HollowBody Guitars
I'm in the market for a hollowbody electric guitar right now, but to be honest i dont know much about them. I'm looking for a real mellow tone, i have this idea of a sound in my head that is like a nylon string guitar.. only electric. I'm thinking one with just one neck on the neck will be fine tone wise (and hopefully cheaper). Also, are the harmonics on hollowbody electrics more like acoustics or normal electrics?
I've been considering the Ibanez Artcore series, one without the sustain block and a trapeze tailpiece.
The fabulous Naiant Mics, perfect for acoustic instruments!
If you don't have DavidK's CD, you are a loser. My tunes. Thanks! ![]() NB DA BEARS! |
whats a sustain block and trapeze tailpiece?
An archtop hollowbody guitar may actually be only hollow on the sides or wings, or there could be a solid piece under the bridge, sometimes called a sustain block. For that old fashioned jazz box sound, the archtop acoustic was fitted with a pickup. The bridge sat on the top, and since the top wasn’t structurally stiff, the strings had to be terminated at the end of the guitar, and that tailpiece is called trapeze because it swings with the strings.
Unless I’m mistaken… ![]()
i always thought it was called trapeze because of its shape.
one thing that has to be thought of before buying a hollow body is that they resonate alot when turned up and one must use the heel of ones pinkie to keep the strings that are not being played muted.
are there hollow body guitars that have that sound I'm going for? The electric version of a nylon string sound?
I think the bottom line regarding your question is this: If you put flat-wound jazz strings on a hollow-body or semi-hollow guitar, you will probably like the tone quite a bit. But it still won't sound much like a nylon string guitar. Have you heard an anyone play an electric guitar with the tone you want? |
Try 'em out
It might be time to visit a store with someone who knows a lot about amps and effects.
Godin makes a hollow-bodied nylon-stringed electric classical guitar. But the mellow sound you like may be achieved with a standard "jazz-box" archtop or a thin one like BB King's Lucile, with the right tone settings. Investigate Line6's modeller guitars, too. The have acoustic and electric versions. Maybe you'll get some specific help if you identify a particular tune that has the sound you are after. |
I've hardly played any semi-hollow guitars, but i Have played a lot of the ibanez artcore instruments. i think they were really nice guitars - quite smooth sounding, comfortable to play not too clumsy feeling and a nice price.
the only problem i decided was that they looked quite vulnerable. my band tend to play in an upstairs club, with very dim lighting and lots of drunk Ska-heads around ... i was always worried that if someone stood on my case or decided to play it without asking then it'd be much easy to damage than a 'proper' electric would be. so i don't have one if you decide to go that route, i think you'll be happy. Andy
"They're posh round 'ere. They get out of the bath for a piss and Everything." |
#12
The way it works in publishing is that the A -Y verson will cost more, especially if it is just for you. Also, I would say that the book is more valuable if it is comprehensive, and therefore provides guidance anywhere. I have a set of maps for my county that are arranged alphabetically by town. On the map, the roads stop at the town border, so you have to open the book to a different page and find yourself again. |
#13
I'll probably be accused of (and guilty of) splitting hairs here, but I think a true "electric" guitar must have metal strings because nylon strings can't excite the pickups. Pickups aren't microphones; they create a magnetic field around the strings and then respond to the disturbances in that field caused by the vibration of the strings. Since nylon strings can't disturb a magnetic field, classical guitars have to be miked -- either by a mic on a stand or by a contact mic on the body -- to be amplified electrically. I just did a quick cruise around Godin's website and didn't see anything about nylon-string electrics. If it's there and I missed it, let me know. Quote:
#14
http://www.godinguitars.com/godinmultnylonsap.htm |
#15
Gibson has (had?) an electric nylon-string model, the Chet Atkins Classical Electric, which I tried once and are quite nice...
#16
#17
Turn up the good, turn down the suck Gibson SG Standard (SD custom custom b, Gibson 490R n) Ibanez NDM1 (Dimarzio Evolution b, SD Cool Rails m, Ibanez Infinity n) MXR Doubleshot Distortion Mesa Boogie Subway Rocket |
#18
i played this washburn one the other day. I forget the model n such but it as about 700 dollars. It had a really rich tone. I like that better than my gibson hollowbody.
-Gibson 1967 ES 125 TDC -Epiphone les paul -samick d-1 acoustic -crate electric (entry level) Jammin for Jesus |
#19
I think they're a pretty flawed concept, as only three of the strings are flatwound, and flatwounds are really dead. The effect when you arpeggiate a chord is THUD-THUD-THUD-TWANG-TWANG-TWANG Pretty stupid-sounding. |
#20
I've been playing an ES-335 since the mid-'80s and it has never once given me feedback problems. Then again, I don't use feedback as part of my "sound" anyway, so my equipment is never set up to be on the edge of feeding back. Somebody who needs feedback on demand may well have a problem controlling a semi-hollow like mine. And a fully hollow arch-top would probably be right out of the question for that person. Quote:
#21
#22
oh yea, what about my question about the harmonics?
#23
I dunno about harmonics... but I'm kinda confused, you want a nylon-string calssical guitar sound, but with distortion?!?! that sounds kinda weird. What kind of music are you playing?
The best thing you could do is go to a guitar shop and play some of the hollow-bodies in order to see what they sound like, tone-wise. Its hard to describe on a BBS if you don't have a frame of reference. Hollow bodies can be all over the map as far as tone: jazz, rockabilly, punk, rock... You usally don't see metal guys playing them because they will feedback with ALOT of distortion, but I've found feedback (even when playing through an amp with alot of gain) to be much more manageable than you would think. There are other variables, like the pickups for example... I have a Gretsch with Filtertrons, which are very twangy compared to pickups on a hollowbody jazz-box, and they are relatively low output too. |
#24
bongolation is right of course, he is just giving his opinion on the sound. It is good to note that you don't get any difference in the G, B, and high E. I did like the tone from them, at least for while. They are just a style that you might like, and for <$20 to try it out (assuming it doesn't totally screw your intonation and require a whole new setup) you can do so fairly easily. Some things would not be well suited for them, others would give you a very mellow, muted sound, and the bottom three satrings definately don't ring as brightly at all. Daav |
#25
| Tradition Guitars--Samick?? | battleminnow | Guitars and Basses | 13 | 03-04-2008 08:35 |
| Bob Taylor's approach to making guitars | dobro | Guitars and Basses | 19 | 10-15-2005 23:19 |
| panning guitars in mix | gjb3 | Mixing / Mastering | 9 | 04-28-2002 01:07 |
| Paul Reed Smith guitars | Hard2Hear | Guitars and Basses | 39 | 06-23-2001 21:38 |
