Guitar Hum
Anybody know what causes the electrical hum of a guitar? I'm getting a very loud hum when my guitar is plugged into a distortion pedal. Anyway to fix or reduce this hum?
Sorry I can't resist.
You'd hum too if you didn't know the words.
Bad cables ground disconnected inside of guitar improper "wall-wart" on distortion dimmer switches other electrical appliances on the same circuit noisy piece of shit distortion box/unit not knowing the words |
Guitar pickups make dandy antennae for picking up stray power line radiation. Distortion pedals are very high gain amplifiers, bringing out the worst of the hum. One way to quiet the guitar is to stay away from sources of electrical waves like TVs, PC monitors, and fluorescent lights. There are also some options available for making the guitar less susceptible to this phenomenon.
Please describe your guitar.
The fabulous Naiant Mics, perfect for acoustic instruments!
If you don't have DavidK's CD, you are a loser. My tunes. Thanks! ![]() NB DA BEARS! |
In my experience almost everything on planet earth, poor shielding, bad ground, bad cable, bad guitar connection, magnetic interference, tube computer monitors, and the list goes on and on.
Best solution is a noise gate, and to get your gain structure in a way that minimizes the amount you hear when the gate isn't catching it. Lots of the new digital gear is free of hum. |
haha
Thanks man, I will look into all of those ![]() |
This may (will) sound ridiculous as hell, but it works for me.
Get about 18" - 24" of speaker wire. Strip both ends. Unscrew one of the bridge screws and attach one end of the wire, tighten screw. To the other end of wire, solder a large washer (1" diameter or larger). After solder has cooled and you're ready to play, put the washer end in your pants! Specifically, in your belt so the washer has full contact with your skin. Again, it sounds weird, but it works for me. Try it.
Chunkadelic! |
Wow, more replies... Hmmm... Well APL, my guitar is a horrid piece of poop... a lotus... I do have a tube crt monitor, and I've tried a noise gate, but then I lose pretty much all those nice harmonics and such, the hum is that loud. Maybe its just time to upgrade the guitar. I was fearing that, but hey, gotta do what I gotta do...
Thanks for the replies guys, still gonna look into those other option first... ![]() |
noise gate shouldn't affect the timbre of your sound when it is open.
Not exactly sure what that meant, but when I try to get that hum out of there I need to have the thresh hold up high, which is why it takes away some of the guitar with the hum. I'd just rather fix the guitar, or get a new one rather than mess with a bad beginning sound. |
Boss makes a pedal for this:
http://www.musiciansfriend.com/srs7/...se_pid/151331/ I was recently watching a video of yngwie malmstreen (on the cdrom that came with guitar world) and he turned on his distortion pedal (causing a loud hum) then he kicked on the boss pedal and it killed the hum immediately. never used one... |
#12
#13
Oh no... a Lotus!
My first guitar was a lotus les paul copy... it's still sitting in the corner in my cellar... If you are confident that your house is wired correctly, I'd try the washer/speaker wire thing. Maybe the ground has come loose inside the guitar. If you are not sure about your wiring, I'm not sure I'd make myself the ground. |
#14
What kind of pickups? Single coil, humbucker, P-90...?
#15
| Does The Word "Lawsuit" Really Make You Think a Guitar Is Somehow Better? | Buck62 | Guitars and Basses | 24 | 07-15-2008 13:30 |
| Stereo Mic'd Guitar Panning | norg | Mixing / Mastering | 0 | 06-16-2005 17:33 |
| Which electric guitar?? | BJW | Guitars and Basses | 31 | 05-28-2005 21:54 |
