic like an SM 57 or whatever dynamic as a close mic. Stick it right in front of the speaker cone. This gives you a very "direct" type of sound. It will reject a lot of room sound being that close to the amp. A second mic farther away (eg. 3 feet) from the speaker will capture a completely different sound. It will include the room a lot more, especially if it's some kind of condenser or ribbon mic, and it will make the guitar sound kind of fat when both mics are being heard back from the recording, provided the mics and placement are suitable, and there's no phasing issues. The distance between the mics will help with the phasing issues because of the time delay, but there's no guarantee. The time delay will usually make the guitar sound "big". A setup like this can impart depth, space, fatness and room sound to a guitar track, but it's not really intended to be stereo. Both mics combined will give you a sound you simply can't get with either mic on its own, and you can blend them together to suit whatever you're going for.
One way to get rid of the phase problems is to run pink noise through the amp. Set both mics up and flip the phase on one of them. Send the combined signal from both mics to a set of headphones. Walk over to the distance mic and tweak it around a bit until you get the lowest sound coming through the phones. Once you flip the phase back to normal, you'll have minimal phase cancellation when you're recording the guitar track. It's a handy trick if you're going to use more than one mic.
Another thing people do sometimes is tape a Beta 52 (or something) to a 421 (or something) to record a kick drum. The capsules are as close together as possible. Usually this doesn't create a whole lot of phase issues, because it's coincident or near coincident. The sound arrives at both mics at the same time, because they're in the same space. The mics will sound completely different from each other, but now you can blend them together to taste with little fear of phase problems.
Hopefully this makes some kind of sense.
sl
Old 08-17-2005
easychair easychair is offline
Force of Nature
easychair has a reputation beyond reputeeasychair has a reputation beyond reputeeasychair has a reputation beyond reputeeasychair has a reputation beyond reputeeasychair has a reputation beyond reputeeasychair has a reputation beyond reputeeasychair has a reputation beyond reputeeasychair has a reputation beyond reputeeasychair has a reputation beyond reputeeasychair has a reputation beyond reputeeasychair has a reputation beyond repute
G.
So if my drum OH mics are three feet over my kit, they should be nine feet apart? You may want to rethink that, no offense intended, you always post great stuff. That would be hard, at the very least, if your OHs are more than a foot or so up. At that point, some kind of spaced or coincident pair technique is probably a bit easier, and what seems to happen a lot for true stereo overheads. 3:1 doesn't really give full true stereo, as I see it. It really seems to be meant to keep phase issues down by controlling bleed, and therefore makes a poor stereo mic'ing choice, compared to others. It seems some center material is always going to be lost.
Jakob,
Some good info here, which I feel like expounding on. It is late, and I am bored. Your instinct about number one in your post is correct, and here is why.
The 3:1 rule covers a lot of situations, and is a guideline to prevent phase anomalies. It is very gain, source, and placement dependent. It applies to some semi-stereo techniques, close-mic'ing of multiple sources to prevent phase problems from bleed, reflections, and probably others I have forgotten.
The basic idea is this:
Phase problems happen when two out-of-phase signals get heard together, at similar levels. Some freqs reinforce, some cancel. A propellorhead a long time ago figured out that if two out-of-phase signals are heard together, you can't hear the phase cancellation if one of the signals is at least 9db quieter than the other. You can't hear the quieter signal very much at all, really, but that's another thing.
Two similar sources in a room (say two strummed acoustic guitars) are each miced at the same distance (say one foot) by identical mics with identical gain.
If the mics (and guitars) are at least three feet apart (3:1), in each mic the close source (the close guitar) will be at least 9db louder than the far guitar. You can play both tracks back together, no phase problems. The bleed between mics is low enough in level it causes no problems.
So this is part of how the general 3:1 rule came about. All things being equal, sources, mics, gain, etc., if the far source is at least three times the distance of the near source, the far source will be at least 9db quieter in the mics than the near source. You can play both tracks, no problems. I don't know if it was originally designed and researched as a stereo technique, but as a stereo technique it has been replaced by many vastly superior ones. 3:1 has lots of uses, though.
Hopefully you can see that a strict 3:1 rule won't do shit if you are mic'ing a hammered dulcimer from one foot, a raging Marshall stack from one foot, and they are three feet apart. If you play both those tracks back at the same level, the Marshall will be very phase-affected, and the dulcimer track will be useless.
It's about relative levels of direct and far sounds in the same mic during recording and relative levels of out of phase signals in different channels on playback, not an absolute 3:1 rule. You observe 3:1 to give you usable tracks, able to be mixed at the right levels with no phase problems.
