Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 08-11-2005
onmoris onmoris is offline
Junior Member
onmoris has a spectacular aura aboutonmoris has a spectacular aura about
no pauses between tracks?
I'm working on a project and I need to have it so that the end of one track and the beginning of the next track flow into each other - in other words the sound doesn't stop but the track number changes. how can i do this? I know you can set your computer up to put no space between tracks when you burn a CD, but is there a way I can use my audio programs to set up the transition? I have protools LE and cubase SX, is there a way to do this or do I have to do it manually?
Old 08-11-2005
Massive Master's Avatar
Massive Master Massive Master is offline
MASSIVE Mastering, LLC
Location: Chicago area, probably looking for more coffee.
Massive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond repute
You *could* line them up in Cubase or what not, but you'll need a PQ editor for the burn anyway, so put the track markers in at that point.
John Scrip - MASSIVE Mastering
Spoon-feed a newbie the answer and he'll mix for a day --
Spark his curiosity to find the answer himself and he'll mix for a lifetime...
Old 08-11-2005
corban's Avatar
corban corban is offline
Registered Boozer
corban has a reputation beyond reputecorban has a reputation beyond reputecorban has a reputation beyond reputecorban has a reputation beyond reputecorban has a reputation beyond reputecorban has a reputation beyond reputecorban has a reputation beyond reputecorban has a reputation beyond reputecorban has a reputation beyond reputecorban has a reputation beyond reputecorban has a reputation beyond repute
What software do you use for burning? All software I've ever seen has a setting to change the silence between tracks. You can set it to zero and have all your tracks run together.
Old 08-11-2005
Fieva's Avatar
Fieva Fieva is offline
myspace.com/fieva
Fieva has a reputation beyond reputeFieva has a reputation beyond reputeFieva has a reputation beyond reputeFieva has a reputation beyond reputeFieva has a reputation beyond reputeFieva has a reputation beyond reputeFieva has a reputation beyond reputeFieva has a reputation beyond reputeFieva has a reputation beyond reputeFieva has a reputation beyond reputeFieva has a reputation beyond repute
I've heard that if you burn your tracks as "Disc at Once" it will do just that. It would make your CD without any empty sound assuming there is no silence at the end or beginning of any track.
Heavyhitta Beats
Hustle Magic
Old 08-11-2005
masteringhouse's Avatar
masteringhouse masteringhouse is offline
www.masteringhouse.com
masteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond repute
I use Waveburner Pro on Mac and CD Architect on a PC.
CD architect is a good standlone program for PCs, there are also programs like Wavelab and Sequoia that support processing as well. Most consumer level software will not allow for more advanced PQ editing (placement of index, start of song, pause etc.) which is likely why you are not seeing the option in your software.
You also try CDRwin, there's a free eval version here:
http://www.goldenhawk.com/
Tom Volpicelli
The Mastering House Inc.
MySpace:
www.myspace.com/masteringhouse
Old 08-11-2005
treymonfauntre's Avatar
treymonfauntre treymonfauntre is offline
Magic Bag Of Sounds
treymonfauntre has a reputation beyond reputetreymonfauntre has a reputation beyond reputetreymonfauntre has a reputation beyond reputetreymonfauntre has a reputation beyond reputetreymonfauntre has a reputation beyond reputetreymonfauntre has a reputation beyond reputetreymonfauntre has a reputation beyond reputetreymonfauntre has a reputation beyond reputetreymonfauntre has a reputation beyond reputetreymonfauntre has a reputation beyond reputetreymonfauntre has a reputation beyond repute
export the cd as one long wav and set indexes manually in your cd burning software?
