Go Back   Home Recording > Equipment Forums > Guitars and Basses
Reply    Audiofanzine Guitar Guitar News Guitar Medias Guitar Tests Guitar Articles Guitar User Reviews Guitar Classifieds Ads
Old 08-16-2005
guitarfreak12's Avatar
guitarfreak12 guitarfreak12 is offline
Dedicated Member
guitarfreak12 is a splendid one to beholdguitarfreak12 is a splendid one to beholdguitarfreak12 is a splendid one to beholdguitarfreak12 is a splendid one to beholdguitarfreak12 is a splendid one to beholdguitarfreak12 is a splendid one to beholdguitarfreak12 is a splendid one to behold
Acoustic EQ
Ok, I am VERY aware that each EQ situation is very different, and good placement takes the place of eq. But is there a standard or most used eq for acoustic guitar once it's tracked. For example to get muddy out of it I drop 250hz by about 4db. Now that's about the extent of my tweaking, what are the "common" tweaks on it. Again I know that it's all relative, but what's the most common.
Omit Peas From the Menu
you Pot Bellied, Crazy, Solid Gold Dancer
Old 08-16-2005
Phyl's Avatar
Phyl Phyl is offline
Master of the Obvious
Phyl is a splendid one to beholdPhyl is a splendid one to beholdPhyl is a splendid one to beholdPhyl is a splendid one to beholdPhyl is a splendid one to beholdPhyl is a splendid one to beholdPhyl is a splendid one to behold
I routinely roll off everything below 80 Hz, other than that I try to use mic positioning to make it fit in the mix.
I'll sometimes roll off the high end as well, especially if there's too much harshness from the mic. I often have this problem with my Rode NT1 and Oktava MC12s.
Old 08-16-2005
asulger asulger is offline
Junior Member
asulger has a reputation beyond reputeasulger has a reputation beyond reputeasulger has a reputation beyond reputeasulger has a reputation beyond reputeasulger has a reputation beyond reputeasulger has a reputation beyond reputeasulger has a reputation beyond reputeasulger has a reputation beyond reputeasulger has a reputation beyond reputeasulger has a reputation beyond reputeasulger has a reputation beyond repute
What do you consider the high end?
Are you talking about cardioids?
12-string tunes: CDBaby, iTunes, Rhapsody
Blog: 12-string Musings
Old 08-16-2005
Phyl's Avatar
It depends on the song. Sometimes the acoustic high end is competing with the percussion or other instrument that has a lot of high frequency content so I'll start rolling off at say 12kHz and slope it down gently, or not so gently, like I said, it depends.
Sometimes I'll just whack everthing above 16kHz.
All my mics are cardioids.
Acoustic To Electric And Back Again... get2sammyb Recording Techniques 3 04-20-2004 08:34
Muddy acoustic recording: technique issue cstockdale Guitars and Basses 5 03-23-2004 02:59
acoustic elec vs acoustic/mic jetfixer03 Guitars and Basses 10 02-29-2004 19:46
I'm in the market for an Acoustic, maybe Acoustic/Electric, and need some guidance. Macpb Guitars and Basses 10 02-12-2004 14:52
Acoustic-Electric or Acoustic??? Forte Guitars and Basses 31 07-26-2002 14:38
