Kick drum hole location
Hey all you drummers, Is there an ideal place to put a hole in the resonant head of a kick drum for mic'ing? Currently I have mine about 3-4" from the edge. Its a hole about the size of a CD
. It looks to be in the standard 4 oclock position but I want to move it to the 12 o'clock position so I can use that boom stand somewhere else. Is this a no no?
I lost my pants in the fountain. |
Why don't you put it at the 6 o'clock position and just use a "mini" mic stand?
Tim |
Does position of the hole have any relevance at all? I know it helps with kick back of the pedal, anything else?
Sorry to hijack the thread.
I don't dispute the doubts you've outlined But it is my right to waste your time... When Life sets down in funnel form and sucks you in... |
Sure it does - a center hole will allow more air to pass through it since most of the pressure is from directly in the center of the drum. A drum with a hole out-of-center will resonate a tad more since the sound has more of an area, where the focused sound is (in the center) , to resonate (against the resonant head).
boomtap |
It will change wherever you place the Porthole.The point is the less diameter
the more it resonates..... |
So I should be able to put it at 12 o'clock without any noticable change?
What size hole are you thinking of having? The diffrent size changes the sound...more than you'd think.
Ever notice that people labelled eccentric are usually geniuses? |
I made the hole awhile back. It's the size of a CD. I used that to trace the circle.
Just a hole in the head? No tape around it? or a holz? or something similar?
#12
It's totally untreated. I prefer to go natural.
It's a crap reso head so I plan to replace it some time in the future.
#13
| Kick drum mic comparison | Mongoo | Microphones | 0 | 10-27-2004 15:25 |
| kick drum head - holes & sound question | teainthesahara | Drums and Percussion | 6 | 02-20-2004 07:56 |
| 3mic drum set up. Centering the Kick? | Booda | Recording Techniques | 1 | 02-01-2004 02:32 |
| Kick drum seems to be lagging on final mix | Joel76 | Drums and Percussion | 6 | 03-07-2002 16:51 |
| How I got a bigger kick drum sound... | PapillonIrl | Drums and Percussion | 17 | 12-19-2001 00:55 |
