Go Back   Home Recording > Equipment Forums > Guitars and Basses
Reply    Audiofanzine Guitar Guitar News Guitar Medias Guitar Tests Guitar Articles Guitar User Reviews Guitar Classifieds Ads
Old 08-13-2005
amt7565 amt7565 is offline
Force of Nature
amt7565 is on a distinguished road
Mic'n question
Considering that we can record acoustic guitars through Mic's, wouldn't it be possible to record electric guitars also through Mic'n at relatively low volumes?
Reason I ask is, I live in an apartment and just ordered a 15W tube amp. And like to know if it's possible to record at pretty low volumes without getting arrested or evicted.
Thanks.
Old 08-13-2005
Outlaws's Avatar
Outlaws Outlaws is offline
Been Here, Posted That
Outlaws has a reputation beyond reputeOutlaws has a reputation beyond reputeOutlaws has a reputation beyond reputeOutlaws has a reputation beyond reputeOutlaws has a reputation beyond reputeOutlaws has a reputation beyond reputeOutlaws has a reputation beyond reputeOutlaws has a reputation beyond reputeOutlaws has a reputation beyond reputeOutlaws has a reputation beyond reputeOutlaws has a reputation beyond repute
Thanks.
You mean record the guitar with a mic or record the amp at a low volume with the mic?
If you mean the amp at a low volume, then yes.
If you mean the guitar itself, then yes, but it will be odd sounding IMO.
Get a Shure SM57 for a dynamic mic that has been used on thousands of professional albums and is very versitile, or search around for a condensor mic that will work good. The condensor will probably work a lot better at low volumes because dynamics can sometimes need a bit more signal to get the most out of them. But with a condensor you need phantom power.
But the way, is this 15watt amp by chance a UniValve? :P Where'd you get it at if you don't mind me asking?
Old 08-13-2005
Force of Nature
Outlaws-
I meant mic'n the Amp ofcourse! And yes it is a Univalve. You guessed correct, good job. Anyawy- so seems like it should be OK to record this at low volumes? I will be using 2x12 Mesa cabs with the amp.
Also, when I do get the Shure-57 mic, do you think I will beed a pre-amp? I think my Yamaha AW4416 has a good built in preamp. Any thoughts? Also, I think the AW4416 does have phantom power.
Thanks.
Old 08-13-2005
Outlaws's Avatar
Outlaws-
Thanks.
Dynamic mics tend to have a higher noise floor than condensors. So if you are recording at a low volume, the condensor might give better (cleaner) results.
The pres on the Yamaha should be fine.
Old 08-13-2005
Force of Nature
Thanks.
Do you have any recommendations for a condensor Mic? I am totally new to mic'n.
As a curiousity for me- do you know the dynamic range for both types of mic's?
Thanks.
Old 08-14-2005
Outlaws's Avatar
I would post a question in the mic forum. There are people over there that have used a lot more mics than I have.
Old 08-15-2005
thehymns thehymns is offline
Senior Member
thehymns has a reputation beyond reputethehymns has a reputation beyond reputethehymns has a reputation beyond reputethehymns has a reputation beyond reputethehymns has a reputation beyond reputethehymns has a reputation beyond reputethehymns has a reputation beyond reputethehymns has a reputation beyond reputethehymns has a reputation beyond reputethehymns has a reputation beyond reputethehymns has a reputation beyond repute
The Audio Technica AT4033 seems to be a favorite condensor on electric guitar. You can probably snag one off ebay for under $200.
Alan... No Stephen Paul Mic? DJL Microphones 249 07-27-2007 23:47
question about mixer matt's bedroom Newbies 3 05-04-2006 05:24
First Post: Ultimate Question!!! HyperSpace Recording Techniques 19 04-25-2005 08:29
Delta 1010 output question? henry_mullis Digital Recording & Computers 1 12-28-2002 11:12
stupid question about compression deathofamind Mixing / Mastering 10 12-13-2002 21:10
