70`s drums.
Hi guys, sorry for asking so many questions.
But I have to questions about drum recording. I`ve allready got the snare, the kick and the toms down. But I`m a bit unsure on overheads, should I compress over heads? Should I add reverb to over heads, keep in mind that I keep the rest of the set dry as an succsesfull AA member. My gut tells me to keep the OH`s dry from reverb, but the compressor bit makes me wonder. and by the way you guys rock, yoo allways take time to answer my questions. ![]() |
To be honest, all of that is really up to you and the kind of ound you're after personally.
I generally do NOT use verb on the overheads - unless it's a ballad, I'll add a very tiny bit of verb just to help the cymbals have a little more "room" in the mix. Typically, I compress everything a little bit. I compress everything in the mix, individually at a 2:1 ratio. This will probably sound strange, but I use 2:1 as if there is no compression on it. so if you were at 1:1 (no compression), you would use 2:1 Since I'm starting with 2:1, if I wanted to achieve a 2:1 type of ratio, I have to compress at 4:1 (I hope this is making sense.) But, I do not compress the kick while recording, because it will boost the cymbals and snare in the kick track if they are bleeding into the kick mic. So, I'll wait until after I gate the kick track to compress it during mixdown. Normally, I may or may not put verb on the toms, all depends on the song and the sound I'm after - and if I have even bothered to mic the toms, generally I just mic the kicks, snare, and a pair of overheads. I don't really feel the need to close mic the toms.....but I tend to be after a more organic drumsound than a lot of people...it's typically a big "rock" drumsound aka "John Bonham-ish" kind of sound.(Plus I use really large toms and they do not close mic very well.) Also, aside from just overheads, you could try using Room mics to help fatten up the drumsound without actually having "effects" on them. On my own stuff, I do use reverb on the snare - it's just a personal decision. Also, if you can, make a "Kick Tunnel" in front of the kick, because that will save you a lot of headaches. These days if I'm recording something and have the extra tracks available, I'll trigger the kick drum for the attack, and then mic the kick in a kick tunnel for the tone/body of the drumsound. Play around with the recordings, and see what you like - that is really the only way you will find out what you like. Try everything! That's the best advice I can give you. Tim |
Thanks Tim; your input is always valuebale.
will try the compressors out. |
Tim's recomendation to play around is the best you'll get. I finaly got pissed and sat for a day with just a kick drum to try to get the sound I wanted. I went through every idea I had heard and some I have not. Experiment! That is the key.
| My drums sound boring | gasal69 | Roland, Boss, VS Series Forum | 13 | 04-22-2005 10:53 |
| How to make my sampled (LM4) drums LOUDER? | Alchemist3k | Mixing / Mastering | 5 | 12-28-2002 09:40 |
| New Drums | Sennheiser | Recording Techniques | 6 | 10-29-2002 19:29 |
| Recording drums with only one condenser... | gilwe | Microphones | 6 | 10-22-2002 02:54 |
