Go Back   Home Recording > Equipment Forums > Drums and Percussion
Reply    Audiofanzine Drum Drum News Drum Medias Drum Tests Drum Articles Drum User Reviews Drum Classifieds Ads
Old 08-10-2005
VTgreen81's Avatar
VTgreen81 VTgreen81 is offline
Dedicated Member
VTgreen81 has a reputation beyond reputeVTgreen81 has a reputation beyond reputeVTgreen81 has a reputation beyond reputeVTgreen81 has a reputation beyond reputeVTgreen81 has a reputation beyond reputeVTgreen81 has a reputation beyond reputeVTgreen81 has a reputation beyond reputeVTgreen81 has a reputation beyond reputeVTgreen81 has a reputation beyond reputeVTgreen81 has a reputation beyond reputeVTgreen81 has a reputation beyond repute
Who can help me get started with triggering acoustic drums?
demoed a DTXpress yesterday, liked the sounds of the drums, did not like the feel of the pads or sound of cymbals. I don't think I'll ever want to play electronic pads, but now I want to learn about triggering. I'm guessing I'd still use overhead mics to capture cymbals. Do I need a module or can I use software like Drumagog of DK from Hell?
All I really know is I don't know enough to even go buy triggers yet.
Thanks,
Dan
Have a wonderful day........................and make someone else's day wonderful too
Old 08-10-2005
mikeh mikeh is offline
2.5K Gold Member
mikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond repute
A drum trigger captures the vibration (impact) of the drum and sends that signal into some type of converter (drum module, etc.) The converter can then converts the "pulse" to a MIDI signal which can then feed to various other modules or software applications.
The triggers normally have a 1/4" jack which must be plugged into whatever converter (module) you use. That would then either have audio outs, to output sounds from that module or MIDI out, to feed a MIDI signal to whatever software application you choose (if you want to use DFH or whatever).
So yes, you would need a converter to accept the 1/4" jacks. I've been told they have new converters which do not require 1/4" input - but I have not seen or tried such animals.
Old 09-13-2005
boomtap's Avatar
boomtap boomtap is offline
Dedicated Member
boomtap will become famous soon enough
Has anybody tried triggering an acoustic kit that has those practice silencer (neoprene mats) on them?
Old 09-13-2005
Tim Brown's Avatar
Tim Brown Tim Brown is offline
Why 2K?
Tim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond repute
It has already been established that you can plug the triggers into individual mic inputs on a computer recording soundcard - such as one with 10 inputs(each trigger/drum's signal must go on its own channel/track) and then have Drumkit from Hell or Drumagogue do a "track replacement", thereby eliminating the Trigger to MIDI Interface - BUT, it can not do it in real time - you have to record the strikes first, and then replace the tracks.
Why not just buy the screen heads? you can get them to fit most standard sized drums.
Tim
Old 09-13-2005
tourettes5139's Avatar
tourettes5139 tourettes5139 is offline
ugh..........
tourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond repute
Drumagogue?
Check out my band!!
www.myspace.com/darkvelvetlaughter
GFCG Membership No:000 019
Old 09-14-2005
boomtap's Avatar
Dedicated Member
I am in the process of doing a conversion by ordering th e screen heads, I just was thumping around and had the practice pads on and was thinking, 'hey has anyone tried this".
Old 09-14-2005
pandamonk's Avatar
pandamonk pandamonk is offline
Three Thousand and Counting
pandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond repute
Can you do this with an e-drumkit with no module? Plus, what do you mean by"you have to record the strikes first, and then replace the tracks", do you mean, once you've recorded the tracks you assign each one to a drum sound? What about the velocity, does that work or is it all just the same?
Old 09-14-2005
Tim Brown's Avatar
Why 2K?
You are basically using the triggers like microphones when you record. Except insterad of delivering a quality sound, the trigger will deliver an electric "spike" or strike each time you hit the drum.
So you have to record each of these drum triggers on it's own track - that way, when you assign sounds to them, you can have the entire kit separated, otherwise it won't work.
Velocity and all of that should work, because the triggers are fully dynamic - and the electronic signal delivered will be dynamic.
I personally haven't tried it because I don't record on a PC, or use any of those programs, but I do trigger my kit and I use the triggers to open and control Gates and Compressors when I'm miking my kit.
Tim
Old 09-17-2005
brandrum brandrum is offline
Jesus Loves me.
brandrum has a reputation beyond reputebrandrum has a reputation beyond reputebrandrum has a reputation beyond reputebrandrum has a reputation beyond reputebrandrum has a reputation beyond reputebrandrum has a reputation beyond reputebrandrum has a reputation beyond reputebrandrum has a reputation beyond reputebrandrum has a reputation beyond reputebrandrum has a reputation beyond reputebrandrum has a reputation beyond repute
Tim
that would be a great idea for volume purposes....a tip though. you might want to cover the bearing edges, since mesh heads can have a sandpaper effect on bearing edges.
The road to hell is paved with good intentions.
Simply Emotional (acoustic g., elec. drums, piano, gang vox) shackrock MP3 Mixing Clinic 2 08-10-2005 13:28
Recording Acoustic drums on cakewalk 7.0 FABE Drums and Percussion 6 07-05-2004 01:10
Making 'real' drums in Fruity Loops. Meshuggah Recording Techniques 11 11-11-2002 13:01
Triggering my drums?? SirPsychoSexy Drums and Percussion 4 08-01-2002 19:01
