mixer reccomedations
i have a behri ub1222 fx for the first 6 months i thought it was just what the doctor ordered, but at this point im wanting a mixer with no noise, which my mixer has noise.I'm a one man band. so i just record one thign at a time so i dont need a lot of imputs, what i want is true quality.any reccomendations?
Gear: soundcraft Mixer m-audio audiophile 24/96 schecter guitars line6 spider amps various soft synths The one plugin that I cant live without:bbe sonic maximizer |
I've been pretty happy with my Soundcraft Compact 10. It's very quiet and pretty easy to use for recording. It has 4 mic inputs and 7 more channels for synths, drum machines, or whatever. They also make a smaller version of it called the Compact 4 I think. It only has 4 channels with 2 mic pres.
I lost my pants in the fountain. |
is it a quite mixer, how good are the mix pre's are they good? or would is till want a dmp3? thanks
The Yamaha 12/4 is a good, quiet inexpensive mixer.
www.recordinghelp.com ![]() "Information without Attitude" |
now im looking at more and more option, would i be better off getitng an audio interface that has phantom, wouldnt this eliminate extra noise that mixers may produce since i just record one track at a time?
how about the yamaha MG series vs. the alesis multimix serie, in terms of preamps, on -board effects and noise, quality of sounds, control, etc... thanx |
![]() Is there any need for a mixer at all? A standalone mic preamp is a more direct way of getting your signal 'to tape'. Les circuitry= less noise. The M Audio DMP-3 is great value. Clean, quiet and plenty of gain. If you really need a mixer (for headphone monitoring or whatever) then the Yamaha MG series is a good call if you're on a budget. The 10/2 should suit your needs. |
you can get various ramsa used console for dirt cheap.
If you are just recording 1 source at a time then a mixer would be overkill. You could just get an interface with built in pres and call it a day.
When I record drums I use my mixer but when I do vocals I go right into my Firepod. I figure anywhere I can shorten the path I will.
i do need my drum machione br ablre o hook up for swriting purposes, i m not looking back at straight anolgue mixers as i have ehard with usb mixers you cant do as many tracks well on my system anyway 1.0 ghz 320 ram. So i have kinda narrowed it down to either soundcraft compact 4 or mackie. how goos id soundcraft?
| PA vs Powered Mixer: Differences? | SKYflyer | Newbies | 5 | 08-07-2005 12:34 |
| Stereo out from mixer to Multitracker | paz8473 | Newbies | 3 | 05-29-2005 13:13 |
| Delta 44 vs. Windows Recording Mixer. God help me. | Shepherd | Digital Recording & Computers | 2 | 06-09-2003 07:39 |
| Help! How to route my mixer so I can monitor effects using my computer | kelitupu | Newbies | 3 | 05-10-2002 01:38 |
| my recording setup - NEEDS HELP | sykotic | Digital Recording & Computers | 12 | 10-06-2001 17:26 |
