Old 08-08-2005
Colwarter Colwarter is offline
Junior Member
Colwarter has much to be proud ofColwarter has much to be proud ofColwarter has much to be proud ofColwarter has much to be proud ofColwarter has much to be proud ofColwarter has much to be proud ofColwarter has much to be proud ofColwarter has much to be proud ofColwarter has much to be proud ofColwarter has much to be proud of
M-audio TAMPA : something strange
I got a new M-audio TAMPA like 2 weeks ago, and it seems like it changes "almost" nothing to my recordings. And yes, I tried to set it a lot of different ways, I tried all the buttons and the difference between using and not using the m-audio tampa is very little. I use a Presonus Firepod, nothing else, and it sounds almost the same when I just put a mic in a line of firepod than when I put my mic in the tampa. Do you have any ideas on how to solve my problem???
Old 08-09-2005
Zed10R Zed10R is offline
Force of Nature
Zed10R has a reputation beyond reputeZed10R has a reputation beyond reputeZed10R has a reputation beyond reputeZed10R has a reputation beyond reputeZed10R has a reputation beyond reputeZed10R has a reputation beyond reputeZed10R has a reputation beyond reputeZed10R has a reputation beyond reputeZed10R has a reputation beyond reputeZed10R has a reputation beyond reputeZed10R has a reputation beyond repute
The answer I see coming from the pro's on the board is a common one. I have seen it many times.
You will not hear much of a difference in the sound untill your mix gets full. Then you will notice a greater degree of seperation between all your tracks, and the details will show more clearly.
A "good" preamp will not give you a night and day improvement over a "not so good" preamp (or none at all) on just a couple tracks.
Bottom line is you just have to keep using it untill you find it's voice.
Good luck.
Old 08-09-2005
fraserhutch's Avatar
fraserhutch fraserhutch is offline
Flypaper for freaks
fraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond repute
Absolutely right.
I would also add that you will likely not hear much of a difference if you have a weak monitoring chain.
What is your chain?
The fact that no one understands you doesn't mean you're an artist...
Old 08-09-2005
SonicAlbert's Avatar
SonicAlbert SonicAlbert is offline
Super-Sonic "Herb" Albert
SonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond repute
I don't think the Tampa is going to be worlds apart from the Presonus when it comes to preamps anyway. It's not like it's a big jump up several classes of gear, it's basically in the same range. So I'd be surprised if there were a big difference.
But certainly if you engage the compressor and dial in some extreme settings you should hear a difference. Have you tried that? Try dialing in an extreme threshold setting and then twiddle the attack and release knobs. If you don't hear that, then I'd be worried something is amiss with the unit.
But if you are bypassing the compressor and just using the preamp, I doubt you'll hear much difference. On one track or many. Just my opinion.
Old 08-09-2005
Jtt Jtt is offline
Newbie
Jtt is an unknown quantity at this point
Arrow
And no offense to all the proponents. But the whole: you won't hear a difference until there are a zillion tracks smacks of BS. If there is a difference, then it must be audible on one track. Saying things stack up weird etc., sounds more like problems of eq and source.
I have a nice pre, (Great River)---and I 'can' hear the difference between it and a mackie on a single track. So I don't doubt that pres can make a difference, but... if it takes a thousand tracks to hear the difference, I want my money back.
And to echo Albert--tampa and presonus pres probably aren't all that different.
Record some music.
J
Old 08-09-2005
LemonTree's Avatar
LemonTree LemonTree is offline
Suck 'em and see!
LemonTree has a reputation beyond reputeLemonTree has a reputation beyond reputeLemonTree has a reputation beyond reputeLemonTree has a reputation beyond reputeLemonTree has a reputation beyond reputeLemonTree has a reputation beyond reputeLemonTree has a reputation beyond reputeLemonTree has a reputation beyond reputeLemonTree has a reputation beyond reputeLemonTree has a reputation beyond reputeLemonTree has a reputation beyond repute
That's excellent! a nice clean sounding pre...exactly the same as my Tampa. Now punch in some compression, yep pretty clean too. It does exactly what it says on the tin.
Lemontree Studio
Not bitter, not twisted!
Old 08-10-2005
beeson beeson is offline
Newbie
beeson is on a distinguished road
Same deal
You know, I've thought the same thing...very clean. I'm trying to get more out of it myself...say is there any way to use the compressor alone on that sucker?
Sample CDs and Reason Refills for Sale! AllStaar.Com DJ & Hip Hop Production 6 04-03-2006 13:16
Strange problem with the left side of the audio. swatsds Cool Edit Pro / Adobe Audition Forum 1 05-26-2005 23:32
The Mic Test Thread! Rhythmschism Microphones 41 04-30-2004 12:23
ARRGH: Audio folder for recording externally mixed audio in 5.1 Lopp Cubase User Forum 0 10-04-2002 15:54