Old 08-12-2005
iwantmypie's Avatar
iwantmypie iwantmypie is offline
Junior Member
iwantmypie is a splendid one to beholdiwantmypie is a splendid one to beholdiwantmypie is a splendid one to beholdiwantmypie is a splendid one to beholdiwantmypie is a splendid one to beholdiwantmypie is a splendid one to beholdiwantmypie is a splendid one to behold
I use Roxio Easy CD Creator and it is a great burning program. Easy lay out and what not and the best part is it came with my computer. Anyways there is an option in Roxio before you burn your CD to set the "transition" between one song and the next and this is where you can start to sound like you know what you are doing. I like to put a little cross-fade between my songs because it sounds professional to me. You can adjust the amount of fade and timing and what not with it and then preview it before you settle on anything. To top it all off there is so space between the songs. Just a nice smooth transition. I'm not sure how many other buring programs have this feature but I'm guessing most would. Hope this helps you out.
Old 08-12-2005
Fieva's Avatar
myspace.com/fieva
Are you using Easy CD Creator 6?
Heavyhitta Beats
Hustle Magic
Old 08-12-2005
iwantmypie's Avatar
Junior Member
I'm on my work computer now so I'll have to check when I get home. Back to work now!!
Old 08-12-2005
7string's Avatar
7string 7string is offline
Force of Nature
7string has a reputation beyond repute7string has a reputation beyond repute7string has a reputation beyond repute7string has a reputation beyond repute7string has a reputation beyond repute7string has a reputation beyond repute7string has a reputation beyond repute7string has a reputation beyond repute7string has a reputation beyond repute7string has a reputation beyond repute7string has a reputation beyond repute
I use Roxio also. I love the transition feature! However, since I've switched computers and to XP I've had constant problems with it. I get an error at the end of the burn and the CD's will only play in my computer and no where else.
7
Friends don't let friends mix drunk...
You can lead a horse to water... but he has to put on his own scuba gear...
I'd give my right arm to be ambidextrous...
I like the tempo but I don't like the beat. I give it a 6, Dick...
Old 08-13-2005
kajunjeaux99 kajunjeaux99 is offline
Newbie
kajunjeaux99 is on a distinguished road
kajunjeaux99
Lets say your song is 100 bars in length. What I would do is:
Record the first song on track 1 and 2, track 1 being the left and track 2 being the right. Then I would start my "Fade out" at bar 99 and fade out at 100. Then I would import the next song and start the beginning of the song at bar 99 and fade-in from bar 99 to 100. So in effect one song fades directly into the next. You can also make the "fade-in/fade out" longer or shorter by increasing or decreasing the span on your fade-in/fade-out.
I hope this is some help to you. ... Kajun Jeaux
  #12
Old 08-14-2005
Marciano Marciano is offline
Newbie
Marciano will become famous soon enoughMarciano will become famous soon enough
You can use wavelab to mount the cd and burn thru there!
the last album i record i didn't have a single moment without sound, and i did all the montage on wavelab and burn the cd trhu there! Try it
Cheers
Márcio Silva
Ps : and it suports Pq editing...
  #13
Old 08-14-2005
EddieRay's Avatar
EddieRay EddieRay is offline
EddieRay has a reputation beyond reputeEddieRay has a reputation beyond reputeEddieRay has a reputation beyond reputeEddieRay has a reputation beyond reputeEddieRay has a reputation beyond reputeEddieRay has a reputation beyond reputeEddieRay has a reputation beyond reputeEddieRay has a reputation beyond reputeEddieRay has a reputation beyond reputeEddieRay has a reputation beyond reputeEddieRay has a reputation beyond repute
CDRwin looks pretty good.
I've also been on the lookout for CD burning software for music and data. Right now I'm just using Windows Media Player to create music CDs but for some reason I'm unable to burn data CDs with whatever XP has built in (never detects the blank in the CDRom drive). So the software I'm looking for would have to do both.
But I didn't see my CDR device listed at GoldenHawk's website. It's only 3 or 4 years old. Do you think that could be related to the data CD problem I have? Should I take a chance on the CDRwin working okay?
  #14
Old 08-14-2005
I would try the evaluation version of CDRwin before making any commitment to it. Last I tried it, the evaluation lasts indefinitely but is limited to burning at 1X.
As far as burning CD and data, are you referring to a multisession CD or just being able to burn them separately?
I usually use Roxio, Nero, or Toast for burning data CDs and Waveburner or CD Architect for music CDs. For multisession its usually Waveburner for the music portion and Toast for data.
