Old 08-11-2005
burok burok is offline
Newbie
burok is on a distinguished road
urgent help!
going to check out an tascam 388 on sunday, need all the help I can get. some of it is urgent, check out:
http://homerecording.com/bbs/showthread.php?t=166210
(sorry for posting in this sub aswell, but I'm really desperate...)
Old 08-11-2005
cjacek's Avatar
cjacek cjacek is offline
Analogue Enthusiast
cjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond repute
See answer here:
http://homerecording.com/bbs/showthr...52#post1593252
Old 08-12-2005
technoplayer's Avatar
technoplayer technoplayer is offline
Practicing Gear-aholic
technoplayer has a reputation beyond reputetechnoplayer has a reputation beyond reputetechnoplayer has a reputation beyond reputetechnoplayer has a reputation beyond reputetechnoplayer has a reputation beyond reputetechnoplayer has a reputation beyond reputetechnoplayer has a reputation beyond reputetechnoplayer has a reputation beyond reputetechnoplayer has a reputation beyond reputetechnoplayer has a reputation beyond reputetechnoplayer has a reputation beyond repute
Thumbs up
I think cjaceks pictures tell the story quite nicely. (Good score)
I recently bought a 388, and then almost immedately had the chance to buy a 2nd one "sight unseen" for parts or repair, as the seller says it would not record.
Turns out the "parts" 388 works perfect (yay...clueless, but honest seller) and is actuallly nicer than the first one! I am pumped about the 388 !!
Probably the most important thing, other than pure cosmetics, is the tape transport and heads. Not much can go wrong or out of adjustment with the mixer section. If you have one of those little pocket tone generator (or a mic)you can plug into each mic input to confirm signal on all channels, that will probably tell you all you need to know about the mixer.
Head condition may be hard to discern, so look also at the tape lifter and guides to either side of the heads for wear or grooving....they would ideally looked like cjackeks pictures, i.e. no wear. Run a tape on the transport, look for good acelleration on the FF and RW functions, proper function of the counter tach, solid engagement of the pinch roller, good brakes, smooth operation and tape movement, etc..
Good luck, and make sure you get a manual one way or the other
Old 08-12-2005
cjacek's Avatar
Analogue Enthusiast
Yeah, just like technoplayer said: the tape lifters are a good indication of "usage" ... If you see significant worn down flat spots where the tape travels on them then take note.
~Daniel
URGENT HELP NEEDED WITH SM57>>>>>>>>>>>>>>>>>>> King Louis Microphones 19 11-30-2004 13:40
Urgent: Tascam MS-16 / MSR-16 / ATR-60 ? gilwe Analog Only 24 01-30-2004 08:33
Need urgent help on PXR-4!!!! HELP Mur Digital Recording & Computers 0 09-18-2003 22:39
Urgent Urgent MessianicDreams Guitars and Basses 8 12-22-2002 22:55
Urgent Advice With Analog Tape Copying Needed! janek Analog Only 5 02-26-2002 15:55