If two mics are on the same source, at different distances, if you listen to both at the same volume, there will be phase anomalies. This is where the idea of moving the far amp mic around to find out where it sounds the best comes in, as well as Snow Lizard's pink noise technique. You are trying to minimize the effects, you can't kill them completely. That is why 3:1 doesn't kill phase problems when you use two mics on one amp from different distances. 3:1 isn't meant to address the phase issues from that. So yes, number two is wrong.
Never mind the physical impossibility you pointed out, of having two mics be farther apart than their combined distance to the source. I laughed when I read that, I got my ass chewed by my mentor when I pointed that same thing out. It led me to study the subject in a lot of detail.
In these digital days, you have a bit more flexibility. Say you find a great room mic location, but it causes massive phase problems. You can nudge the track until it doesn't cause as many problems, instead of moving the mic and losing your sound.
The concept behind the 3:1 rule also helps explain phase problems caused by reflections. Picture a speaker talking into a podium mic across a hard desk. His voice reflects off the desk, and the reflection arrives at the mic shortly after his voice. This can cause phase cancellation if his voice is less than 9db louder than the reflection at the mic, as it violates the concept behind the 3:1 rule. The cures?
Move the mic close enough to make the speaker's voice more than 9db louder than the reflection, or damp the reflection so it is more than 9db quieter than his voice.
3:1 in Stereo Mic'ing:
First of all, a little basic background on how stereo mic techniques and human hearing work.
Human directional location works on two principles. If a signal is louder in one ear than the other, our brain thinks it comes from the louder side. Our heads are kind of sound baffles, and our ears are fairly directional. Also, our head acts as a delay between our ears. A sound of equal intensity in both ears but delayed slightly on one side will seem to come from the non-delayed side. Our brains use amplitude and delay to provide very accurate spatial location of sound sources.
Spaced pairs use delay to generate the stereo image. Spacing the mics introduces the delay for the stereo recording. A signal on the right will hit the right mic first, then the left.
Coincident pairs work by the fact that directional (cardioid, mostly) mics are used, but facing different directions. A sound coming from the far right will enter one of the mics where it is very sensitive. The other mic picks up the sound at the same time, but reduced in level, as the mic is not facing the sound. When you listen to both mics, the postion in the stereo field is determined by the relative volume of the source in both channels. Something appearing to be in the center is actually in both mics at the same volume. This is how the pan pot on a mixer works, by varying the levels of a channel in both ears at once.
3:1 is sometimes used in close stereo mic'ing. In the case of a piano, say, with one mic covering the low strings and one covering the highs. 3:1 is a good place to start to keep the bleed and therefore phase problems down.
The key thing to notice is that left and right are kept as isolated as possible, to reduce phase problems. Essentially each half of the piano is treated as a separate source. So, two sources, two mics, 3:1, no problems. Not real stereo, either, though, as I see it. Because as you might guess, this leaves a hole in the middle. It's the same with drum overheads. A pair of mics one foot up and three apart is going to miss a lot if you really want to avoid phase from bleeding.
So you gotta toss 3:1 and go with your ears.
Any spaced pair is either going to follow 3:1, and not capture the whole image, or needs to be placed so phase problems are minimized.
Spaced and coincident pairs have their own problems, and solutions, but that is another thread.
Anyway, that's my 3.14159265 cents
Old 08-17-2005
Newbie
Thanks, that cleared up a lot.
Well, as easychair said, it's impossible to mic a source from 2 distances with no phasing problems at all, isn't it?
Old 08-17-2005
Force of Nature
Holy crap, kid, you read fast. I couldn't have hit the submit button more than five minutes ago.
Yes, it is impossible to eliminate the phasing, but making it not be a problem isn't that hard. Many people have achieved incredible results using near/far techniques on single sources. It takes experience, experimenting, and good ears.
You can let phase problems from this technique work against you, or make them work for you. Making them not hurt you is the mark of a good engineer. Making them work for you is the mark of a great engineer.
Snow Lizard and Southside Glen seem to have some pretty hot chops, they always have good stuff to say.
Old 08-17-2005
Newbie
I replied 17 minutes later
3:1 rule for stero mic'ing a guitar trion12 Recording Techniques 22 04-01-2005 03:13
whats the rule of thumb for pedal order and using FX loop dassy The Rack 6 02-26-2003 19:14
Mac vs PC bdemenil Digital Recording & Computers 51 03-22-2002 15:31
3:1 rule... Phildo Microphones 26 02-14-2002 20:53
