Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 08-11-2005
FALKEN's Avatar
FALKEN FALKEN is offline
FALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond repute
another question for tha pro's.
do you calibrate your mixer before mixing a project? i.e., use test tones to ensure that each track is indeed centered, and that busses and auxes are equalized if sending stereo signals? Anything else I might be missing?
Old 08-11-2005
Massive Master's Avatar
Massive Master Massive Master is offline
MASSIVE Mastering, LLC
Location: Chicago area, probably looking for more coffee.
Massive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond repute
I "somewhat regularly" run test tones and set everything at unity to make sure the chain is solid.
If there's ever ANY question of the integrity, I drop whatever I'm doing and run a test for sure.
John Scrip - MASSIVE Mastering
Spoon-feed a newbie the answer and he'll mix for a day --
Spark his curiosity to find the answer himself and he'll mix for a lifetime...
Old 08-11-2005
FALKEN's Avatar
Thanks, massive. I was all pissed off at my mixer and ready to buy a new one....then it occured to me to just run some test tones and to compensate for its deficiencies. which is what I did. was wondering if that is normal... i.e., if I bought a new mixer i would still probably have the same problem anyway.
Old 08-11-2005
Well, if you can zero in on exactly where the problem is, it might be something ridiculously easy to fix.
Other times, not so easy. But either way, knowing precisely where the problem is in the chain is the first step to correcting it.
Old 08-11-2005
FALKEN's Avatar
hmm...where do I start...the master bus and the sub bus are both split into L and R, which are not "equal" when set visually equal. all of the auxes are not equal (for sending stereo), the returns are not equal, hell, if I have channel 1 panned L and channel 2 Panned R, those are not equal, even coming off the direct outs, with no gain. its an old board that was gigged with a lot, but it has 16 inline channels and I got it for 300 in an skb case.
Question for the Recording Pro's.... brn2bafactor Digital Recording & Computers 3 05-30-2005 12:20
Question bout sub and turntables onlydude DJ & Hip Hop Production 5 03-24-2005 18:21
Question for the PROS (or whoever knows the answer) chris-from-ky The Rack 1 02-16-2005 20:29
A question for the pros out there... octoruss Recording Techniques 8 06-11-2002 15:59
Question for the pros smellyfuzz Recording Techniques 8 08-20-2001 03:49
