One for the Amp Gurus
I have a Fender "The Twin" and the volume control is very sensitive. From off to full-on is barely a turn. Can I put in a different volume control so it's more gradual, it's a real pig to adjust on the run.
Clive |
Would a 500k or 1meg have any different tonalities? |
let's determine which amp model you have...
go to Schematic Heaven scroll down and click on Fender... then match a schematic to your amp... i think there should be a sticker inside the amp housing... |
No, the sticker inside only gives a listing of the valves used, the model is "The Twin" it's one of the Twin clones that was manufactured in the late 80's.
is this a known characteristic of this amp model?
I'm not familiar with that amp, but possibly a pot with a reversed audio taper from the installed pot or even a linear pot... assuming the pot installed is audio taper... to do this correctly, you need to determine the taper you have installed |
Clive |
If its one of the red knob models, I seem to recall they are super loud and clean. Could it be that the amp is so loud that the volume taper just seems fast? There is no gain left after you "barely" give it a turn from 0?
I had a late 80's Dual Showman and it was just so darn loud that even Vol 2 or 3 was too much for most live situations. I recall it had a really fast taper like you describe - but I just attributed it to the high power and headroom of the amplifier.
"I wouldn't recommend sex, drugs or insanity for everyone, but they've always worked for me." Hunter S. Thompson |
It's the best Amp I have ever owned out of 9 amps over 40 odd years. Cripes, about 5 of them I just seem to have lost, loaned them and left them, God knows where, hells bells, what miss-spent youth. |
Correction, read 13 amps over 40 odd years.
| effects loop MOD on tube amp | metalj | Guitars and Basses | 18 | 06-20-2005 19:03 |
| guitar > amp > mic > 4-track, or guitar > amp > 4-track? | topolino | Recording Techniques | 2 | 10-04-2004 00:07 |
| Yorkville YSM1p vs Yorkville YSMi + power amp | ambi | Mixing / Mastering | 25 | 04-01-2003 12:40 |
| difference between guitar power amp and PA power amp? | MegaGoo | Guitars and Basses | 11 | 02-18-2003 14:42 |
| RMS power, Peak(music) POWER? | covana | Newbies | 3 | 12-04-2001 14:42 |
