Go Back   Home Recording > User Forums by Brand > Cubase User Forum
Reply    Audiofanzine Steinberg Steinberg News Steinberg Medias Steinberg Tests Steinberg Articles Steinberg User Reviews Steinberg Classifieds Ads
Old 08-08-2005
BATERIA71 BATERIA71 is offline
Newbie
BATERIA71 is on a distinguished road
Need Advice!!
Can Anybody Explain To Me The Difference Between Cubasis Vst 3.7 And Cubase Le. I'm Very New At This , I Have Cubasis Vst And You Can Put Up To Six Inserts At One Time Per Channel And For What I Read Le Has Two Inserts At One Time Per Channel ,so Why Is Le Better Or Not? .any Advice Is Appreciated ,i Just Don't Want To Get Something Without Knowing What I'm Getting ,thanks Paul
Old 08-08-2005
Easto's Avatar
Easto Easto is offline
Dedicated Member
Easto has much to be proud ofEasto has much to be proud ofEasto has much to be proud ofEasto has much to be proud ofEasto has much to be proud ofEasto has much to be proud ofEasto has much to be proud ofEasto has much to be proud ofEasto has much to be proud of
I'm not sure what version the LE is but if it's one of the more recent releases it has a better audio engine and coding that the old VST version. I believe it also gives you the option to run the latest verions of certain plugins.
Old 08-09-2005
Carter's Avatar
Carter Carter is offline
Total gear slut
Carter has a reputation beyond reputeCarter has a reputation beyond reputeCarter has a reputation beyond reputeCarter has a reputation beyond reputeCarter has a reputation beyond reputeCarter has a reputation beyond reputeCarter has a reputation beyond reputeCarter has a reputation beyond reputeCarter has a reputation beyond reputeCarter has a reputation beyond reputeCarter has a reputation beyond repute
That version would be Cubase SL3 or SX3, LE is a limited version and I think you can only get that version bundled with some hardware, you would be better off going with Cubase SE for $100.00.
Cubase SL3 $349.00
Cubase SX3 is some where in the $700.00 range depending where you get it.
Carter
MCF Productions
EQ Advice on Bass Drum? Accroya Mixing / Mastering 3 08-19-2005 09:59
advice on equipment napalm229 Newbies 5 10-26-2004 12:22
i could use a little mixing and mastering advice Levant Mixing / Mastering 32 04-22-2004 13:14
Advice? ChristopherM MP3 Mixing Clinic 6 10-02-2003 13:47
Forum advice requested - if ya got a minute MC Gitarz MP3 Mixing Clinic 9 08-04-2003 20:15