Tom Volpicelli
MySpace:
  #15
Old 08-15-2005
EddieRay's Avatar
I meant separately. I'm unable to backup data files to CD.
BTW, is that how I would burn an mp3 CD - copy them as data files to a blank?
  #16
Old 08-15-2005
SouthSIDE Glen's Avatar
SouthSIDE Glen SouthSIDE Glen is online now
independentrecording.net
SouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond repute
If you're just looking to burn data and MP3 CDs and want to save a few bucks, there a piece or freeware out there calle CDBurnerXP Pro that looks and operates in the same class as something like Nero and Roxio. I've been using it on one of my other systems for about 6 months now with a TDK VeloCD 48/10/24 and it has worked flawlessly. Just do a net search for it.
It'll burn basic audio CDs as well, and they have worked fine, but for your pre-master productions I'd stick with something like CD Architect or Wavelab.
G.
Glen J. Stephan,
SouthSIDE Multimedia Productions
RECORDING RESOURCES AND INFO SITE:
  #17
Old 08-22-2005
EddieRay's Avatar
FYI: I tried the CDRWin demo. It is fully functional software but only burns at a speed of 1x. It works. However:
1. I could not find any means of setting the gaps between tracks.
2. Windows Media Player 10 would not play the burned CD. Winamp has no problem, nor do standard CD players (so far).
That is all.
  #18
Old 08-23-2005
xstatic xstatic is offline
Been Here, Posted That
xstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond repute
CD Architect is an amazing program for PC's. Not only can you change whatever you want, but it gives you a grpahic representation of your CD project so you can actually drag the files to where you want. It even has basic envelope editing and trimming built into it. Wavelab also works pretty well for this stuff, but CD Architecht was designed to do just what it does
  #19
Old 08-23-2005
EddieRay's Avatar
What is "envelope editing and trimming"?
Y'know, I've been using Windows Media Player to test .wav files and burn CDs and have always had a problem playing those CDs on my portable Magnavox player in my car (plugs into cigarette lighter and cassette tape player). But the one I burned with CDRWin played with no problem. Plus I just upgraded to WMP 10.0 and it's even more difficult than ever to use. So it's time for me to move on to something more serious. Can you confirm that CD Architect allows you to set the time gap between tracks? Meanwhile I'll do some searching....
  #20
Old 08-23-2005
gullfo's Avatar
gullfo gullfo is offline
Dedicated Member
gullfo has a reputation beyond reputegullfo has a reputation beyond reputegullfo has a reputation beyond reputegullfo has a reputation beyond reputegullfo has a reputation beyond reputegullfo has a reputation beyond reputegullfo has a reputation beyond reputegullfo has a reputation beyond reputegullfo has a reputation beyond reputegullfo has a reputation beyond reputegullfo has a reputation beyond repute
yeah, CD Architect pretty much does it all. you can even plug in effects on each song or the entire CD if you want to do some additional eq'ing... you can use envelopes to set levels, you can overlap songs and do cross fades, add CD test, the works... very good tool...
Glenn
fossile music
  #21
Old 08-23-2005
Envelope editing allows you to make basic changes to a song through a graphic automation interface. In general with CD architect you would just be doing volume changes between tracks, or custom fades and crossfades. Trimming in CD Architect is a basic 2 track editor. Its pretty primitive as far as intense editing goes, but its purpose is really to allow you basic editing of a track without having to reopen that track in your primary 2 track editor.
Mixing strategies for stereo tracks? petimar Mixing / Mastering 8 05-29-2008 13:20
need help with V tracks on BossBR8 soundmaster Roland, Boss, VS Series Forum 10 01-31-2006 18:31
Can you drag tracks freely in Acid XPress? matt's bedroom Newbies 4 06-08-2003 14:45
Mastering Sonar tracks in Wavelab then to CD 4ever Cakewalk / Sonar Forum 5 09-24-2002 11:42
9 Drum Tracks in Two Days... remote drum recording... Blue Bear Sound Recording Techniques 58 03-01-2002 07:15
