Old 08-13-2005
JohnSmooth JohnSmooth is offline
Newbie
JohnSmooth is an unknown quantity at this point
How do I know when I need a patchbay?
I've been wrestling with this question for a while and I just wanted some opinions. Thanks!
Old 08-13-2005
SouthSIDE Glen's Avatar
SouthSIDE Glen SouthSIDE Glen is offline
independentrecording.net
SouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond repute
If you've got a couple of pieces or more of outboard processing gear (verbs, EQs, compressors, etc.) that you want to easily chain together - or seperately - to any recording or playback channel you wish in any order you wish and you don't want to mess around with a spaghetti bowl of cables to create those chains, then you are in the market for a patch bay.
If you have to ask whether or not you need a patch bay, then you probably don't need one.
G.
Glen J. Stephan,
SouthSIDE Multimedia Productions
RECORDING RESOURCES AND INFO SITE:
Old 08-14-2005
Chris Shaeffer's Avatar
Chris Shaeffer Chris Shaeffer is offline
Peavey ROCKS!!!!!!!!!!!!!
Chris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond repute
I suggest getting a patch bay before your back goes out from crawling under the table so you can get to the back of your rack and hook things up.
If you've worn out more than 2 sets of pant knees its time for a patchbay.
And especially if you tend to hook and unhook your stuff so much that the jacks start to get a bit loose- patch that puppy up and make the $50 patchbay take the abuse instead!
Keep in mind, though, that you cabling needs go through the roof when you add a patchbay because its essentially like having everything hooked up all the time AND you have short patch cables to actually patch them in.
Worth it, though, to save your back and knees.
I suppose another condition I'd add is if you want to look professional for some reason. Or if you need to neaten up the appearance of your studio. Patchbays, while they create WAY more cables, typically let you tuck all those cables away and just have little ones laying around.
-C
Old 08-14-2005
thajeremy's Avatar
thajeremy thajeremy is offline
registered abuser
thajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond repute
You may need a patch bay if.....all of the above
Old 08-14-2005
FALKEN's Avatar
FALKEN FALKEN is offline
FALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond repute
you'll know.
...and then a month later, you'll know you need a second one.
my patchbay doesn't have a switch to goto Half normalled..open... earworm The Rack 3 3 Weeks Ago 11:17
Patchbay setup w/ProTools fatone The Rack 0 12-19-2004 18:48
Signal flow/ Patchbay/ RNC's (2) Pro Tools User The Rack 1 09-18-2004 22:05
Using a patchbay...Help! K9SaVeLLi The Rack 9 06-28-2004 06:03
midi patchbay trickeries L'espion Noir The Rack 5 11-08-2002 11:00
