Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 08-14-2005
jamking's Avatar
jamking jamking is offline
Junior Member
jamking has a reputation beyond reputejamking has a reputation beyond reputejamking has a reputation beyond reputejamking has a reputation beyond reputejamking has a reputation beyond reputejamking has a reputation beyond reputejamking has a reputation beyond reputejamking has a reputation beyond reputejamking has a reputation beyond reputejamking has a reputation beyond reputejamking has a reputation beyond repute
What am I doing wrong?
I cannot get the bass drum and bass guitar to sound decent. I'm using a keyboard (Ensoniq ks32) to create the sounds. They have a very good sound except that no matter how I eq them, they sound crappy. If I don't take away like -9db (60hz or so) at the low end, they saturate badly. This solves the bassy problem but now, they seem to thin; almost non-existant. Even the guitars are masking them. It's hard rock music, so these are vital to stand out.
I am using an Akai Dps 16 recorder that does have a frequency select compressor in the on board effects but even that didn't seem to help.
Has anyone ever experienced anything like this?
This place is so angry!!!
Old 08-14-2005
bigwillz24's Avatar
bigwillz24 bigwillz24 is offline
One Turd at a Time...
bigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond repute
Then stop EQing them...
Old 08-14-2005
jamking's Avatar
Junior Member
do you know anything about recording???
I'm taking away EQ, not pumping it up. If I stop equalizing them, they distort.
Bigwillz, you gotta comprehend better!
Old 08-14-2005
aaronlyon aaronlyon is offline
Newbie
aaronlyon is on a distinguished road
Most likely you've got more than one sound competing for the same spectrum. You need to give each instrument it's own space so they can all be heard properly. This means cutting lows from guitars, mids from bass, etc.
If your Ensonic instruments sound good by themselves, leave them as is, and look for competing sounds in your mix.
-aaron
St. Frank sez, "Shut up and play yer guitar!"
DP4, Mac Dual G4/1.25, 2GB RAM, MOTU 828
Old 08-14-2005
shortness's Avatar
shortness shortness is offline
Senior Member
shortness will become famous soon enough
shortness
scott swatzell
http://www.myspace.com/upperroommusic2006
Old 08-14-2005
bigwillz24's Avatar
Then the volume is too loud. I comprehend just fine you're eqing a signal that doesn't need to be eq'd according to you it sounds fine until you eq it.
Ok you want a quick answer...
Slap a high pass filter on the bass and set it around 200 hz.
Or separate them slighly using the pan knob
Old 08-14-2005
DonGraham's Avatar
DonGraham DonGraham is offline
Senior Member
DonGraham is a name known to allDonGraham is a name known to allDonGraham is a name known to allDonGraham is a name known to allDonGraham is a name known to allDonGraham is a name known to all
They have a very good sound except ....... they sound crappy.
Thats a good one.......When you EQ them try cutting/boosting different frequencies for each one.....Using a keyboard for hard rock drums and bass??? Not the usual approach. Maybe a wav. based drum loop (beta monkey/m-audio, etc.) will be better suited to your music.
Old 08-15-2005
volltreffer's Avatar
volltreffer volltreffer is offline
Imply depressed
volltreffer is on a distinguished road
Cool
You oughta behave better...
I think the tip is not meant as an insult while your reply seems kinda insulting... If your tracks distort, back up with gain...
aXel
Just bought 3 SM 57's . Something is very wrong. Please help! Newtons Law Recording Techniques 142 09-06-2002 22:27
Just bought 3 SM 57's . Something is very wrong. Please help! Newtons Law Microphones 64 09-06-2002 15:38
