Old 08-08-2005
memriloc memriloc is offline
Dedicated Member
memriloc has a reputation beyond reputememriloc has a reputation beyond reputememriloc has a reputation beyond reputememriloc has a reputation beyond reputememriloc has a reputation beyond reputememriloc has a reputation beyond reputememriloc has a reputation beyond reputememriloc has a reputation beyond reputememriloc has a reputation beyond reputememriloc has a reputation beyond reputememriloc has a reputation beyond repute
Advice Needed...
i guys...Havn't been 'round here in ages...Good to be back...
OK, story goes:
DAW via M-Audio Delta 1010
Fostex G-16-S
Soundtracs Solitair
Daw and Solitair no problem, running at +4 but the Fostex runs at -10 only, I'd like to know if there's a way of running it at +4 so's I can change all the jumper links in my solitair back to +4...Any thoughts? I know you can get little adaptors to attenuate a +4 device down to -10 but don't know if you can do it the other way...Any help would be great...Cheers, DOM!
www.feckstudios.com
This World Wouldn't Stink So Much If There Weren't So Many Arseholes...
Old 08-09-2005
Dr ZEE's Avatar
Dr ZEE Dr ZEE is offline
Anti-Pro Circles Insider
Dr ZEE has a reputation beyond reputeDr ZEE has a reputation beyond reputeDr ZEE has a reputation beyond reputeDr ZEE has a reputation beyond reputeDr ZEE has a reputation beyond reputeDr ZEE has a reputation beyond reputeDr ZEE has a reputation beyond reputeDr ZEE has a reputation beyond reputeDr ZEE has a reputation beyond reputeDr ZEE has a reputation beyond reputeDr ZEE has a reputation beyond repute
people use this thing ... from a well respected brand-name , I guess you'll need two of 'em. Personally I can't say anything about the unit 'cos never had one ..never needed one.
Maybe other guys here have better experience.
/respects
Dr ZEE
MZE | ZDL | DZW
Old 08-09-2005
Dr ZEE's Avatar
ooops
I guess this unit can be used as only 6 channels line-level (matching) amp .... so it turns out that to please all 16 channels of your Fostex you'll need three of them ... , but , wait, if you also want to have both ins/and outs to match with the rest of your +4 setup, then you'd need another three of them, working in "reverse action" .... that's allot of Behringer in your rack! Scary! )
if you have six of em', then you'll have four channels left 'unused'.... so you can get yourself some -10 level analog two-track for mixdown .... why waste channels?
silly stuff
Dr ZEE
MZE | ZDL | DZW
Old 08-09-2005
arjoll's Avatar
arjoll arjoll is offline
Force of Nature
arjoll has a reputation beyond reputearjoll has a reputation beyond reputearjoll has a reputation beyond reputearjoll has a reputation beyond reputearjoll has a reputation beyond reputearjoll has a reputation beyond reputearjoll has a reputation beyond reputearjoll has a reputation beyond reputearjoll has a reputation beyond reputearjoll has a reputation beyond reputearjoll has a reputation beyond repute
If you know electronics, you can do what you need to do with a pile of op-amps. I still use TL071/072/074's - not as 'cool' as some of the others but they work and sound ok. Use a single op-amp as a differential amp and gain less than unity to go from +4 balanced to -10 unbalanced (nicer than a pad, but you could go the pad way as well); use a dual op-amp, one side wired inverting with some gain, the other inverting with unity gain and take the outputs to be hot (the side with unity gain) and return (the other one) to your XLR. Add appropriate resistors and caps. You'll need 16x TL071's and 16x TL072's (or you could use 12x TL074's but I'd prefer different chips for each channel).
There are, of course, a huge number of nice tidy rackmount boxes that do this - there was a thread a while ago with a range of these, where A Reel Person quite rightly pointed out that not everyone has the time, skills or inclination to make their own gear!
Cya
Andrew
Old 08-09-2005
The Ghost of FM's Avatar
The Ghost of FM The Ghost of FM is offline
French Mofo
The Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond repute
A couple of these things could work also.
http://www.tascamcontractor.com/products/LA-80.html
Cheers!
Old 08-09-2005
SteveMac's Avatar
SteveMac SteveMac is offline
Force of Nature
SteveMac has a reputation beyond reputeSteveMac has a reputation beyond reputeSteveMac has a reputation beyond reputeSteveMac has a reputation beyond reputeSteveMac has a reputation beyond reputeSteveMac has a reputation beyond reputeSteveMac has a reputation beyond reputeSteveMac has a reputation beyond reputeSteveMac has a reputation beyond reputeSteveMac has a reputation beyond reputeSteveMac has a reputation beyond repute
Do I need to know what this is all about?
New Studio Advice Needed! Anomaly Design Digital Recording & Computers 0 04-26-2005 08:41
Advice needed... BrettB Studio Building & Display 3 07-15-2002 13:14
3 mic on drums, advice needed A1A2 MP3 Mixing Clinic 11 02-18-2002 11:03
Advice needed! DA GOAT DJ & Hip Hop Production 2 08-20-2001 02:53
Advice Needed! Building Home Studio RockinRobert Studio Building & Display 3 10-03-2000 23:48
